Turns out our build was using the library from the build machine which
at least on Fedora 23 seems broken.
Update to latest from git in order to have support for
--usb-timeout= parameter.
The OpenMAX_IL headers archive has been updated resulting in a
changed checksum.
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
TK1 silence warning for hash-style not gnu
Allow debug package, as for TK1 we have an unstripped binary
Add to RDEPENDS for tegrastats-gtk
WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libatk-1.0.so.0... [file-rdeps]
WARNING: tegrastats-1.0-r3 ...tegrastats: Files/directories were installed but not shipped in any package:
WARNING: tegrastats-1.0-r3 ...No GNU_HASH in the elf binary: '...packages-split/tegrastats/usr/bin/tegrastats' [ldflags]
WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libpangocairo-1.0.so.0... [file-rdeps]
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
fix errors due to missing uint* types.
Move to u-boot git.
While at it move the bbappend and xorg.conf under jetson-tk1 so that
one only needs meta-jetson-tk1 when one builds for tk1.
Disabling LVDS output by default has issue with pcmanfm consuming 100% CPU if
HDMI is inactive. So to make sure HDMI is set as primiary display and to address
the issue with pcmanfm, configure LVDS in extended mode by default so that if
HDMI is not active LVDS will be on atleast.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
With the split of meta-toradex we removed the binary blobs of the
Tegra driver- and codec packages.
This changes the recipe to download the files.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
Disable LVDS output in favour of primary HDMI one on Apalis TK1.
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and
remove /${bindir}/ which would need escaping.
And while at it replace Apalis-T30 in summary with Apalis T30 and get
rid of PR and empty do_compile.
Note: Currently only compiles -native but fails compiling for target!
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
Introduce SRCBRANCH notation for easier switching to our -next branch.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
And use 2015.04-toradex branch
