2020-04-21LinuxImage3.0-next: update to latest meta-toradex-* hashesVerdin-iMX8MM_Console-Image_3.0b4.254-20200421Colibri-iMX8X_Console-Image_3.0b4.254-20200421Colibri-iMX7_Console-Image_3.0b4.254-20200421Colibri-iMX7-eMMC_Console-Image_3.0b4.254-20200421Colibri-iMX6_Console-Image_3.0b4.254-20200421Colibri-iMX6ULL_Console-Image_3.0b4.254-20200421Apalis-iMX8_Console-Image_3.0b4.254-20200421Apalis-iMX8X_Console-Image_3.0b4.254-20200421Apalis-iMX6_Console-Image_3.0b4.254-20200421Apalis-TK1_Console-Image_3.0b4.254-20200421Apalis-TK1-Mainline_Console-Image_3.0b4.254-20200421LinuxImage3.0-nextLinuxImage3.0Marcel Ziswiler
Related-to: ELB-2510 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-04-17LinuxImage3.0-next: update to latest meta-toradex-* hashesMarcel Ziswiler
2020-04-17default.xml: update to latest meta-freescaleMarcel Ziswiler
This is needed to match HEAD of meta-toradex-nxp. Related-to: commit 1f6cebb1f714 ("integration.xml: update to latest meta-freescale") Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-04-16integration.xml: update to latest meta-freescaleMax Krummenacher
This is needed to match HEAD of meta-toradex-nxp. Change-Id: If2cde40de0a34062edb5a53e7b2437c570cff15d Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-03-18LinuxImage3.0: update to latest layer hashesMax Krummenacher
Change-Id: Ie1facdd56a2e346f0bcdbbb06d0490209ad72f55 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-03-12next.xml: pin meta-rustMax Krummenacher
Keep meta-rust at 1.39 as firefox 60 does not build with 1.40. 0:14.15 error[E0713]: borrow may still be in use when destructor runs 0:14.15 --> /usr/src/debug/firefox/60.4.0esr-r0/firefox-60.4.0/third_party/rust/url/src/form_urlencoded.rs:261:40 Change-Id: I6d088af4b5798484622ca40f0dba9f904255d642 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-01-13README: clean-upMax Krummenacher
Change-Id: I53c27386ae1cdc103078855828ca05c2d36747b0 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-12-30LinuxImage3.0: update to latest meta-toradex-* hashesVerdin-iMX8MM_Console-Image_3.0b3.118-20200101Colibri-iMX8X_Console-Image_3.0b3.118-20200101Colibri-iMX7_Console-Image_3.0b3.118-20200101Colibri-iMX7-eMMC_Console-Image_3.0b3.118-20200101Colibri-iMX6_Console-Image_3.0b3.118-20200101Colibri-iMX6ULL_Console-Image_3.0b3.118-20200101Apalis-iMX8_Console-Image_3.0b3.118-20200101Apalis-iMX8X_Console-Image_3.0b3.118-20191231Apalis-iMX6_Console-Image_3.0b3.118-20191231Apalis-TK1_Console-Image_3.0b3.118-20191231Apalis-TK1-Mainline_Console-Image_3.0b3.118-20200101Marcel Ziswiler
2019-12-30default.xml: update external layer heads to latest thudMax Krummenacher
Keep meta-browser to where one does not yet need meta-clang. Change-Id: Ie46a00f3dc91fbf4bc3989e0e929e2bfcdaf75f0 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit bc008a30194b59f7197d015a4983252f417d556d) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-12-19next.xml: pin meta-browserMax Krummenacher
Keep meta-browser to where one does not yet need meta-clang. Change-Id: I6d088af4b5798484622ca40f0dba9f904255d642 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-12-19integration.xml: update external layer heads to latest thudMax Krummenacher
2019-08-29LinuxImage3.0: update to latest meta-toradex-bsp-common hashColibri-iMX8X_Console-Image_3.0b2.65-20190830Colibri-iMX7_Console-Image_3.0b2.65-20190830Colibri-iMX6_Console-Image_3.0b2.65-20190830Colibri-iMX6ULL_Console-Image_3.0b2.65-20190830Apalis-iMX8_Console-Image_3.0b2.65-20190830Apalis-iMX6_Console-Image_3.0b2.65-20190830Apalis-TK1_Console-Image_3.0b2.65-20190830Apalis-TK1-Mainline_Console-Image_3.0b2.65-20190830Max Krummenacher
This fixes the missing kernel filename in image.json for rawnand devices. Change-Id: I11aec8f68a0f01251cd406b4c6c39f4ab94adb6e Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-08-28LinuxImage3.0: update to latest meta-toradex-nxp hashMax Krummenacher
This fixes the missing kernel/dtb in bootfs. Change-Id: Iaa969e71ef459360adbd8f3426e2f8d6f03b5fcc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-08-27LinuxImage3.0: update to latest meta-toradex-tegra hashMax Krummenacher
Change-Id: I22b0118565df41d822c575f17e92f12facf77e69 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-08-26LinuxImage3.0: update to latest meta-toradex-* hashesMax Krummenacher
