- New ColibriT20_333_256_V1_2B_nand.bct targetting ISSI NAND part.
- Configure NvFlash for RS4 ECC algorithm compatible with YAFFS2.
- New loader.nb0 from WinCE/WEC release (pre-release for now).
- New nvflash binary built against latest WinCE/WEC sources.
- Adjusted update.sh script for new nvflash and added V1.2B handling.
Update git hash of the Linux kenrel to latest from 2.8b4 release and
revert BCH ECC configuration again.
Looks like something changed. Update header file hashes accordingly.
Update to later linaro eglibc 2.19 14.05 version as previous 14.04 is no
longer available for download.
The upstream server currently gives error 403.
$ wget http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
--2015-09-17 10:50:25-- http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
Resolving linuxbrit.co.uk (linuxbrit.co.uk)... 65.110.41.18
Connecting to linuxbrit.co.uk (linuxbrit.co.uk)|65.110.41.18|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2015-09-17 10:50:25 ERROR 403: Forbidden.
Add Atemsys Linux kernel module which enables to run the EtherCAT
Master stack from userspace.
Update to top of -next branch which also includes FEC unbind
fixes.
This contains some eMMC fixes for Apalis/Colibri T30 as well as a CSI-2
fix for Apalis T30 and an ACM fix.
- Make sure leases file is not persistent (in /var/run now)
This allows to serve the same IP to the generated (and hence
different IP addresses)
- Start RNDIS service after the network.target
- Tegra: Add extra service for udhcpd. When running dhcpd directly
from udev, the daemon will be killed after a while
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
Convert qt-demo-init to a systemd service. The service will only
start when the systemd target is set to graphical, hence also set
the new default target of the qt4e-demo-image to graphical.
Add a recipe for the Chromium OS version of the mmc-utils able to
handle Extended CSD revision 1.7 of the latest MMC 5.0 specification.
Some of the more interesting information thereof is the life time
estimation and pre EOL information as follows:
root@apalis-t30:~# mmc extcsd read /dev/mmcblk0 | \
grep -A 3 'Device life time estimation type A'
Device life time estimation type A [DEVICE_LIFE_TIME_EST_TYP_A: 0x01]
i.e. 0% - 10% device life time used
Pre EOL information [PRE_EOL_INFO: 0x01]
i.e. Normal
Add issue with getty also started on ttymxc1.
Also update default defconfig for colibri-vf.
Create a common script for USB flash drive (mass storage) and SD-
card updates.
Update default ALSA state for WM9712 AC97 codec support on 3.18
kernel.
Use the exact base types as X11 defines them. Newer compilers
through errors when mixing unsigned with unsigned long and
the likes.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Remove debug feed URL as it does not exist.
Re-add Colibri T20 specific (ARM, hard-float, non-neon) feeds which
recently are built in Angstrom again as Atmel SAMA5D3 is non-neon as
well.
Deploys the additonal u-boot and adds u-boot commands to deploy
on an IT module.
run update_it
run update_uboot_it
The IT variant needs different RAM timings
Two last minute fixes: Default Product/Vendor ID for USB peripheral
in U-Boot and fix for the USB peripheral RNDIS freeze.
Support IT variants in burnflash script "create_configblock.sh".
To use the kernel interfaces required for mcc-pingpong we need the
kernel headers of the actual kernel. Alter CFLAGS to add the kernel
headers to the include path.
If the rootfs in early init is read-only /etc/machine-id is in a tempfs.
systemd-machine-id-commit can be used to migrate to the 'real' rootfs.
The command is run in the installers postinst and thus needs no further
activation.
- Reduces the rootfs partition size to 3500MB to fit into all modules
- Add sanity checks for existens of some programms and files
This kernel can be used on latest Apalis T30 V1.1A hardware with
Toshiba eMMC and optional UHS SD cards in MMC slot.
Integrate L4T R16.5 for T20 currently exclusively distributed via
NVIDIA's partner portal. Should supposedly fix some memory leaks in
gstreamer resp. its OpenMAX wrapper thereof.
In order to make the MCC kernel module working with our newer kernel
some changes had been made on the MCC kernel module. The changes
are available on the Toradex Github account. Get the MCC kernel
module sources from Github.
This avoids fsck execution.
systemd-fsck[169]: arm: Superblock last write time (Tue Dec 16 15:46:16 2014,
systemd-fsck[169]: now = Mon Nov 17 11:08:57 2014) is in the future.
Depending on the system we might not have a sensible time. On top of that, during
first boot we compare the fs creation time of the PC with the intial embedded
time which very likely triggers the fsck.
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
