2019-12-10 | next.xml: pin meta-browser | Max Krummenacher | |
meta-browser only has a master branch which later versions are no longer compatible to the rocko branch of the other layers. Change-Id: Icb2a8e4fd7d195d47630ab5d6d347e64b7f7a8d1 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2019-12-06 | default.xml: actually pin all repos now that we have integration and next | Max Krummenacher | |
These finishes commit '1dd22db manifest: add integration and next as separate files' Change-Id: I1655893117937f31eb64263bcf7d1e9dc929ce82 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2019-04-01 | manifest: add integration and next as separate files | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2019-04-01 | manifest: next: top of all branches | Marcel Ziswiler | |
For development purpose this manifest is meant to build top of stable external branches as well as top of -next branches on our meta-lxde as well as meta-toradex- aka all tdx repos. This may be combined with the following machine override in your local.conf to also get top of -next branches from our U-Boot and Linux kernel repo branches: MACHINEOVERRIDES =. "use-head-next:" Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2019-04-01 | manifest: integration: top of -next branches on tdx repos | Marcel Ziswiler | |
For integration purpose this manifest is meant to build top of -next branches on our meta-lxde as well as meta-toradex- aka all tdx repos. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> | |||
2019-04-01 | manifest: freeze toradex repositories to latest rockoColibri-iMX7_LXDE-Image_2.8b6.184-20190401Colibri-iMX6_LXDE-Image_2.8b6.184-20190401Colibri-iMX6ULL_LXDE-Image_2.8b6.184-20190401Colibri-VF_LXDE-Image_2.8b6.183-20190331Colibri-T30_LXDE-Image_2.8b6.184-20190401Colibri-T20_LXDE-Image_2.8b6.184-20190401Apalis-iMX6_LXDE-Image_2.8b6.184-20190401Apalis-TK1_LXDE-Image_2.8b6.184-20190401Apalis-TK1-Mainline_LXDE-Image_2.8b6.184-20190401Apalis-T30_LXDE-Image_2.8b6.184-20190401 | Marcel Ziswiler | |
2019-01-03 | manifest: freeze toradex repositories to latest rockoColibri-iMX7_LXDE-Image_2.8b5.156-20181228Colibri-iMX6_LXDE-Image_2.8b5.156-20181228Colibri-iMX6ULL_LXDE-Image_2.8b5.156-20181228Colibri-VF_LXDE-Image_2.8b5.156-20181228Colibri-T30_LXDE-Image_2.8b5.156-20181228Colibri-T20_LXDE-Image_2.8b5.156-20181228Apalis-iMX6_LXDE-Image_2.8b5.156-20181228Apalis-TK1_LXDE-Image_2.8b5.156-20181228Apalis-TK1-Mainline_LXDE-Image_2.8b5.156-20181228Apalis-T30_LXDE-Image_2.8b5.156-20181228 | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Philippe Schenker <philippe.schenker@toradex.com> | |||
2018-12-07 | manifest: freeze external repositories to latest rocko | Marcel Ziswiler | |
Skip meta-angstrom (e.g. not upgrading to systemd 237) and meta-browser (e.g. not upgrading to Firefox 60.1.0esr). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2018-10-09 | manifest: freeze toradex repositories to latest rockoColibri-iMX7_LXDE-Image_2.8b4.129-20181005Colibri-iMX6_LXDE-Image_2.8b4.129-20181005Colibri-iMX6ULL_LXDE-Image_2.8b4.129-20181005Colibri-VF_LXDE-Image_2.8b4.129-20181005Colibri-T30_LXDE-Image_2.8b4.129-20181005Colibri-T20_LXDE-Image_2.8b4.129-20181005Apalis-iMX6_LXDE-Image_2.8b4.129-20181005Apalis-TK1_LXDE-Image_2.8b4.129-20181005Apalis-TK1-Mainline_LXDE-Image_2.8b4.129-20181005Apalis-T30_LXDE-Image_2.8b4.129-20181005 | Marcel Ziswiler | |
2018-09-11 | manifest: freeze external repositories to latest rocko | Marcel Ziswiler | |