Change-Id: I57ac050151b20170436ba9787c2914b1c9ecf1c4 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-08-05manifests: update hashes to latest upstreamMax Krummenacher
Change-Id: Ie2172dcd2a7e80fc1b1689813ec99b2fdbb9b573 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-11LinuxImage3.0: update to latest meta-toradex-* hashesApalis-iMX8_Console-Image_3.0b1.40-20190612Max Krummenacher
Change-Id: I23272f40bd1265c58db997f74089eb125bc94a25 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-05LinuxImage3.0: add a default.xmlMax Krummenacher
Change-Id: I83c52b2bad50959d352baabb171a12663231042f Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-30integration.xml: update 3-rdparty layer git hashes to latest for thudMax Krummenacher
Change-Id: Ifd101af6a3890ada3d85c1f39277c4d2da4ad013 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-08manifests: drop installing the qt4 layerMax Krummenacher
Qt 4 was first released in 2005 and has been unsupported since 2015. Drop it from what we regularly install. Change-Id: Ieebc09b9896cd342a8d1c42a02c4c2f8556cdb8b Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-29integration.xml: use a valid upstream git sha for meta-qt5-extraMax Krummenacher
Change-Id: I5e16cfabbd96f90dc80c3151518803c38e2f4d88 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-25integration.xml: use a valid upstream git sha for meta-freescaleMax Krummenacher
Change-Id: Iac82fa3d92fb9fac1c88fb4d51efb83798bea35e Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-23integration.xml: update 3-rdparty layer git hashes to latest for thudMax Krummenacher
Change-Id: I1e92f022cde92cbea9a496ae9bf8f76dcc725133 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-07README: adapt for 3.0Max Krummenacher
- No longer keep an incomplete list of machines. - No longer point out the parallization variables as they are now set dynamically. - Don't use 'master' as the branch to check out. - Reformat. Change-Id: I5b837fecae3233b2798cef517aa7693ee6a90de8 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-07manifests: update hashes to latest upstream and fix syntaxMax Krummenacher
Update the git hashes of all external layers to latest on the used branches. Fix syntax errors in next.xml. Change-Id: I6df71a712b7b123ae5a133d77cd549dec946a1fd Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06manifest: integrate meta-toradex-distroMax Krummenacher
Change-Id: Ibd4b023a6b73b0bf3773604917b3a8021acdaaab Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-05manifest: initial 3.0 aka thud releaseMax Krummenacher
With the move to thud we drop angstrom as our distro and we drop support for Apalis T30, Colibri T20/T30. - Do not install meta-angstrom. - No longer used, do not install meta-jetson-tk1. - Delete default.xml, add when ready for a release again. Change-Id: I0d1725c8d0587ded4025b0a92afd9927c1787615 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-01-03manifest: add integration and next as separate filesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-01-03manifest: next: top of all branchesMarcel Ziswiler
For development purpose this manifest is meant to build top of stable external branches as well as top of -next branches on our meta-lxde as well as meta-toradex- aka all tdx repos. This may be combined with the following machine override in your local.conf to also get top of -next branches from our U-Boot and Linux kernel repo branches: MACHINEOVERRIDES =. "use-head-next:" Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-01-03manifest: integration: top of -next branches on tdx reposMarcel Ziswiler
For integration purpose this manifest is meant to build top of -next branches on our meta-lxde as well as meta-toradex- aka all tdx repos. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2019-01-03manifest: freeze toradex repositories to latest rockoColibri-iMX7_LXDE-Image_2.8b5.156-20181228Colibri-iMX6_LXDE-Image_2.8b5.156-20181228Colibri-iMX6ULL_LXDE-Image_2.8b5.156-20181228Colibri-VF_LXDE-Image_2.8b5.156-20181228Colibri-T30_LXDE-Image_2.8b5.156-20181228Colibri-T20_LXDE-Image_2.8b5.156-20181228Apalis-iMX6_LXDE-Image_2.8b5.156-20181228Apalis-TK1_LXDE-Image_2.8b5.156-20181228Apalis-TK1-Mainline_LXDE-Image_2.8b5.156-20181228Apalis-T30_LXDE-Image_2.8b5.156-20181228Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
