2017-01-11colibri_vf: disable UBIFS support by defaultStefan Agner
U-Boot has grown to big with the enablement of FIT image. Since we boot from a separate UBI volume, U-Boot does not need access to the UBIFS. Also fix the maximum size, also consider the text base offset in gfxRAM. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11toradex boards: enable FIT image supportStefan Agner
FIT image support is used by the upcoming Toradex Easy Installer and also can be useful for more advanced boot scenarios. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri t20/t30/tk1: distro boot integrationMarcel Ziswiler
Rather than relying on our separate proprietary storage media dependent boot commands use regular distro boot as a fall back. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis_t30: add optional pcie evalboard initialisationMarcel Ziswiler
Implement optional PCIe EvalBoard initialisation which properly reset the PLX (now Avago) PEX 8605 PCIe switch plus PCIe devices on the Apalis Evaluation carrier board. Please note that you will have to enable the second PCIe port in the dts as well e.g.: diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts index be4f4d6..321c7d6 100644 --- a/arch/arm/dts/tegra30-apalis.dts +++ b/arch/arm/dts/tegra30-apalis.dts @@ -59,6 +59,7 @@ }; pci@2,0 { + status = "okay"; nvidia,num-lanes = <1>; }; Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 340f51a210df1da640a57267e6c7fa56b8a852ed)
2017-01-11apalis-tk1: stop boot on recoveryMarcel Ziswiler
If U-Boot was launched via USB recovery mode stop auto booting. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri_t30: vdd core pmic handlingMarcel Ziswiler
Just release TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362 VSEL1 to switch VDD_CORE back to boot set 1 defaulting to 1.200V. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 622d408fea7af6d2ed778b546de346e90ea1a21f)
2017-01-11toradex boards: updating maintainers file with new web urlMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 0a9606863b0e7b8edfad02467a4e63c6c68025ee)
2017-01-11colibri_t20: implement early pmic rail configurationMarcel Ziswiler
Implement early TPS6586X PMIC rail configuration setting SM0 being VDD_CORE_1.2V to 1.2 volts and SM1 being VDD_CPU_1.0V to 1.0 volts. While those are PMIC power-up defaults the SoC might have been reset separately with certain rails being left at lower DVFS states which is e.g. the case upon watchdog reset while otherwise nearly idling. (cherry picked from commit f7c3186985ebb244d075b04ed7c055f39f485670)
2017-01-11apalis_t30: enable display driverMarcel Ziswiler
Enable the display driver on Apalis T30. Unfortunately the PWM pin muxing wasn't any good neither which made that display stay dark. (cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
2017-01-11colibri_t30: enable display driverMarcel Ziswiler
On popular request enable the display driver on Colibri T30. A few notes about some things encountered during porting: While analogue VGA (e.g. via the on-carrier RAMDAC) worked just fine from the beginning the EDT display flickered like crazy which turned out to be a pin muxing issue. Unfortunately the PWM pin muxing wasn't any good neither which made that display stay dark. Enjoy. (cherry picked from commit 201cc6d4e4c8213fbd103e74b0f2f2ca591edf54)
2017-01-11tegra: lcd: video: integrate display driver for t30Marcel Ziswiler
On popular request make the display driver from T20 work on T30 as well. Turned out to be quite straight forward. However a few notes about some things encountered during porting: Of course the T30 device tree was completely missing host1x as well as PWM support but it turns out this can simply be copied from T20. The only trouble compiling the Tegra video driver for T30 had to do with some hard-coded PWM pin muxing for T20 which is quite ugly anyway. On T30 this gets handled by a board specific complete pin muxing table. The older Chromium U-Boot 2011.06 which to my knowledge was the only prior attempt at enabling a display driver for T30 for whatever reason got some clocking stuff mixed up. Turns out at least for a single display controller T20 and T30 can be clocked quite similar. Enjoy. (cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
2017-01-11apalis_t30: comment about disabled pcie nodesMarcel Ziswiler
Add a comment about the disabled PCIe port nodes. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit f0adaf95b3edd1e8e23ebb0feab1f86eb77c9d84)
2017-01-11colibri_t20: fix ulpi reset polarityMarcel Ziswiler
Fix ULPI reset polarity which caused a hard hang on Colibri T20 upon attempting to start the USB subsystem: This fixes my late commit d5a24d8b53d350364bd429b7104ec369b817e4b8 (colibri_t20: fix usb operation and controller order) inadvertently having overwritten Stephen's previous commit 2f6a7e8ce5df8b99d84bfd486c6f99d92322ce04 (ARM: tegra: fix USB ULPI PHY reset signal inversion confusion). While at it also fix comment about on-module USB port. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit 3f33bd299fd438a04d37c3c25af1ab02a9b0d2f9)
2017-01-11colibri_t20: migrateMarcel Ziswiler
Migrate Colibri T20 to U-Boot 2016.11. (cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
2017-01-11tegra: nand: 16-bit bch ecc integrationMarcel Ziswiler
Integrate 16-bit BCH ECC handling required e.g. for the latest NAND parts assembled on Colibri T20. (cherry picked from commit dcca76ea36fc778fa750473aee09fa0297dc5e2b)
2017-01-11apalis/colibri: add device tree overlay support for all modulesStefan Agner
Device tree overlays might prove useful in the future, enable it by default on all our modules. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11cmd: fdt: Print error message when fdt application failsStefan Agner
