2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-09 | xserver: remove bbappend for version 1.11.2 | Max Krummenacher | |
2013-10-07 | tegrastats: add --once, --help options | Max Krummenacher | |
2013-09-22 | tegrastats: remove dependency on gtk for cmdline tool | Max Krummenacher | |
2013-09-22 | trdx-nv-binaries: fix khronos checksum changes | Max Krummenacher | |
while at it add PROVIDES for EGL, GLES 1.1, 2.0 use SOC FAMILY to simplify recipe | |||
2013-09-22 | xserver: update to version 14, remove pixman_glyph_cache | Max Krummenacher | |
With the propriatry GPU driver, some text is not rendered. e.g. like in this report http://slopjong.de/2012/11/19/problem-with-font-rendering/ -> remvert the relevant patch | |||
2013-09-22 | inhibit missing debug info warnings in binary package | Max Krummenacher | |
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | libxi: provide dummy recipe - libxi.bbappend in a layer breaks build | Max Krummenacher | |
2013-09-22 | nv-binaries: oe-core required changes | Max Krummenacher | |
- xserver driver api now at version 13 - conflicting wpasupplicant.conf renamed - move debug info into the dbg package | |||
2013-09-22 | nvgstplayer: libpcre*.so symlinks to existing libs in newer oe-core | Max Krummenacher | |
2013-08-26 | xserver: move all xserver stuff in the same directory | Max Krummenacher | |
2013-08-12 | trdx-nv-binaries: checksum change in khronos_headers.tgz | Max Krummenacher | |
khronos_headers.tgz has been updated with newer stuff from the khronos registry. As the file download is not version controlled a download will fail due to changed checksums. | |||
2013-07-10 | tegrastats: correctly detect if running on T30 | Max Krummenacher | |
2013-06-07 | nv-binaries: update to L4T R16.3 | Max Krummenacher | |
2013-04-15 | nvsamples: remove bitbake warning | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-03-04 | xorg.conf: Apalis & Colibri T30: use 16bpp framebuffer | Max Krummenacher | |
- 32bpp framebuffers use a lot of memorybandwidth, 16bpp is a better default | |||
2013-02-06 | trdx-nv-binaries: mimetype file assoziations fixed | Max Krummenacher | |
- nvgstplayer must be called in a terminal window - added mp3, wav, au audio mimetypes | |||
2013-01-29 | xorg.conf: add Apalis-T30 | Max Krummenacher | |
2013-01-29 | glmark2: add recipe for linaro glmark2 | Max Krummenacher | |
2013-01-29 | nv-binaries: added apalis | Max Krummenacher | |
- moved the files/colibri-t30 folder to files/t30 | |||
2012-12-07 | gstreamer: add colorspace converter for nvidia color space | Max Krummenacher | |
2012-12-07 | nvidia binaries: move the license files into the path used by oe for licenses | Max Krummenacher | |
2012-11-19 | nvsamples: | Max Krummenacher | |
- remove the header deployment, now provided by trdx-nv-binaries | |||
2012-11-19 | trdx-nv-binaries: | Max Krummenacher | |
- use L4T R16.2 binaries - provide the headers from khronos.org which describe the OpenGL ES related libs - unify colibri-t20, colibri-t30 | |||
2012-11-19 | tegrastats: | Max Krummenacher | |
- unified closed source LICENSE to CLOSED | |||
2012-10-19 | nv-binaries: don't deploy libjpeg.so which according to Nvidia does not work ↵ | Max Krummenacher | |
and interferes with our open source libjpeg | |||
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-10-18 | nvgstplayer: change symlink to point to the new libpcre*.so versions | Max Krummenacher | |
2012-10-18 | nvsamples: don't use source shaders, L4T can not cope compile for hardfloat | Max Krummenacher | |
2012-10-18 | corrected license info | Max Krummenacher | |
2012-10-18 | xserver hack no longer needed with R16 | Max Krummenacher | |
2012-10-18 | update the binary applications to use hard float abi | Max Krummenacher | |
2012-10-18 | update to L4T R16, use abi hard float instead of soft float | Max Krummenacher | |
2012-08-27 | nautilus depends on gobject-introspection-native | Max Krummenacher | |
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist | |||
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-06-19 | Add binary package of GPIOConfig, Tegrastats | Max Krummenacher | |
Add udev-late-mount | |||
2012-06-19 | Update to new NV binary packages L4T R15 | Max Krummenacher | |
Removed nvrm_deamon and corresponding init.d script Kernel from git.toradex.int | |||
2012-06-03 | Initial commit | Max Krummenacher | |
