Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Corrects reset and irq pins for capacitive touch for Aster carrier board.
Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>aödf
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Unfortunately, perf fails building in rocko since this oe-core commit:
commit 6f9117c0bceeedbfce08647825edf86966457bfc
Author: Hongxu Jia <hongxu.jia@windriver.com>
Date: Tue Apr 24 11:33:47 2018 +0800
perf: make a copy of kernel source to perf workdir
Unfortunately perf in such obsolete kernels is not yet as nicely
separated therefore just copy over some more stuff for it to compile
again.
Latest additions:
- 0024-apalis_t30-enable-broken-hpi-on-emmc.patch
Avoid a rare soft lockup upon installing an image from within Tezi.
- 0025-tegra_defconfig-disable-sound-in-tezi-configuration.patch
Avoid keyboard/mouse being unresponsive for 10-15 Seconds.
- 0026-apalis_t30-fix-mmc1-cmd-pull-up.patch
Avoid issues with higher speed SD cards.
- 0027-apalis_t30-pull-up-sd-card-detect-pins.patch
Avoid floating SD card detect pins.
- 0028-Revert-mmc-tegra-Disable-UHS-I-modes-for-Tegra124.patch
Allow for UHS-I modes on TK1.
- 0029-mmc-tegra-fix-eMMC-DDR-mode.patch
Fix eMMC DDR mode.
- 0030-apalis-tk1-enable-ddr52-mode-on-emmc.patch
Enable eMMC DDR mode.
- 0031-apalis-tk1-force-fixed-ids-for-sdmmc-controllers.patch
Avoid re-ordering of SDMMC controller instances.
- 0032-apalis-tk1-fix-pcie-reset-for-reliable-gigabit-ether.patch
Fix PCIe gigabit bring-up issue on Apalis TK1.
Drop commit c35b518f9ba0 ("clk: tegra: Fix pll_u rate configuration")
which meanwhile got merged into stable.
Add the following patches:
- apalis-t30/tk1-mainline: igb: avoid nvm checksum failure
- apalis_t30: fix can2
- mfd: as3722: disable auto power on when AC OK
Update to NVIDIA's latest Linux for Tegra aka L4T R21.7:
https://developer.nvidia.com/linux-tegra-r217
The following libraries got updated:
4094b811241593224a89a5020e0bef7a08914dea */usr/lib/arm-linux-gnueabihf/tegra/libglx.so
157e8271ba925d1dc7405c4ebaad1b8b8b3f1312 */usr/lib/xorg/modules/drivers/nvidia_drv.so
c1d9de2b619110534437850335c06408648e263b */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so
2a712cc736f0cfc694e1ae44603bb1c95fc0873e */usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so
25514ded098387ac0260586392308144d6e659fa */usr/lib/arm-linux-gnueabihf/tegra/libnvmm_camera_v3.so
4c2528fa906e1ff8702a9e1cad2b63d261bd2c16 */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_query.so
28ace2c204408e58444497f7fc32a7f6852f98a9 */usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so
4094b811241593224a89a5020e0bef7a08914dea */usr/lib/xorg/modules/extensions/libglx.so
Move the USB device aka gadget fix from Tezi to here.
Add patches to force fixed IDs for SDMMC controllers.
Add patch to fix for PLL_U rate configuration (T30).
Add Apalis T30 specific patch for PCIe fix hacks.
Some patches meanwhile got accepted mainline. Backport those
patches.
Integrate Thierry's fbdev mmap fix allowing legacy applications that use
the mmap() syscall on the fbdev device to map framebuffer memory without
causing a hang. Useful e.g. for Tezi.
While at it also update to 4.14.30.
This reverts commit deec4d3c6702cddd23b572790f8b1728761ff6a2.
While at it also update to 4.14.29.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
The Device Tree support is now handled by the kernel class. This patch
removes the inclusion of linux-dtb.inc from the kernel recipes in this
layer.
Update to latest Linux LTS 4.14.
Update to NVIDIA's latest Linux for Tegra aka L4T R21.6:
https://developer.nvidia.com/linux-tegra-r216
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/xorg/modules/extensions/libglx.so
7fdf08dac2661c78aa13d72caa205660435a0591 */usr/lib/xorg/modules/drivers/nvidia_drv.so
61fe4c3e02eee124a0b50e0d2f616701c3093da8 */usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/arm-linux-gnueabihf/tegra/libglx.so
06ff56f0001e07b9e5271e5d1c8ee78a0ddd299d */usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so
abdccb24f89f1f0e482524569f9b6364c1fff0a9 */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so
3e9b93e4e3bf24980d025917d694e1f23147837f */usr/lib/arm-linux-gnueabihf/tegra/libnvmm_camera_v3.so
1ee7838597bd9a351b4e241ba947b55d8b4419db */usr/lib/arm-linux-gnueabihf/tegra/libnvparser.so
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
greatest.
in local.conf:
DDC/EDID detection was failing on Apalis TK1 V1.2A on Ixora.
Update to latest Linux LTS 4.9.52, add V1.2 hardware support and prepare
for optional CI top of linux-stable 4.9.y branch builds.
Prepare for snapd integration.
Use the d.*Var variant instead.
pushd and popd are not posix compliant.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
