Fixes: 3560660 linux-toradex: synchronise defconfigs
Related-to: ELB-2510
Basically, as per the following commit from the
toradex_4.14-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git
ab66d6c48c8e78e74ebbf41505db65b0830e6fd7
ARM: apalis/colibri-imx6/7/6ull: enable options for backports
8d6cc5a3e9a2cf349c4d42e13c4449f16512651e
ARM: apalis/colibri-imx6/7/6ull: disable wireless drivers
c666f52447fa426fdc414bb1c922d89969f25385
arm64: defconfig: enable options required for backports
d55c4e1ff7f1a6b23908d45bfec48b2c717d13fe
arm64: defconfig: disable wireless drivers
Related-to: ELB-2687
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
19a90652d70208c755d3339e21f6bfc8cae04b82:
ARM: apalis/colibri: defconfig: remove backported drivers
76b17e9c0b6f0245dc76c59062257bea2d0d6a0f:
arm64: apalis/colibri: defconfig: remove backported drivers
Related-to: ELB-2388
Resync with latest configs in the kernel, but switch on PREEMPT_RT_FULL.
Final synchronization with the commit from the toradex_4.14-2.3.x-imx
branch on git://git.toradex.com/linux-toradex.git:
25c008952d3a61c9c402126d4ba7424ef8132f90
arm64: defconfig: further config clean-up
Basically, as per the following commit from the toradex_4.14-2.3.x-imx
b1df9c77a53e92dc6b993007e3d8bb1f3cc61bf6:
colibri imx6ull: defconfig: enable building backports-5.4
Basically, as per the following two commits from the
ad4d419f1b24e1d986e2fe956c1f3ca7d1eab93f:
apalis/colibri_imx6/-imx6ull/_imx7/-imx8/8x_defconfig: config refresh
Related-to: ELB-2351
This provides headers unique to the NXP downstream kernel.
Since linux-toradex is rebased onto NXP's downstream kernel the needed
git hash is also part of our linux-toradex git and we can save the
download of a second kernel git repo.
u-boot-toradex-common.inc: all but below
u-boot-toradex-common_2018.03.inc: i.MX 8 series based modules
u-boot-toradex_2016.11.bbappend: Toradex Easy Installer 2.0
linux-toradex_4.14-2.0.x.bb: all NXP based modules
Resync with the defconfigs from the kernel repository. This adds:
- fix ip firewall (bpf/cgroup)
- Revert "arm64: defconfig: Choose the newer version of the ov5640 driver"
- enable USB WiFi adapter.
Related-to: #58517
Resync with the defconfig from the kernel repository. This adds:
Related-to: #32198
Synchronise with kernel defconfig
- add USB HID raw support
- enable ext4 file system security support
(cherry picked from commit 557a0e42badba143a8c0b3b0ef0eb1d4ebb5ee10)
- enable USB-to-serial adapters
- add load edid support
Related-to: #57567
(cherry picked from commit b103c379c216b5e370e7702b3e586e81c38625bb)
Enable zram which is useful for compressed swap space in memory. This is
especially useful on embedded devices where swap space on a block device
is not typically enabled (to avoid flash wear).
Resync with kernel defconfig, this includes:
- defconfig: fix delayed mxt loading
- defconfig: fix ip firewall (bpf/cgroup)
The RT project moves the patches into an 'older' directory once superseeded
by a newer patch.
Provide both download paths to cope with the changing location.
While at it use the OE maintained KERNELORG_MIRROR variable to specify the path.
Update rt kernel recipe to use the linux-toradex_4.14-2.0.x kernel.
Re-sync defconfig which enables emulation for deprecated instructions
in ARMv8 for AArch32, enables CAN MCP251X driver, enables a generic
LVDS panel driver and disables CAAM Keystore test driver.
Re-sync defconfig e.g. taking the following dumb-vga-dac idrm bridge
enablement into account:
http://git.toradex.com/cgit/linux-toradex.git/commit/?id=551ce056fd0cd91ae8237d1517469bc1b0f4366f
Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
Update the components which NXP forked or provides to the version
used in the 4.14.78_1.0.0_ga BSP.
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
