While at it remove version from recipe directory.
The hdmi.sh script, triggered by udev, export the DISPLAY environment
variable and uses the Xauthority configuration file to enable xrandr to
run.
Also restarts LXDE after xrandr, adjusting the taskbar length to the new
display width.
Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com>
The read_ahead configuration is now set using udev. The script run from udev
was added to meta-toradex-bsp-common, since it applies to all modules with
eMMC.
The 'rdepending' packages are picked up automatically by the
buildsystem.
Systemd startup script for NVIDIA T30 CPU hot-plug configuration.
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10.
Remove the backport, is part of fido.
Angstom Dizzy now uses systemd V218 so there is no need to build
a component seperately anymore.
This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4.
This changes the minimum required Linux version from 3.7 back to 3.0.
[YOCTO #7409]
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
backported from openembedded-core,
commit 31163abc7bedd477c1aad10e6d1f47dbee194513
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c.
recipes-core/systemd/systemd_%.bbappend
When the link goes down, the DHCP service has been disabled, while
there is no corresponding functionality which enables the service
when the link goes up again. This fix is taken from systemd 217.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
Patch pending in meta-angstrom
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
Add the fstrim utility to Colibri T30 image. The utility allows to
send trim commands to the underlaying flash translation layer, which
allows too free not used flash sectors and those improve wear-
leveling
