The gstreamer based package rdepend on gstreamer components so add
the relevant RDEPEND for these packages.
Silence warnings which can not be avoided with the binary distibuted files.
The Vybrid xorg.conf should not be part of the Tegra BSP.
While at it move the bbappend and xorg.conf under jetson-tk1 so that
one only needs meta-jetson-tk1 when one builds for tk1.
Disabling LVDS output by default has issue with pcmanfm consuming 100% CPU if
HDMI is inactive. So to make sure HDMI is set as primiary display and to address
the issue with pcmanfm, configure LVDS in extended mode by default so that if
HDMI is not active LVDS will be on atleast.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The base_contains function is deprecated and we ought to use
bb.utils.contains instead.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
With the split of meta-toradex we removed the binary blobs of the
Tegra driver- and codec packages.
This changes the recipe to download the files.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
Disable LVDS output in favour of primary HDMI one on Apalis TK1.
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and
remove /${bindir}/ which would need escaping.
And while at it replace Apalis-T30 in summary with Apalis T30 and get
rid of PR and empty do_compile.
while at it move both to machine arch to reduce rebuilds.
linux-toradex.inc's functionality is provided with linux-dtb.inc for current
device tree enabled kernels. So don't include both include files.
Prevents
ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list]
This is only used for choosing a custom logo size. Not needed in our
use case.
meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc
Note: Currently only compiles -native but fails compiling for target!
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
Address the following warnings:
WARNING: QA Issue: nvsamples rdepends on libice, but it isn't a build dependency? [build-deps]
WARNING: QA Issue: nvsamples rdepends on libsm, but it isn't a build dependency? [build-deps]
We want to append to the generic VAR when we build for a tegra machine.
Using VAR_tegra += "" creates a machine specific VAR.