2018-06-29 | manifest: use https by defaultColibri-iMX7_LXDE-Image_2.8b3.111-20180627Colibri-iMX6_LXDE-Image_2.8b3.111-20180627Colibri-iMX6ULL_LXDE-Image_2.8b3.111-20180627Colibri-VF_LXDE-Image_2.8b3.111-20180626Colibri-T30_LXDE-Image_2.8b3.111-20180627Colibri-T20_LXDE-Image_2.8b3.111-20180626Apalis-iMX6_LXDE-Image_2.8b3.111-20180626Apalis-TK1_LXDE-Image_2.8b3.111-20180626Apalis-TK1-Mainline_LXDE-Image_2.8b3.111-20180627Apalis-T30_LXDE-Image_2.8b3.111-20180626 | Stefan Agner | |
This avoids a warning when fetching GitHub repositories: warning: redirecting to https://github.com/meta-qt5/meta-qt5.git/ Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2018-06-29 | manifest: freeze toradex repositories to latest rocko | Marcel Ziswiler | |
2018-06-29 | manifest: freeze external repositories to latest rocko | Marcel Ziswiler | |
2018-06-21 | manifest: use rocko branch for meta-qt5-extra | Stefan Agner | |
2018-04-11 | manifest: update meta-toradex-demos to latest | Marcel Ziswiler | |
2018-03-30 | manifest: update meta-toradex-tegra to latestColibri-iMX7_LXDE-Image_2.8b2.97-20180331Colibri-iMX6_LXDE-Image_2.8b2.97-20180331Colibri-iMX6ULL_LXDE-Image_2.8b2.97-20180331Colibri-VF_LXDE-Image_2.8b2.97-20180331Colibri-T30_LXDE-Image_2.8b2.97-20180331Colibri-T20_LXDE-Image_2.8b2.97-20180331Apalis-iMX6_LXDE-Image_2.8b2.97-20180331Apalis-TK1_LXDE-Image_2.8b2.97-20180331Apalis-TK1-Mainline_LXDE-Image_2.8b2.97-20180331Apalis-T30_LXDE-Image_2.8b2.97-20180331 | Marcel Ziswiler | |
2018-03-29 | manifest: update meta-toradex-demos to latest | Marcel Ziswiler | |
2018-03-29 | manifest: freeze toradex repositories to latest rocko | Marcel Ziswiler | |
While at it drop obsolete snappy stuff. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> | |||
2018-03-29 | manifest: freeze external repositories to latest rocko | Marcel Ziswiler | |
2018-03-26 | default.xml: add meta-qt5-extra | Max Krummenacher | |
Change-Id: I92d69313403d7f9dfea9063a7c402ce78523e629 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2017-12-30 | manifest: use angstrom-v2017.12-rocko branch for meta-angstromColibri-iMX7_LXDE-Image_2.8b1.64-20171229Colibri-iMX6_LXDE-Image_2.8b1.64-20171229Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229Colibri-VF_LXDE-Image_2.8b1.64-20171229Colibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-iMX6_LXDE-Image_2.8b1.64-20171229Apalis-TK1_LXDE-Image_2.8b1.64-20171229Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229 | Stefan Agner | |
2017-12-30 | manifest: update to rocko | Max Krummenacher | |
Change-Id: I21e0c1051cc7b369fb68252c5a62fd45e3203455 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-12-06 | manifest: update meta-toradex-bsp-common to latest morty | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com> | |||
2017-12-06 | manifest: update to latest morty hashesColibri-iMX6ULL_LXDE-Image_2.7b5-20171201Apalis-TK1_LXDE-Image_2.7b5-20171201 | Max Krummenacher | |
Change-Id: Idadc0845a58d73e88993c0e291266f155a285e47 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-10-06 | manifest: update meta-toradex-tegra to latestApalis-TK1_LXDE-Image_2.7b4-20171007 | Marcel Ziswiler | |
2017-10-06 | manifest: freeze toradex repositories to latest morty as wellColibri-iMX7_LXDE-Image_2.7b4-20171005Colibri-iMX6_LXDE-Image_2.7b4-20171005Colibri-VF_LXDE-Image_2.7b4-20171005Colibri-T30_LXDE-Image_2.7b4-20171005Colibri-T20_LXDE-Image_2.7b4-20171005Apalis-iMX6_LXDE-Image_2.7b4-20171005Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005Apalis-T30_LXDE-Image_2.7b4-20171005 | Marcel Ziswiler | |