2018-12-07manifest: freeze external repositories to latest rockoMarcel Ziswiler
Skip meta-angstrom (e.g. not upgrading to systemd 237) and meta-browser (e.g. not upgrading to Firefox 60.1.0esr). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-10-09manifest: freeze toradex repositories to latest rockoColibri-iMX7_LXDE-Image_2.8b4.129-20181005Colibri-iMX6_LXDE-Image_2.8b4.129-20181005Colibri-iMX6ULL_LXDE-Image_2.8b4.129-20181005Colibri-VF_LXDE-Image_2.8b4.129-20181005Colibri-T30_LXDE-Image_2.8b4.129-20181005Colibri-T20_LXDE-Image_2.8b4.129-20181005Apalis-iMX6_LXDE-Image_2.8b4.129-20181005Apalis-TK1_LXDE-Image_2.8b4.129-20181005Apalis-TK1-Mainline_LXDE-Image_2.8b4.129-20181005Apalis-T30_LXDE-Image_2.8b4.129-20181005Marcel Ziswiler
2018-09-11manifest: freeze external repositories to latest rockoMarcel Ziswiler
2018-06-29manifest: use https by defaultColibri-iMX7_LXDE-Image_2.8b3.111-20180627Colibri-iMX6_LXDE-Image_2.8b3.111-20180627Colibri-iMX6ULL_LXDE-Image_2.8b3.111-20180627Colibri-VF_LXDE-Image_2.8b3.111-20180626Colibri-T30_LXDE-Image_2.8b3.111-20180627Colibri-T20_LXDE-Image_2.8b3.111-20180626Apalis-iMX6_LXDE-Image_2.8b3.111-20180626Apalis-TK1_LXDE-Image_2.8b3.111-20180626Apalis-TK1-Mainline_LXDE-Image_2.8b3.111-20180627Apalis-T30_LXDE-Image_2.8b3.111-20180626Stefan Agner
This avoids a warning when fetching GitHub repositories: warning: redirecting to https://github.com/meta-qt5/meta-qt5.git/ Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-29manifest: freeze toradex repositories to latest rockoMarcel Ziswiler
2018-06-29manifest: freeze external repositories to latest rockoMarcel Ziswiler
2018-06-21manifest: use rocko branch for meta-qt5-extraStefan Agner
2018-04-11manifest: update meta-toradex-demos to latestMarcel Ziswiler
2018-03-30manifest: update meta-toradex-tegra to latestColibri-iMX7_LXDE-Image_2.8b2.97-20180331Colibri-iMX6_LXDE-Image_2.8b2.97-20180331Colibri-iMX6ULL_LXDE-Image_2.8b2.97-20180331Colibri-VF_LXDE-Image_2.8b2.97-20180331Colibri-T30_LXDE-Image_2.8b2.97-20180331Colibri-T20_LXDE-Image_2.8b2.97-20180331Apalis-iMX6_LXDE-Image_2.8b2.97-20180331Apalis-TK1_LXDE-Image_2.8b2.97-20180331Apalis-TK1-Mainline_LXDE-Image_2.8b2.97-20180331Apalis-T30_LXDE-Image_2.8b2.97-20180331Marcel Ziswiler
2018-03-29manifest: update meta-toradex-demos to latestMarcel Ziswiler
2018-03-29manifest: freeze toradex repositories to latest rockoMarcel Ziswiler
While at it drop obsolete snappy stuff. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-29manifest: freeze external repositories to latest rockoMarcel Ziswiler
2018-03-26default.xml: add meta-qt5-extraMax Krummenacher
Change-Id: I92d69313403d7f9dfea9063a7c402ce78523e629 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-12-30manifest: use angstrom-v2017.12-rocko branch for meta-angstromColibri-iMX7_LXDE-Image_2.8b1.64-20171229Colibri-iMX6_LXDE-Image_2.8b1.64-20171229Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229Colibri-VF_LXDE-Image_2.8b1.64-20171229Colibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-iMX6_LXDE-Image_2.8b1.64-20171229Apalis-TK1_LXDE-Image_2.8b1.64-20171229Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229Stefan Agner
2017-12-30manifest: update to rockoMax Krummenacher
Change-Id: I21e0c1051cc7b369fb68252c5a62fd45e3203455 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-06manifest: update meta-toradex-bsp-common to latest mortyMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-12-06manifest: update to latest morty hashesColibri-iMX6ULL_LXDE-Image_2.7b5-20171201Apalis-TK1_LXDE-Image_2.7b5-20171201Max Krummenacher
Change-Id: Idadc0845a58d73e88993c0e291266f155a285e47 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-06manifest: update meta-toradex-tegra to latestApalis-TK1_LXDE-Image_2.7b4-20171007Marcel Ziswiler
2017-10-06manifest: freeze toradex repositories to latest morty as wellColibri-iMX7_LXDE-Image_2.7b4-20171005Colibri-iMX6_LXDE-Image_2.7b4-20171005Colibri-VF_LXDE-Image_2.7b4-20171005Colibri-T30_LXDE-Image_2.7b4-20171005Colibri-T20_LXDE-Image_2.7b4-20171005Apalis-iMX6_LXDE-Image_2.7b4-20171005Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005Apalis-T30_LXDE-Image_2.7b4-20171005Marcel Ziswiler
