path: root/recipes-bsp/u-boot/u-boot-toradex_git.bb
2019-07-10u-boot-toradex: update to 2019.07 basedMax Krummenacher
Update to a 2019.07 based U-Boot. Use the openembedded master recipes for u-boot_2019.07 as a base. While at it append -tk1 to PN to have a name different from the u-boot recipe name for our NXP based SoM and set the prefered provider accordingly. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-24linux kernel & u-boot recipes: update to latestMarcel Ziswiler
Update linux-toradex-mainline to 4.14.109. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit d4511e4a45392799ae157c6632f3944981787c02) Conflicts: recipes-kernel/linux/linux-toradex_git.bb
2019-03-06u-boot-toradex: drop include tdx_version.confMax Krummenacher
Variables from tdx_version.conf are now provided by the distro. Add defaults in case someone doesn't use our distro. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06apalis/colibri-t20 -t30: drop machinesMax Krummenacher
These machines use an old Nvidia provided downstream kernel 3.1.10. They are no longer compatible with more recent sysroot components, e.g. libc, xserver et. al. The maintenance burden to keep the userspace components in their old version becomes simply too high. Keep using the rocko based 2.8 BSP for these machines. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06u-boot: fix build error with dtc headers in sysrootMax Krummenacher
...recipe-sysroot-native/usr/include/libfdt_env.h:70:30: error: conflicting types for 'fdt64_t' typedef uint64_t FDT_BITWISE fdt64_t; ^~~~~~~ In file included from <command-line>:0:0: ...git/include/libfdt_env.h:19:16: note: previous declaration of 'fdt64_t' was here typedef __be64 fdt64_t; ^~~~~~~ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06Revert "u-boot: fix build error with dtc headers in sysroot"Max Krummenacher
This reverts commit 8f9fb0502e052276bdb4d349af5e652e193543ff.
2018-12-27linux kernel & u-boot recipes: update to latestColibri-T30_LXDE-Image_2.8b5.156-20181228Colibri-T20_LXDE-Image_2.8b5.156-20181228Apalis-TK1_LXDE-Image_2.8b5.156-20181228Apalis-TK1-Mainline_LXDE-Image_2.8b5.156-20181228Apalis-T30_LXDE-Image_2.8b5.156-20181228Marcel Ziswiler
Update linux-toradex-mainline to 4.14.90. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
2018-09-28linux kernel & u-boot recipes: update to latestMarcel Ziswiler
Update linux-toradex-mainline to 4.14.72. While at it drop obsolete linux-toradex-mainline 4.9 recipe. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2018-06-22linux kernel & u-boot recipes: update to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-06-18u-boot-toradex: apalis-t30: generate cbootimageMarcel Ziswiler
Generate cbootimage already during build as required for Toradex Easy Installer BSP package. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-29linux kernel & u-boot recipes: update to latestMarcel Ziswiler
2018-03-29u-boot-toradex: include U-Boot default environmentStefan Agner
Include u-boot-toradex-env.inc will generate a uEnv.txt text file containing the default environment of the U-Boot binary. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-28linux kernel & u-boot recipes: update to latestColibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-TK1_LXDE-Image_2.8b1.64-20171229Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229Marcel Ziswiler
2017-12-20recipes: follow version variable changeMax Krummenacher
We changed the version variables in meta-toradex-bsp-common/conf/tdx_version.conf Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-20u-boot: unify use of pv/prMax Krummenacher
2017-11-29u-boot recipes: update to latestMarcel Ziswiler
2017-11-29u-boot-toradex: move binary, image and symlink to machine configurationMarcel Ziswiler
Move UBOOT_BINARY, UBOOT_IMAGE and UBOOT_SYMLINK definitions to machine configuration re-used by the Toradex Easy Installer U-Boot recipe. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29u-boot recipes: automatically update to latest -next through overrideMax Krummenacher
This can be used e.g. for a CI setup to do nightly builds of latest and greatest. To use HEAD of xxx-next instead of the pinned version one would add in local.conf: MACHINEOVERRIDES =. "use-head-next:" Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-05u-boot-toradex: apalis-tk1/apalis-tk1-mainline: generate cbootimageMarcel Ziswiler
Generate cbootimage already during build as required for Toradex Easy Installer BSP package. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-10-05u-boot recipes: update to latestMarcel Ziswiler
2017-06-30u-boot: update to latestMarcel Ziswiler
2017-04-10apalis/colibri-t20/t30/tk1: u-boot: new version plus git hashMarcel Ziswiler
Use the new version variables plus the git hash. Inspired by meta-freescale/classes/fsl-u-boot-localversion.bbclass. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-04-10u-boot: update to latestMax Krummenacher
2017-04-07u-boot: use the new version variablesMax Krummenacher
2017-04-07meta-toradex-tegra: cleanup whitespace useMax Krummenacher
2017-04-07u-boot: update to latest -nextMax Krummenacher
2017-01-11u-boot: update to latestColibri_T30_LinuxImageV2.7Beta1_20170112Colibri_T20_LinuxImageV2.7Beta1_20170112Apalis_TK1_LinuxImageV2.7Beta1_20170112Apalis_T30_LinuxImageV2.7Beta1_20170112Max Krummenacher
2017-01-11u-boot/kernel: update version string to 2.7Max Krummenacher
While at it consistently use a lower case 'v' as with U-Boot and kernel in meta-toradex-nxp. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11u-boot: upgrade to 2016.11 based versionMax Krummenacher
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-11-22u-boot: tk1: update to include changes for v1.1 modulesMax Krummenacher
2016-09-29u-boot: update to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-30u-boot: integrate apalis-tk1Marcel Ziswiler
2016-06-30u-boot, u-boot-fw-utils: update to latestStefan Agner
The upgrade is required to match to the latest update scripts which deploy the kernel and device tree into static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-31u-boot: update to latest from 2015.04-toradex-nextMarcel Ziswiler
2016-03-30u-boot tegra: update to latest -nextMax Krummenacher
2015-12-15Update all U-Boot versions to latestMax Krummenacher
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-30apalis/colibri_t20/t30: u-boot/fw-utils: introduce srcbranch notationMarcel Ziswiler
Introduce SRCBRANCH notation for easier switching to our -next branch.
2015-08-07u-boot-toradex_git: add virtual/bootloader to PROVIDESMax Krummenacher
2015-08-07u-boot: remove obsolete overridesMax Krummenacher
2015-05-18Apalis/Colibri: update U-Boot to latestMax Krummenacher
And use 2015.04-toradex branch
2015-05-18Apalis/Colibri: update U-Boot to latest in -nextMax Krummenacher
2015-05-12update to latest u-bootMax Krummenacher
2015-05-12update U-Boot and Colibri VFxx Linux to latest git revisionStefan Agner
2015-05-12update to latest u-bootMarcel Ziswiler
2015-05-12u-boot: use latest from gitMax Krummenacher
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils.
2015-05-12apalis/colibri_t20/t30: integrate latest stuffMarcel Ziswiler
2014-12-19u-boot/u-boot-fw-utils: update all to latestMax Krummenacher
2014-12-18Update all to latest and greatest U-Boot and Linux kernel.Marcel Ziswiler
