Fixes: 3560660 linux-toradex: synchronise defconfigs
Related-to: ELB-2510
Basically, as per the following commit from the
toradex_4.14-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git
ab66d6c48c8e78e74ebbf41505db65b0830e6fd7
ARM: apalis/colibri-imx6/7/6ull: enable options for backports
8d6cc5a3e9a2cf349c4d42e13c4449f16512651e
ARM: apalis/colibri-imx6/7/6ull: disable wireless drivers
c666f52447fa426fdc414bb1c922d89969f25385
arm64: defconfig: enable options required for backports
d55c4e1ff7f1a6b23908d45bfec48b2c717d13fe
arm64: defconfig: disable wireless drivers
Related-to: ELB-2687
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
19a90652d70208c755d3339e21f6bfc8cae04b82:
ARM: apalis/colibri: defconfig: remove backported drivers
76b17e9c0b6f0245dc76c59062257bea2d0d6a0f:
arm64: apalis/colibri: defconfig: remove backported drivers
Related-to: ELB-2388
Resync with latest configs in the kernel, but switch on PREEMPT_RT_FULL.
Final synchronization with the commit from the toradex_4.14-2.3.x-imx
branch on git://git.toradex.com/linux-toradex.git:
25c008952d3a61c9c402126d4ba7424ef8132f90
arm64: defconfig: further config clean-up
Basically, as per the following commit from the toradex_4.14-2.3.x-imx
b1df9c77a53e92dc6b993007e3d8bb1f3cc61bf6:
colibri imx6ull: defconfig: enable building backports-5.4
Basically, as per the following two commits from the
ad4d419f1b24e1d986e2fe956c1f3ca7d1eab93f:
apalis/colibri_imx6/-imx6ull/_imx7/-imx8/8x_defconfig: config refresh
Related-to: ELB-2351
This provides headers unique to the NXP downstream kernel.
Since linux-toradex is rebased onto NXP's downstream kernel the needed
git hash is also part of our linux-toradex git and we can save the
download of a second kernel git repo.
u-boot-toradex-common.inc: all but below
u-boot-toradex-common_2018.03.inc: i.MX 8 series based modules
u-boot-toradex_2016.11.bbappend: Toradex Easy Installer 2.0
linux-toradex_4.14-2.0.x.bb: all NXP based modules
Resync with the defconfigs from the kernel repository. This adds:
- fix ip firewall (bpf/cgroup)
- Revert "arm64: defconfig: Choose the newer version of the ov5640 driver"
- enable USB WiFi adapter.
Related-to: #58517
Resync with the defconfig from the kernel repository. This adds:
Related-to: #32198
Synchronise with kernel defconfig
- add USB HID raw support
- enable ext4 file system security support
(cherry picked from commit 557a0e42badba143a8c0b3b0ef0eb1d4ebb5ee10)
- enable USB-to-serial adapters
- add load edid support
Related-to: #57567
(cherry picked from commit b103c379c216b5e370e7702b3e586e81c38625bb)
Enable zram which is useful for compressed swap space in memory. This is
especially useful on embedded devices where swap space on a block device
is not typically enabled (to avoid flash wear).
Resync with kernel defconfig, this includes:
- defconfig: fix delayed mxt loading
- defconfig: fix ip firewall (bpf/cgroup)
The RT project moves the patches into an 'older' directory once superseeded
by a newer patch.
Provide both download paths to cope with the changing location.
While at it use the OE maintained KERNELORG_MIRROR variable to specify the path.
Update rt kernel recipe to use the linux-toradex_4.14-2.0.x kernel.
Re-sync defconfig which enables emulation for deprecated instructions
in ARMv8 for AArch32, enables CAN MCP251X driver, enables a generic
LVDS panel driver and disables CAAM Keystore test driver.
Re-sync defconfig e.g. taking the following dumb-vga-dac idrm bridge
enablement into account:
http://git.toradex.com/cgit/linux-toradex.git/commit/?id=551ce056fd0cd91ae8237d1517469bc1b0f4366f
Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
