2015-11-04 | apalis/colibri_imx6: update/load USB Gadget ConfigFS automatically | Stefan Agner | |
Since we use USB Gadget ConfigFS now use libusbg to load the USB Gadget configuration automatically. | |||
2015-11-03 | Update Linux kernel and U-Boot to latest. | Marcel Ziswiler | |
2015-10-21 | colibri_vf: update/load USB Gadget ConfigFS automatically | Stefan Agner | |
Update defconfig and kernel version to latest version from git. This also configures the USB Gadget ConfigFS as a module. Add the ConfigFS module to the list of autoloaded modules. | |||
2015-10-12 | Apalis iMX6: cleanup filename for V1.0 HW | Max Krummenacher | |
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version. | |||
2015-10-12 | apalis-imx6: update kernel to toradex_imx_3.14.28_1.0.0_ga-next | Max Krummenacher | |
2015-08-13 | colibri-vf: initial kernel based on upstream 4.1 | Max Krummenacher | |
2015-08-07 | kernel: adapt to oe's new shared work dir | Max Krummenacher | |
2015-08-07 | colibri-vf: moved to meta-fsl-arm, remove here | Max Krummenacher | |
2015-06-03 | colibri_vf: enable SCSI disk required for USB mass storage | Stefan Agner | |
SCSI lock device disk support is required for USB mass storage to work. Also enable asynchronous SCSI scanning by default. | |||
2015-05-29 | mcc-kmod: fix revision to build with kernel revision used | Stefan Agner | |
Use a fixed revision of the MCC kernel module which makes sure it builds with the corresponding Vybrid Linux kernel, which also uses a fixed git hash. | |||
2015-05-18 | Apalis/Colibri iMX6: use toradex_imx_3.10.17_1.0.0_ga branch | Max Krummenacher | |
2015-05-18 | Colibri VF: use latest from toradex_vf_4.0 branch | Max Krummenacher | |
2015-05-18 | Apalis/Colibri T20/T30: use tegra branch | Max Krummenacher | |
2015-05-18 | Apalis/Colibri iMX6: update kernel to latest in -next | Max Krummenacher | |
2015-05-18 | Apalis/Colibri T20/T30: update kernel to latest in -next | Max Krummenacher | |
2015-05-12 | recipes-kernel: remove orphaned 3.17 defconfig | Max Krummenacher | |
2015-05-12 | Apalis/Colibri iMX6: kernel/U-Boot update to latest in -next | Max Krummenacher | |
2015-05-12 | update U-Boot and Colibri VFxx Linux to latest git revision | Stefan Agner | |
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module. | |||
2015-05-12 | colibri_vf: update to U-Boot 2015.04/Linux 4.0 | Stefan Agner | |
2015-05-12 | linux-toradex-fsl_git.bb: remove 3.0.15 Vybrid Kernel | Max Krummenacher | |
This removes the 3.0.15 based Kernel for Colibri VFxx. Since some time now we use a more recent Kernel provided from the linux-toradex-vf_3.18.bb recipe. | |||
2015-05-12 | apalis/colibri_t20/t30: integrate latest stuff | Marcel Ziswiler | |
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-03-19 | atemsys: add atemsys kernel module | Stefan Agner | |
Add Atemsys Linux kernel module which enables to run the EtherCAT Master stack from userspace. | |||
2015-03-19 | colibri-vf: update to top of -next branch | Stefan Agner | |
Update to top of -next branch which also includes FEC unbind fixes. | |||
2015-03-19 | tegras: update to latest kernelColibri_T20_LinuxImageV2.3_20150320V2.3 | Marcel Ziswiler | |
This contains some eMMC fixes for Apalis/Colibri T30 as well as a CSI-2 fix for Apalis T30 and an ACM fix. | |||
2015-02-03 | tegras: update git hash of Linux kernelColibri_VF_LinuxImageV2.3Beta7_20150203Colibri_T20_LinuxImageV2.3Beta7_20150203 | Stefan Agner | |
2015-02-03 | colibri-vf: update Linux kernel and U-Boot git hashes | Stefan Agner | |
Also update default defconfig for colibri-vf. | |||
2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-18 | tegras: update to latest kernel | Marcel Ziswiler | |
This kernel can be used on latest Apalis T30 V1.1A hardware with Toshiba eMMC and optional UHS SD cards in MMC slot. | |||
2014-12-18 | mcc-kmod: use mcc kernel module from toradex git | Stefan Agner | |
In order to make the MCC kernel module working with our newer kernel some changes had been made on the MCC kernel module. The changes are available on the Toradex Github account. Get the MCC kernel module sources from Github. | |||
2014-12-16 | colibri-vf: switch to mainline kernel based on 3.18 | Stefan Agner | |
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch. | |||
2014-12-11 | colibri-vf: update Kernel | Max Krummenacher | |
2014-12-11 | apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1 | Max Krummenacher | |
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules | |||
2014-11-13 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: rev kernel version to V2.3b4 | Marcel Ziswiler | |
2014-11-13 | colibri-vf: add mainline kernel recipe | Stefan Agner | |
Add recipe to build mainline kernel. Currently, the 3.17 next branch will be built. To use this kernel, add this lines to your local.conf PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex" IMAGE_INSTALL_append = "kernel-devicetree" KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb" Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc since the required kernel interfaces are not available on the 3.17 mainline port. | |||
2014-10-30 | linux: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-30 | linux: tegra latest from git | Marcel Ziswiler | |
2014-10-06 | colibri-imx6: refactor recipes for new module | Max Krummenacher | |
2014-09-03 | linux-toradex: update to latestApalis_T30_LinuxImageV2.3Beta2_20140903 | Max Krummenacher | |
This pulls in the fix for PCIe rarely unavailable at boot. Branch changed from colibri to tegra | |||
2014-08-04 | kernel: update to latest on git.toradex.comColibri_VF_LinuxImageV2.3Beta1_20140804Colibri_T30_LinuxImageV2.3Beta1_20140804Colibri_T20_LinuxImageV2.3Beta1_20140804Apalis_iMX6_LinuxImageV2.3Beta1_20140804Apalis_T30_LinuxImageV2.3Beta1_20140804 | Max Krummenacher | |
2014-08-04 | t20, t30: update kernel to latest in git | Max Krummenacher | |
2014-08-04 | apalis-imx: update kernel to 3.10.17 | Max Krummenacher | |
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus code changes for Apalis iMX6. | |||
2014-08-04 | colibri-vf: update kernel to latest, port recipe for use with daisy | Max Krummenacher | |
2014-08-04 | linux-toradex-fsl: remove linux-toradex-fsl.inc usage | Max Krummenacher | |
2014-08-04 | mcc/m4: use recipes from meta-fsl-arm | Max Krummenacher | |
deleted: recipes-bsp/libmcc/libmcc_1.04.bb deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb | |||
2014-05-20 | colibri-vf: switch back to latest git on colibri_vf branch | Marcel Ziswiler | |
This commit switches Colibri VF machine back to use the colibri_vf branch and use the latest Linux kernel. | |||
2014-05-07 | linux-toradex: rename linux.inc to avoid layer order dependency | Stefan Agner | |
The include files (such as linux.inc) are not resolved by priority but on layer order instead. This can lead to build errors in case the layers in BBLAYERS are ordered differently. |