2017-10-06 | manifest: update openembedded-core to latest morty | Max Krummenacher | |
Change-Id: I6102549221f324fa89e4003113f1b55f94179e02 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-10-06 | manifest: freeze external repositories to latest morty | Marcel Ziswiler | |
Getting ready for release let us freeze the external repositories to latest morty. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com> | |||
2017-09-27 | manifest: move to top of branches | Stefan Agner | |
Let repo use top of (morty) branch of all repositories we use and use top of morty-next branch of all Toradex repositories. Also remove head-default.xml since it was outdated anyways. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-07-05 | manifest: update to latest mortyColibri-iMX7_LXDE-Image_2.7b3-20170630Colibri-iMX6_LXDE-Image_2.7b3-20170630Colibri-VF_LXDE-Image_2.7b3-20170630Colibri-T30_LXDE-Image_2.7b3-20170630Colibri-T20_LXDE-Image_2.7b3-20170630Apalis-iMX6_LXDE-Image_2.7b3-20170630Apalis-TK1_LXDE-Image_2.7b3-20170630Apalis-T30_LXDE-Image_2.7b3-20170630 | Max Krummenacher | |
This updates meta-toradex-demos to fix recovery mode which was using a not available u-boot.imx symlink. Change-Id: I7c7365f1a25d42658ba49fea8765240899b202b1 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-07-01 | manifest: update to latest morty | Marcel Ziswiler | |
Update meta-toradex-* and the other layers to latest morty. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com> | |||
2017-07-01 | manifest: add meta-snappy | Marcel Ziswiler | |
2017-04-14 | manifest: update to latest mortyColibri-iMX7_LXDE-Image_2.7b2-20170410Colibri-iMX6_LXDE-Image_2.7b2-20170410Colibri-VF_LXDE-Image_2.7b2-20170410Colibri-T30_LXDE-Image_2.7b2-20170410Colibri-T20_LXDE-Image_2.7b2-20170410Apalis-iMX6_LXDE-Image_2.7b2-20170410Apalis-TK1_LXDE-Image_2.7b2-20170410Apalis-T30_LXDE-Image_2.7b2-20170410 | Max Krummenacher | |
Update meta-toradex-* and the other layers to latest morty. Change-Id: I89929f0f19f3293b7ea6b550993cec3088f4d2b6 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-01-26 | manifest: update meta-lxde to latest | Max Krummenacher | |
Update meta-lxde. This fixes build of lxterminal if catalog files are not installed on the host. Change-Id: I3153f0c0be822fa90fae466007d1de18d5deb3c4 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2017-01-19 | manifest: update meta-lxde to latest | Max Krummenacher | |
This fixes lxterminal dependencies, so there is no longer a race condition which may make building it fail due to missing tools for man pages. Change-Id: Id38b2153e63cc27697bcfa9f23eb9c0f5108299c Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2017-01-13 | manifest: update meta-toradex-tegra to latest | Marcel Ziswiler | |
2017-01-13 | manifest: move from morty-next to morty branchesColibri_iMX7_LinuxImageV2.7Beta1_20170112Colibri_iMX6_LinuxImageV2.7Beta1_20170112Colibri_VF_LinuxImageV2.7Beta1_20170112Colibri_T30_LinuxImageV2.7Beta1_20170112Colibri_T20_LinuxImageV2.7Beta1_20170112Apalis_iMX6_LinuxImageV2.7Beta1_20170112Apalis_TK1_LinuxImageV2.7Beta1_20170112Apalis_T30_LinuxImageV2.7Beta1_20170112 | Max Krummenacher | |
Change-Id: I9d4dad0e65ed2b5d8057d73c9f385b362b8652b2 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2017-01-12 | manifest: update to morty | Max Krummenacher | |
Change-Id: Iad1e866b68848cf373b9c483a86ebe77ea74e5ad Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-11-22 | manifest: update to latest jethroApalis_TK1_LinuxImageV2.6.1Beta2_20161122 | Max Krummenacher | |
