PREFERRED_PROVIDER_u-boot should be 'u-boot-toradex-tk1' instead of
'u-boot-toradex', also set PROVIDES += "u-boot" in u-boot-tk1 recipe.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
They are not needed any more since we upgraded to 2019.07.
Rename the apalis-tk1-mainline machine to the now dropped
apalis-tk1 machine name.
Related-to: ELB-2733
The downstream kernel gets to old to be used with the new zeus
userspace components. Drop the machine.
That's not necessary since nativepython is a symbolic link pointing to
python binary in ${STAGING_BINDIR_NATIVE}/python-native.
Related-to: ELB-2510
(cherry picked from commit 7880c26275385d30ce2d7d6c45065764e0fd2472)
(cherry picked from commit 47541b793939763acca3c43d13761e4cdac6db05)
(cherry picked from commit 9625a9d01efe7e3bd9c2590a275e13a6652c946f)
Debugging reveals that it is really also expecting certain firmware at
the original path:
[ 134.878913] firmware tegra12x!vic03_ucode.bin: firmware: requesting tegra12x/vic03_ucode.bin
So make a symbolic link rather then copying them.
Without older systemd's firmware usermode helper fallback in place using
an alternative file name leads to a very long timeout. Fix this by
linking the alternative nameed firmware to the one tried first.
(cherry picked from commit 5d206eb3265bc6bc96442ffcd1cc4ce1f80f0714)
For the TK1 U-Boot this fails to build on master where Python 2 is no
longer available, but it also fails on zeus where we still can use Python 2.
So revert for zeus.
This reverts commit 691b4469b3cf94273514f2f41563ab608120643b.
OE dropped python2 support.
Unify u-boot.inc with openembedded-core which now uses python3 for the build.
(cherry picked from commit 8d3d527425b592480900d006c76694877755486a)
recipes-kernel/linux/linux-toradex-mainline_4.14.bb
recipes-kernel/linux/linux-toradex_3.10.40.bb
Use toradex-u-boot-localversion class to implement the new versioning
scheme for U-Boot.
Otherwise the picked u-boot.inc file depends on the bblayers variable.
Recent OE adds additional shared object checks which errors out on the way
the binary Tegra drivers are injected.
Rework the recipes, so that
- mesa no longer PROVIDE any OpenGL shared objects and the binaries.
- linux-driver-package now depends on mesa to install development headers
- linux-driver-package PROVIDE and RPROVIDE the OpenGL shared objects.
- linux-driver-package drops the additional arm-linux-gnueabihf/tegra path
to the *.so* files.
- the apalis-tk1 machine PREFERS linux-driver-package as the OpenGL provider.
While at it unify whitespace usage.
This commit does not change any configuration or behaviour, it prepares
for a rework of the recipe.
The gstreamer plugins now require addional runtime depends or one gets
qa errors of the following form:
| ERROR: linux-driver-package-21.7.0-r7 do_package_qa: QA Issue: /usr/bin/nvgstplayer-1.0 contained in package linux-driver-package-nvgstapps
| requires libgstvideo-1.0.so.0, but no providers found in RDEPENDS_linux-driver-package-nvgstapps? [file-rdeps]
meta-openembedded dropped gstreamer 0.10 with commit 010c2f388.
There is not a generic license called
"FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT", drop it, use
"CLOSED" instead, this fixes a following QA warning:
| tdx-k20-fw: No generic license file exists for: FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT in any provider
Also remove a relative path reference in LIC_FILES_CHKSUM.
commit 8691ba636cb2 allowed to also use SysV init. However, if only systemd
is configured in DISTRO_FEATURES the content of /etc/init.d is deleted
after the install step. This results in the scripts nv and nvfb not being
present.
Fix this by installing them additionally in /usr/bin so that the systemd
service can call them.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
While at it append -tk1 to PN to have a name different from the u-boot recipe
name for our NXP based SoM and set the prefered provider accordingly.
Assign the systemd service in the package providing them.
Prevents the following do_rootfs error if linux-driver-package is installed
but linux-driver-package-*boot is not:
| WARNING: linux-driver-package.postinst returned 1, marking as unpacked only, configuration required on target.
| ERROR: Postinstall scriptlets of ['linux-driver-package'] have failed. If the intention is to defer them to first boot,
| then please place them into pkg_postinst_ontarget_${PN} ().
This is caused by sytemctl trying to enable the not existing services nv.service and nvfb.service.
Update linux-toradex-mainline to 4.14.109.
(cherry picked from commit d4511e4a45392799ae157c6632f3944981787c02)
recipes-kernel/linux/linux-toradex_git.bb
(cherry picked from commit 0f59e154bfebd18f4f9eb11a31912ad5cb7e0c93)
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone doesn't use our distro.
All of meta-jetson-tk1 has been moved into meta-toradex-tegra as updates
were needed. Drop meta-jetson-tk1.
Remove comment which was obsoleted by commit
b34fa66b4159cb6b0952a6821e73fdb93ae7714f
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
prevents warning:
| Applying patch 0001-configure.ac-link-crypotpp-as-a-static-library.patch
| patching file configure.ac
| Hunk #1 succeeded at 20 with fuzz 1.
cc1: error: -mfloat-abi=hard: selected processor lacks an FPU
...recipe-sysroot-native/usr/include/libfdt_env.h:70:30: error: conflicting types for 'fdt64_t'
typedef uint64_t FDT_BITWISE fdt64_t;
In file included from <command-line>:0:0:
...git/include/libfdt_env.h:19:16: note: previous declaration of 'fdt64_t' was here
typedef __be64 fdt64_t;
This reverts commit 8f9fb0502e052276bdb4d349af5e652e193543ff.
Now with 10.1 inch displays soon being available make those settings the
default. Note that one still needs to set vidargs properly e.g. from
within U-Boot as follows:
Apalis T30 # setenv vidargs 'video=tegrafb0:1280x800-16@60 fbcon=map:1'
Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Add a script to the lvds-ctrl recipe for setting the correct mode for
10.1" display
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Enforcing to build 32-bit binaries for native and portions thereof
using -m32 in EXTRA_OEMAKE_class-native may lead to building errors.
Also, it seems it's time to move on from 32-bit compatibility.
Affected repositories:
meta-toradex-demos
meta-toradex-nxp
meta-toradex-tegra
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
