2019-03-06 | apalis/colibri-t20 -t30: drop machines | Max Krummenacher | |
These machines use an old Nvidia provided downstream kernel 3.1.10. They are no longer compatible with more recent sysroot components, e.g. libc, xserver et. al. The maintenance burden to keep the userspace components in their old version becomes simply too high. Keep using the rocko based 2.8 BSP for these machines. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2017-04-10 | hdmi-hotplug: fix issue for the apalis/colibri tegra modules | Leonardo Graboski Veiga | |
The hdmi.sh script, triggered by udev, export the DISPLAY environment variable and uses the Xauthority configuration file to enable xrandr to run. Also restarts LXDE after xrandr, adjusting the taskbar length to the new display width. Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> |
