We want to append to the generic VAR when we build for a tegra machine.
Using VAR_tegra += "" creates a machine specific VAR.
Upstream has already fixed the GCC 5 problem, so use the patch from upstream.
Signed-off-by: Ross Burton <ross.burton@intel.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Backport a patch from fedora details are in patch header
Change-Id: I6b8dfaae3b751071bf8b0d88b15a4f95c19877f6
Signed-off-by: Khem Raj <raj.khem@gmail.com>
The evdev version provided by oe-core is in the meantime newer than
this backport, hence we can safely remove it.
The upstream server currently gives error 403.
$ wget http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
--2015-09-17 10:50:25-- http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
Resolving linuxbrit.co.uk (linuxbrit.co.uk)... 65.110.41.18
Connecting to linuxbrit.co.uk (linuxbrit.co.uk)|65.110.41.18|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2015-09-17 10:50:25 ERROR 403: Forbidden.
(cherry picked from commit 77e6a09a5afeab9f0d550b3319e134ec991f50cf)
gpu-viv-bin-mx6q -> imx-gpu-viv
with a bunch of subpackages.
PublicDomain is not known to OE
Neiter graphviz_2.32.0.bb graphviz_2.38.0.bb work with dizzy.
Uses python directory from build host.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
while at it remove the xserver-xorg.inc file in favour of the identical
inc file in the openembedded-core layer.
Upgrading to 1.14.7 fixes the broken X server rotation issue seen on
Apalis/Colibri T20/T30 as noted on our developer website:
http://developer.toradex.com/software-resources/arm-family/linux/linux/
release-details?view=all&issue=9562
This is an upgrade from the former 1.14.4 recipe as found here:
http://cgit.openembedded.org/openembedded-core/tree/meta/
recipes-graphics/xorg-xserver?id=
b8feee3cf21f70ba4ec3b822d2f596d4fc02a292
This is also done by the session manager effectively starting the
autostart items twice.
Remove xinput-calibrator systemd service since autostart is done
using /etc/xdg/autostart/xinput_calibrator.desktop.
HACK: during do_rootfs opkg takes the latest and greatest available
in any feed, e.g. one built for another machine without prefered version
rather than what PREFERRED_VERSION puts in the MACHINE_ARCH feed
so we set the recipe epoch here. Thus for our architecture we're
always latest and greatest.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
The tegras xdrivers require an 1.14 API
Make the xserver ARCH specific
Two popular VNC clients:
- DirectVNC based on DirectFB (e.g. without X11)
- TightVNC based on X11
(cherry picked from commit ef4113208de357a5b8accd7610f8bf3230125a59)
If the xinput-calibrator.service is enabled but lxdm.service is disabled lxdm
was started anyway because of the requires dependency.
Replase Requires with Requisite to have xinput-calibrator.service fail instead.
(cherry picked from commit e34e6361ecaaa8b148d438d517761bdd084d1a32)
adds gpu-viv-bin-mx6q-libraries package which RDEPENDS only the
libraries but not the samples.
V2.7.3 crash when it receives multitouch events
With the propriatry GPU driver, some text is not rendered.
e.g. like in this report
http://slopjong.de/2012/11/19/problem-with-font-rendering/
-> revert the relevant patch
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- make the menuentry behave as the one time calibration on first boot
- Unclutter hides your X mouse cursor when you do not need it