Change-Id: I8129d4fc8c5b83948357ffd2aa656626ad4efd4b Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-10-01 | manifest: update to latest jethroColibri_iMX7_LinuxImageV2.6.1Beta1_20160929Colibri_iMX6_LinuxImageV2.6.1Beta1_20160929Colibri_VF_LinuxImageV2.6.1Beta1_20161001Colibri_T30_LinuxImageV2.6.1Beta1_20160929Colibri_T20_LinuxImageV2.6.1Beta1_20160929Apalis_iMX6_LinuxImageV2.6.1Beta1_20160929Apalis_TK1_LinuxImageV2.6.1Beta1_20160929Apalis_T30_LinuxImageV2.6.1Beta1_20160929 | Max Krummenacher | |
Change-Id: If915ef9bada09e173de7e1c2e0fe9dd24b865254 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-09-05 | default.xml: oe-layers: rename the parent directory from stuff to layers | Max Krummenacher | |
Have all oe meta data layers in a directory called layers rather than stuff Change-Id: Ibb4a383830c528de12c389aa6bbf70606dc637ae Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-08-26 | add the split meta-toradex-xxx layers | Max Krummenacher | |
Change-Id: I6acf15dd9fdb6f5cda897a5c57feb1943d7d69f5 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-07-01 | manifest: update to latest jethroColibri_iMX7_LinuxImageV2.6Beta2_20160701Colibri_iMX6_LinuxImageV2.6Beta2_20160701Colibri_VF_LinuxImageV2.6Beta2_20160701Colibri_T30_LinuxImageV2.6Beta2_20160701Colibri_T20_LinuxImageV2.6Beta2_20160701Apalis_iMX6_LinuxImageV2.6Beta2_20160701Apalis_TK1_LinuxImageV2.6Beta2_20160701Apalis_T30_LinuxImageV2.6Beta2_20160701 | Max Krummenacher | |
Change-Id: I29b04f65475befb8d2b6917ed025a390ed071c7c Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-03-31 | manifest: update to latest jethroColibri_iMX6_LinuxImageV2.6Beta1_20160331Colibri_VF_LinuxImageV2.6Beta1_20160331Colibri_T30_LinuxImageV2.6Beta1_20160331Colibri_T20_LinuxImageV2.6Beta1_20160331Apalis_iMX6_LinuxImageV2.6Beta1_20160331Apalis_T30_LinuxImageV2.6Beta1_20160331 | Max Krummenacher | |
Change-Id: I729f51ea709fc8e571f781cf5750f2cd4ce753fc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-03-15 | manifest: update to jethroColibri_iMX7_LinuxImageV2.6Alpha1_20160315 | Max Krummenacher | |
Change-Id: Iebb4a2f8ec462c06b2edd790fcba69565c999ee3 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-12 | default.xml: move oe URL to github | Max Krummenacher | |
http://www.openembedded.org/wiki/Mirrors Change-Id: Iee8b2d5d3a6b6b4e9f6c4a6b01cbfd331178c987 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-12 | default.xml: shorten project names | Max Krummenacher | |
Move common URL name parts from <project> to <remote> Change-Id: I8c4122e1cb8d043a947ce5de9e466f56575a90a1 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-12 | default.xml: set all remote names to repo | Max Krummenacher | |
this allows to fetch all git repos with one command. repo forall -c git fetch repo Change-Id: I74894fe5c6c438f1ceaa40b5683bcbc00f4ec6af Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-12-15 | manifest: update to latest fidoColibri_iMX6_LinuxImageV2.5Beta3_20151215Colibri_VF_LinuxImageV2.5Beta3_20151215Colibri_T30_LinuxImageV2.5Beta3_20151215Colibri_T20_LinuxImageV2.5Beta3_20151215Apalis_iMX6_LinuxImageV2.5Beta3_20151215Apalis_T30_LinuxImageV2.5Beta3_20151215LinuxImageV2.5 | Max Krummenacher | |
Change-Id: I6d6e103d0c869bcd27fddb16ac68413b40db6b1e Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-12-09 | manifest: update to latest fido | Max Krummenacher | |
Change-Id: Ibc371e2d2a45e445675c58e5dc6410517f0ab225 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> |
