While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend.
- add the original xserver-xorg.inc which matched the 1.14.4 recipe as the
current one is no longer compatible with the older xserver.
- renamed to xserver-xorg-1.14.7.inc
- merge in OE specific changes from current xserver-xorg,inc.
- merge bbappend into the bb file, we are the only user of this recipe.
- set the compatible machine to SOC-Family rather than specific machines.
reorder assignments to be similar between tegra, tegra124, tegra124m
remove unneeded COMPATIBLE_MACHINE assignement.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
Moving from patching the "*.pc" files to patching there "*.pc.in" files
should hopefully make the patch more independent of the mesa version.
With the update 'xf86-input-evdev: Upgrade 2.9.2 -> 2.10.0' this file is
provided by the evdev recipe.
The Vybrid xorg.conf should not be part of the Tegra BSP.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
We want to append to the generic VAR when we build for a tegra machine.
Using VAR_tegra += "" creates a machine specific VAR.
Upstream has already fixed the GCC 5 problem, so use the patch from upstream.
Signed-off-by: Ross Burton <ross.burton@intel.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Backport a patch from fedora details are in patch header
Change-Id: I6b8dfaae3b751071bf8b0d88b15a4f95c19877f6
Signed-off-by: Khem Raj <raj.khem@gmail.com>
The evdev version provided by oe-core is in the meantime newer than
this backport, hence we can safely remove it.
gpu-viv-bin-mx6q -> imx-gpu-viv
with a bunch of subpackages.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
while at it remove the xserver-xorg.inc file in favour of the identical
inc file in the openembedded-core layer.
Upgrading to 1.14.7 fixes the broken X server rotation issue seen on
Apalis/Colibri T20/T30 as noted on our developer website:
http://developer.toradex.com/software-resources/arm-family/linux/linux/
release-details?view=all&issue=9562
This is an upgrade from the former 1.14.4 recipe as found here:
http://cgit.openembedded.org/openembedded-core/tree/meta/
recipes-graphics/xorg-xserver?id=
b8feee3cf21f70ba4ec3b822d2f596d4fc02a292
HACK: during do_rootfs opkg takes the latest and greatest available
in any feed, e.g. one built for another machine without prefered version
rather than what PREFERRED_VERSION puts in the MACHINE_ARCH feed
so we set the recipe epoch here. Thus for our architecture we're
always latest and greatest.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
The tegras xdrivers require an 1.14 API
Make the xserver ARCH specific
adds gpu-viv-bin-mx6q-libraries package which RDEPENDS only the
libraries but not the samples.
V2.7.3 crash when it receives multitouch events
With the propriatry GPU driver, some text is not rendered.
e.g. like in this report
http://slopjong.de/2012/11/19/problem-with-font-rendering/
-> revert the relevant patch
