path: root/recipes-core/hdmi-hotplug
2017-04-10hdmi-hotplug: fix issue for the apalis/colibri tegra modulesLeonardo Graboski Veiga
The hdmi.sh script, triggered by udev, export the DISPLAY environment variable and uses the Xauthority configuration file to enable xrandr to run. Also restarts LXDE after xrandr, adjusting the taskbar length to the new display width. Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07meta-toradex-tegra: cleanup whitespace useMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07recipes: remove unneeded RDEPENDSMax Krummenacher
The 'rdepending' packages are picked up automatically by the buildsystem. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29apalis-tk1: hdmi: add udev rule to start an X output on hotplugMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2014-08-04recipes-core/hdmi-hotplug/hdmi-hotplug.bbMax Krummenacher
2013-10-21hdmi: add udev rule to start an X output on hotplugMax Krummenacher