There are lots of reason why a FDT application might fail, the error code might give an indication. Let the error code translate in a error string so users can try to understand what went wrong. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11libfdt: overlay: Fix missing symbols conditionStefan Agner
When there is no symbols section in the device tree, overlay_fixup_phandles should return FDT_ERR_NOTFOUND instead of FDT_ERR_BADOFFSET. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri_t30: fix l4t boot hang due to sbc1 clockMarcel Ziswiler
Fix the following boot hang observed when booting our downstream L4T R16.5 based BSP: [ 4.174349] tegra_dvfs: rate 408000000 too high for dvfs on sbc1 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri_t30: migrateMarcel Ziswiler
Migrate Apalis/Colibri T30 to U-Boot 2016.11. (cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
2017-01-11apalis/colibri_imx7/t20/t30/tk1/vf: update maintainer support status/informationMarcel Ziswiler
Add our support email address as well as our developer website as official maintenance point of contacts: Toradex ARM Support <support.arm@toradex.com> http://developer.toradex.com/software/linux/linux-software (cherry picked from commit c675aa26ad6a4a25d09c1079dda61ef24abd3770)
2017-01-11Revert "dm: tegra: Enable driver model for serial"Marcel Ziswiler
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting slower. With mainline Linux I noticed about a 1 to 2 second increase while booting downstream L4T takes 10 to 15 seconds longer! This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813. Conflicts: drivers/serial/Makefile (cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea) Conflicts: drivers/serial/serial_tegra.c include/configs/tegra-common.h (cherry picked from commit 4b97c4173ef96cfa4eb3ba4ea9121320efa90091)
2017-01-11colibri_imx7: disable usb start when using distroboot DHCPStefan Agner
There is no need to enumerate USB when trying to boot using DHCP. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_vf: synchronize environmentStefan Agner
Synchronize environment with current layout, order variables by name. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11e1000: unprogrammed i210 operation hackMarcel Ziswiler
Hack driver to avoid the following error for now. This is required for unprogrammed i210 operation. e1000: e1000#0: ERROR: Hardware Initialization Failed (cherry picked from commit 02bf24ad4a7c882e25771f656b973d5458695cf0) (cherry picked from commit 68cecfdbe342f800a0b1f10a1f8fb019b491f04b) (cherry picked from commit 2d8ea651b6da79047b6fa729863d25b5eb9e15d7)
2017-01-11colibri_imx7/vf: set fdtfile for distrobootStefan Agner
Set fdtfile to represent the current board. This allows distribution to load the correct device tree, which in the module case often deviates from the common fallback ${soc}-${board}${boardver}.dtb... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_imx7: use default dtb configurationStefan Agner
Use default CONFIG_OF_SEPARATE configuration which appends the device tree at the end of the U-Boot binary. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_imx7/vf: disable EFI loaderStefan Agner
The EFI loader is for most use cases not necessary so disable it by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11tools: mkimage: limit Vybrid image format for boards which use itStefan Agner
Not all Vybrid boards are using the new Vybrid image format, only add it as default target for boards which make use of it. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_vf/imx7: add distroboot supportStefan Agner
Add support for distro boot. This is especially helpful for external devices. There is a global boot command which scans a predefined list of boot targets: run distro_bootcmd As well as direct boot commands such as: run bootcmd_mmc0 run bootcmd_usb run bootcmd_dhcp ... Refer to doc/README.distro fo details. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri_imx6: add distroboot supportStefan Agner
Add support for distro boot. This is especially helpful for external devices. There is a global boot command which scans a predefined list of boot targets: run distro_bootcmd As well as direct boot commands such as: run bootcmd_mmc1 run bootcmd_mmc2 run bootcmd_usb run bootcmd_dhcp ... Refer to doc/README.distro fo details. While at it, remove the CONFIG_DRIVE_TYPES define which has not been used and was meant to be used for multi device boot support which is now provided by distroboot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11distro: allow to overwrite NET USB start commandStefan Agner
Boards with native ethernet support don't require USB start. This change lets a board configuration overwrite the NET USB command, so that U-Boot does not start USB for network boot by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11ARM: dts: vf: Fix warning about missing reg propertyStefan Agner
Add proper reg values for the two AIPS bus nodes. This avoids this two warnings: Node /soc/aips-bus@40000000 has a unit name, but no reg property Node /soc/aips-bus@40080000 has a unit name, but no reg property Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11video: dcu: add additional modes for DCUStefan Agner
Add common widescreen modes 800x480 and 1024x600. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11toradex: colibri_vf: Add default environment for framebuffer supportStefan Agner
Add environment variables for default framebuffer support using a default VGA mode. Also remove memargs, since we use memory size to reserve the framebuffer which does not get overwritten by the Linux kernel. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11video: dcu: fix framebuffer to the end of memoryStefan Agner
Fix the framebuffer location to the very end of the available memory. This allows to remove the area from available memory for the kernel, which in turn allows to display the splash screen through the while Linux kernel boot process. Ideas has been taken from the sunxi display driver, e.g. 20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory") Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11video: dcu: Add DCU support for Vybrid SoCStefan Agner
