path: root/recipes-kernel
2016-11-21linux-toradex: configure IPv6 SIT driver as moduleApalis_TK1_LinuxImageV2.6.1Beta2_20161122Stefan Agner
SIT tunnels (IPv6 over IPv4) are not often used hence configure the driver as a module. This also gets rid of the extra network interface sit0 by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-10-01colibri-vf: update kernel to latestColibri_iMX7_LinuxImageV2.6.1Beta1_20160929Colibri_iMX6_LinuxImageV2.6.1Beta1_20160929Colibri_VF_LinuxImageV2.6.1Beta1_20161001Apalis_iMX6_LinuxImageV2.6.1Beta1_20160929Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-30colibri-vf: update kernel to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-09-29linux-toradex: Auto-load rpmsg/remoteproc modules during bootSanchayan Maity
Auto-load rpmsg/remoteproc modules during boot. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29colibri_vf: Update defconfig to build rpmsg and remoteprocSanchayan Maity
Update defconfig to build rpmsg and remoteproc. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29linux vf: update to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29colibri-imx7: synchronize defconfigStefan Agner
Synchronize defconfig with kernel git. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29linux imx7: update to latestMax Krummenacher
2016-09-29linux imx6: update to latestMax Krummenacher
2016-06-30linux-toradex: update to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30colibri_vf: fix audio and add L2 switchStefan Agner
Resynchronize defconfig with the git tree version: The audio Codec Machine driver was missing hence the sound card got not detected by the SAI driver. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30linux-toradex: update to latest -nextMax Krummenacher
2016-06-30colibri-imx7: synchronize defconfigStefan Agner
Synchronize defconfig with kernel git. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30colibri-imx7: add kernel 4.1.15 recipeMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-30colibri_vf: update defconfig to enable IIO sysfs triggerSanchayan Maity
While we enable CONFIG_IIO_SYSFS_TRIGGER in kernel source defconfig this is not enabled in defconfig being used in OpenEmbedded. This results in sysfs triggers not being enabled by default in an image build with OpenEmbedded. This is already observed with our last release 2.6 Beta1 image. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-04-11linux-toradex-fsl-rt: Added a real-time kernel recipe for 3.14.52Brandon Shibley
A new i.MX6/i.MX7 real-time 3.14.52 kernel recipe was added with a modified PREEMPT_RT patch to accomodate the backports applied to the Toradex kernel. To select the kernel use a preferred provider variable in your configuration files (e.g. local.conf): PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt" Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-31linux-toradex_3.14.52: autoload USB gadget modulesMax Krummenacher
Use KERNEL_MODULE_AUTOLOAD to load USB gadget support. This is required for libusbg (gadget-import) to work. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30linux-toradex_4.4: update to latest on -nextMax Krummenacher
2016-03-30linux-toradex_3.14.52: update to latest on -next and use also for mx6Max Krummenacher
Update defconfigs and drop picking the defconfig from the kernel sources. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30linux-toradex-fsl-rt: Added a real-time kernel recipeBrandon Shibley
A new i.MX6 real-time kernel recipe was added with a modified PREEMPT_RT patch to accomodate the backports applied to the Toradex kernel. To select the kernel use a preferred provider variable in your configuration files (e.g. local.conf): PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt" Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-30linux-toradex_4.4: autoload USB gadget modulesStefan Agner
Use KERNEL_MODULE_AUTOLOAD to load USB gadget support. This is required for libusbg (gadget-import) to work. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-30linux-toradex_4.1: set local version to V2.6Max Krummenacher
Signed-off--by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30linux-toradex_3.14.28: update to latest and fix branch nameMax Krummenacher
2016-03-14colibri-vf: add linux-toradex_4.4.bbMax Krummenacher
2016-03-14linux-toradex_3.14.28: add bbappend with SRCVER and defconfigMax Krummenacher
2016-03-14linux-toradex: add Linux recipe for Toradex Colibri iMX7Max Krummenacher
This recipe provides a kernel for the Freescale i.MX 7 based module Colibri iMX7. - based on Freescale's BSP release imx_3.14.52_1.1.0_ga release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14linux-firmware: drop bbappend, changes are now in metaMax Krummenacher
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-12-15linux-firmware: backport rtl8192cx: Add latest available firmwareMax Krummenacher
2015-12-15linux-toradex_4.1: update to latest revisionMax Krummenacher
Update to latest revision which contains a SPI bugfix and the latest upstream stable release v4.1.15. Also synchronize the VF defconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15linux-toradex-fsl: update to latest revisionMax Krummenacher
Update to latest revision which fixes Colibri iMX6D not powerering off but creating a stacktrace. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15linux-toradex_4.1: convert recipe to bbappendMax Krummenacher
We have this recipe in meta-fsl-arm-extra. Convert it to a bbappend and only keep the changes to the bb files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15colibri_vf: updated defconfig enables RTL8192CU driverStefan Agner
Enable RTL8192CU driver to support LM006 USB WiFi adapter. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-04Apalis/Colibri iMX6: Update Linux kernel to latestMax Krummenacher
2015-11-04linux: fix B != SMarcel Ziswiler
2015-11-04apalis/colibri_imx6/t20/t30: add version/git hash to KernelStefan Agner
Add LOCALVERSION and generate a scmversion file to annotate the Kernel with the Toradex release and a git hash.
2015-11-04apalis/colibri_imx6: update/load USB Gadget ConfigFS automaticallyStefan Agner
Since we use USB Gadget ConfigFS now use libusbg to load the USB Gadget configuration automatically.
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-21colibri_vf: update/load USB Gadget ConfigFS automaticallyStefan Agner
Update defconfig and kernel version to latest version from git. This also configures the USB Gadget ConfigFS as a module. Add the ConfigFS module to the list of autoloaded modules.
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-10-12apalis-imx6: update kernel to toradex_imx_3.14.28_1.0.0_ga-nextMax Krummenacher
2015-08-13colibri-vf: initial kernel based on upstream 4.1Max Krummenacher
2015-08-07kernel: adapt to oe's new shared work dirMax Krummenacher
2015-08-07colibri-vf: moved to meta-fsl-arm, remove hereMax Krummenacher
2015-06-03colibri_vf: enable SCSI disk required for USB mass storageStefan Agner
SCSI lock device disk support is required for USB mass storage to work. Also enable asynchronous SCSI scanning by default.
2015-05-29mcc-kmod: fix revision to build with kernel revision usedStefan Agner
Use a fixed revision of the MCC kernel module which makes sure it builds with the corresponding Vybrid Linux kernel, which also uses a fixed git hash.
2015-05-18Apalis/Colibri iMX6: use toradex_imx_3.10.17_1.0.0_ga branchMax Krummenacher
2015-05-18Colibri VF: use latest from toradex_vf_4.0 branchMax Krummenacher
2015-05-18Apalis/Colibri iMX6: update kernel to latest in -nextMax Krummenacher
2015-05-12recipes-kernel: remove orphaned 3.17 defconfigMax Krummenacher
