Add Linux kernel recipe which patches the Toradex Colibri VF50/VF61
kernel with the 4.4.60-rt73 PREEMPT RT patch set.
Disable the fusing/one-time-programmable driver by default. It
allows to blow fuses which might make the module unusable with
a simple sysfs write...
While at it remove double assignement to 'S'.
To select the kernel use a preferred provider variable in your
configuration files (e.g. local.conf):
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt"
Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com>
Configure Bluetooth to be built as kernel modules by default. This
allows to make use of USB/SDIO based Bluetooth solutions easier.
This kernels are based on the fslc community kernel which in turn are
based on the NXP 4.1.15 released kernels.
They can be used for Apalis iMX6, Colibri iMX6, and Colibri iMX7.
Kernel upgraded to 3.14.52 kernel.
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Auto-load rpmsg/remoteproc modules during boot.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Update defconfig to build rpmsg and remoteproc.
Synchronize defconfig with kernel git.
Resynchronize defconfig with the git tree version:
The audio Codec Machine driver was missing hence the sound card
got not detected by the SAI driver.
While we enable CONFIG_IIO_SYSFS_TRIGGER in kernel source defconfig
this is not enabled in defconfig being used in OpenEmbedded. This
results in sysfs triggers not being enabled by default in an image
build with OpenEmbedded. This is already observed with our last
release 2.6 Beta1 image.
A new i.MX6/i.MX7 real-time 3.14.52 kernel recipe was added with a
modified PREEMPT_RT patch to accomodate the backports applied to
the Toradex kernel.
Use KERNEL_MODULE_AUTOLOAD to load USB gadget support. This is
required for libusbg (gadget-import) to work.
Update defconfigs and drop picking the defconfig from the kernel sources.
A new i.MX6 real-time kernel recipe was added with a modified
PREEMPT_RT patch to accomodate the backports applied to the
Toradex kernel.
