0001-gallium-add-renderonly-library.patch:
added upstream
0004-gallium-add-tegra-support.patch, 0008-remove-dependency-on-libdrm_tegra.patch
fix patch conflicts
While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend.
reorder assignments to be similar between tegra, tegra124, tegra124m
remove unneeded COMPATIBLE_MACHINE assignement.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
Moving from patching the "*.pc" files to patching there "*.pc.in" files
should hopefully make the patch more independent of the mesa version.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
