Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
While at it append -tk1 to PN to have a name different from the u-boot recipe
name for our NXP based SoM and set the prefered provider accordingly.
Update linux-toradex-mainline to 4.14.109.
(cherry picked from commit d4511e4a45392799ae157c6632f3944981787c02)
recipes-kernel/linux/linux-toradex_git.bb
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone doesn't use our distro.
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
cc1: error: -mfloat-abi=hard: selected processor lacks an FPU
...recipe-sysroot-native/usr/include/libfdt_env.h:70:30: error: conflicting types for 'fdt64_t'
typedef uint64_t FDT_BITWISE fdt64_t;
In file included from <command-line>:0:0:
...git/include/libfdt_env.h:19:16: note: previous declaration of 'fdt64_t' was here
typedef __be64 fdt64_t;
This reverts commit 8f9fb0502e052276bdb4d349af5e652e193543ff.
Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Generate cbootimage already during build as required for Toradex Easy
Installer BSP package.
The eMMC unlocking was missing which lead to the following error
message:
Write error on /dev/mmcblk0boot0: Operation not permitted
Error: can't write fw_env to flash
Include u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
No functional change intended.
The U-Boot Makefile has a unusual way of compiling the user space tools which
results in the wrong toolchain (native vs. target) being used.
Drop our downstream fix in favour of how openembedded-core does this now.
Move UBOOT_BINARY, UBOOT_IMAGE and UBOOT_SYMLINK definitions to machine
configuration re-used by the Toradex Easy Installer U-Boot recipe.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
Use the new version variables plus the git hash. Inspired by
meta-freescale/classes/fsl-u-boot-localversion.bbclass.
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
fix errors due to missing uint* types.
Move to u-boot git.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
