In our images this has been done during do_rootfs and friends,
do it the oe-core way.
While at it clean-up and unify with other Toradex layers.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
Unsetting KEEPUIMAGE requests that vmlinux is built and later manually
packed into a uImage.
The resulting uImage in morty now packeges a gz compressed kernel in favour of
the uImage compression. Our U-Boot is not configured to boot such a uImage.
So keep the default setting for KEEPUIMAGE.
However the deploy logic for device tree-files can not cope with this
and prefixes the device-tree files with vmlinux and not uImage as expected.
The base_contains function is deprecated and we ought to use
bb.utils.contains instead.
This is only used for choosing a custom logo size. Not needed in our
use case.
meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Change DEFAULTTUNE in machine configurations to Thumb-2.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
Include the NVIDIA binaries as soon as X11 is in distribution
features. This allows to use the hardware accelerated X11 DDX
driver "tegra" even when OpenGL is not selected by the image.
Consolidate Tegra specific machine configuration in a common
tegra-base.inc file.
Since the boot loader requires a kernel-image in /boot, add the
kernel-image to MACHINE_ESSENTIAL_EXTRA_RDEPENDS. This allows to
boot images which do not select packagegroup-boot by default such
as the Poky reference distribution images.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Update to a U-Boot and Kernel which can be used for Apalis iMX6
HW version V1.0 and V1.1.
Also deploy additional device tree for Apalis iMX6 V1.0 modules
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
Angstrom default on armv7a would be thumb2, however there are some
recipes around with arm assembler which fails.
If the package manager finds a version newer than the prefered-version that one
gets installed. As we need a specific one for the tegras and for imx6 we
change the 'epoch' to something very high.
unify the features between machines
kernel26 is deprecated and unused
apm does not make sense on ARM
While at it remove some commented stuff
Be consistent with the other machine recipes
Help the autobuilder setup
File now provided by openembedded-core
This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419.
EGL, OpenGL ES1.1 and OpenGL ES2.0 provided in binary form.
virtual/bootloader is a commonly used target. This patch
adds it for meta-fsl-arm machines.
Other BSP layers have this provider and when using a mutli-machine
distro setup bitbake virtual/bootloader
builds a wrong u-boot for fsl machines
The patch was imported from the meta-arm-fsl git server
(https://github.com/Freescale/meta-fsl-arm/commit/93b3d7dd7cdbbc0a49394cc32d335fb85fd2da74)
and adapted to our machines.
remove the files copied from meta-fsl* for Colibri-VF V2.1
move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
- Colibri T30 and Apalis T30 changed to NEON
- Colibri VF50 changed to hard float
This makes packages built for T30 incompatible with Colibri T20
(but Colibri T20 packages can still be used on T30)
remove when moving to dora branch
revert when moving to dora
- also add the relevant configuration files