The Vybrid SoC family has the same display controller unit (DCU) like the LS1021A SoC. This patch adds platform data, pinmux defines and clock control to enable the driver for Vybrid based boards too. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11tools/env: fix environment alignment tests for block devicesMax Krummenacher
commit 183923d3e412500bdc597d1745e2fb6f7f679ec7 enforces that the environment must start at an erase block boundary. For block devices the sample fw_env.config does not mandate a erase block size for block devices. A missing setting defaults to the full env size. Depending on the environment location the alignment check now errors out for perfectly legal settings. Fix this by defaulting to the standard blocksize of 0x200 for environments stored in a block device. That keeps the fw_env.config files for block devices working even with that new check. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11colibri_vf: synchronize/improve memory optionsStefan Agner
Synchronize initramfs related configuration options and improve memory layout. The memory layout with an offset of 16MiB allows to boot bigger kernels. With AUTO_ZRELADDR, which is pretty much the standard nowadays, the kernel relacates itself to PC masked with 0xf8000000 plus a text offset of 0x8000 (hence 0x80008000 for Vybrid). With a 16MiB offset from the start of memory and a 16MiB distance to the device-tree, we allow kernel up to ~16MiB. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11colibri_vf: sort fdt_file alphabeticallyStefan Agner
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11configs: colibri_vf: Add fdt_fixup environment variableSanchayan Maity
u-boot allows modifying a device tree after it is loaded into memory. Add fdt_fixup hook in u-boot environment which can facilitate such modifications. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> (cherry picked from commit faf1e62bf04b01dc7110a459f558aaf414bfcac0)
2017-01-11colibri_vf: introduce automatic ethernet update capabilitySanchayan Maity
Introduce Ethernet update capability via setethupdate which is automatically tried by setupdate as well should SD and USB update fail (e.g. neither an SD card nor an USB memory stick with our flash_blk.img script and accompanying artefacts is inserted. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11colibri_vf: Read kernel and device tree from static UBI volumesSanchayan Maity
Our update scripts write the kernel and device tree in seperate UBI volumes. This allows to use a lot less UBI/UBIFS support in U-Boot, which should lower the risk of hitting bugs in this area. Boot times are also slightly faster (measurements showed an improvement of ~150ms). Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11board: colibri_imx7: avoid using DDR reserved for Cortex-M4Stefan Agner
Using linux,usable-memory the board code carves out 1MiB of memory for the Cortex-M4 core at the end of the 256MiB block. However, in case a board has 256MiB of memory (Colibri iMX7S), that is the area where U-Boot gets relocated to... Use board_get_usable_ram_top to avoid using that area as relocation target. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11board: colibri_imx7: reserve DDR memory for Cortex-M4Stefan Agner
i.MX 7's Cortex-M4 core can run from DDR and uses DDR memory for the rpmsg communication. Both use cases need a fixed location of memory reserved. For the rpmsg use case the reserved area needs to be in sync with the kernel's hardcoded vring descriptor location. Use the linux,usable-memory property to carve out 1MB of memory in case the M4 core is running. Also make sure that the i.MX 7 specific rpmsg driver does not get loaded in case we do not carve out memory. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11common: fdt_support: Add support for setting usable memorySanchayan Maity
Add support for setting the linux,usable-memory in the memory node of device tree. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11imx-common: add declaration for arch_auxiliary_core_check_upStefan Agner
Add declaration for arch_auxiliary_core_check_up which can be useful to add board specific behavior. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11cmd_writebcb_mx7: add command to write FCB and DBBT for i.MX 7Max Krummenacher
Code mostly ported from imx-kobs-5.3. MTD partitioning is set accordingly. writebcb: Write Boot Control Block (FCB and DBBT) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> [ported to U-Boot 2016.11] Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11imx: add writebcb commandStefan Agner
Add writebcb command which creates a NAND Boot Configuration Block (BCB) at the beginning of the active flash device. The BCB stores the information for the SoC internal boot ROM where the application with a valid IVT header can be found on the NAND device. The first two argument of the command need an offset of the NAND device where the primary and secondary application can be found. Typically, U-Boot is the application which gets loaded by the boot ROM. Hence, the offset address need to be the address where U-Boot (u-boot.imx along with a 0x400 long prefix) is stored on the device. At least one location is mandatory. Currently only the FCB (Firmware Configuration Block) is written to the device. The DBBT (Discovered Bad Block Table) is optional and not created by writebcb currently. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11mtd: nand: use mtd_to_nand in mxs_nand_get_ecc_strength tooStefan Agner
The MTD subsystem now uses mtd_to_nand to get to the struct nand_chip pointer. Use mtd_to_nand in mxs_nand_get_ecc_strength too. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
