Adjust defconfigs for use with backports
linux-toradex-4.1-2.0.x/defconfig is not building for machine
apalis-imx6, colibri-imx6, or colibri-imx7.
But the kernel does not (no longer`) build for this configuration.
| LD init/built-in.o
| drivers/built-in.o: In function `mxc_hdmi_disp_init':
| coresight-etm-cp14.c:(.text+0x4499c): undefined reference to `mxc_cea_mode'
Also include the patch from Julio Cruz which allows to use the external
vivante kernel module from meta-freescale.
snapd requires squashfs kernel module but this has not been added
to all defconfigs.
Follow commit f0d525d36e915076416a443eb15a69efdcac1e73
or the images which add the snapd packagegroup will not build
Add Linux kernel recipe which patches the Toradex Colibri VF50/VF61
kernel with the 4.4.60-rt73 PREEMPT RT patch set.
Disable the fusing/one-time-programmable driver by default. It
allows to blow fuses which might make the module unusable with
a simple sysfs write...
While at it remove double assignement to 'S'.
To select the kernel use a preferred provider variable in your
configuration files (e.g. local.conf):
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt"
Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com>
Configure Bluetooth to be built as kernel modules by default. This
allows to make use of USB/SDIO based Bluetooth solutions easier.
This kernels are based on the fslc community kernel which in turn are
based on the NXP 4.1.15 released kernels.
They can be used for Apalis iMX6, Colibri iMX6, and Colibri iMX7.
Kernel upgraded to 3.14.52 kernel.
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Auto-load rpmsg/remoteproc modules during boot.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Update defconfig to build rpmsg and remoteproc.
Synchronize defconfig with kernel git.
Resynchronize defconfig with the git tree version:
The audio Codec Machine driver was missing hence the sound card
got not detected by the SAI driver.
