2018-03-21colibri_t20: fix passing mac address via dtColibri-iMX7_LXDE-Image_2.8b2.97-20180331Colibri-iMX6_LXDE-Image_2.8b2.97-20180331Colibri-iMX6ULL_LXDE-Image_2.8b2.97-20180331Colibri-VF_LXDE-Image_2.8b2.97-20180331Colibri-T30_LXDE-Image_2.8b2.97-20180331Colibri-T20_LXDE-Image_2.8b2.97-20180331Apalis-iMX6_LXDE-Image_2.8b2.97-20180331Apalis-TK1_LXDE-Image_2.8b2.97-20180331Apalis-TK1-Mainline_LXDE-Image_2.8b2.97-20180331Apalis-T30_LXDE-Image_2.8b2.97-20180331Marcel Ziswiler
T20 uses different addresses for its EHCI controllers which I missed. Fix this. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-21apalis_t30/tk1/colibri_t20/t30: integrate mac address via dtMarcel Ziswiler
Use device tree to set MAC address of the Ethernet chip. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-21colibri_t20: integrate mtd partitions via dtMarcel Ziswiler
Use device tree to set MTD partitions of the NAND chip. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-21tools/env: allow equal sign as key value separationStefan Agner
Treat the first equal sign as a key/value separation too. This makes the script files compatible with mkenvimage input file format. It won't support variables with equal signs anymore, but this seems not really like a loss. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21apalis/colibri_imx6: remove white space after string endStefan Agner
The white spaces after the zero string terminator are applied to the following environment entry. This is not what was intended. Remove the superfluous white spaces. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21script: Make the get_default_envs.sh script working with newest u-bootLukasz Majewski
This commit fixes several issues: - Use ${OBJCOPY} if available, fallback to system default's objcopy if not present. - Extend the script to accept different build directory than current one. It is extremely handy with OE usage, where source code is separated from build. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> [Backported to 2016.11] Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 0778e7c50ba1904943a1d6b5194c29d1fee33334)
2018-03-21colibri_vf_defconfig: enable MTD partitions via dtStefan Agner
Use device tree to set MTD partitions of the NAND chip. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21arm: dts: imx7: add UART2/UART3Stefan Agner
This allows to change U-Boots default UART by simply changing stdout-path in the device tree. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21apalis/colibri: switch to zimageBhuvanchandra DV
Switch to the generic compressed Kernel image type (zImage) instead of the U-Boot specific uImage format. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21tdx-cfg-block: add new SKUsStefan Agner
2018-03-21imx: initialize and use generic timer on i.MX 6UL/ULLStefan Agner
The i.MX 6UL/ULL feature a Cortex-A7 CPU which suppor the ARM generic timer. This change makes use of the ARM generic timer in U-Boot. This is crucial to make the ARM generic timers usable in Linux since timer_init() initalizes the system counter module, which is necessary to use the generic timers CP15 registers. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21imx: introduce CONFIG_GPT_TIMERStefan Agner
Introduce a new config symbol to select the i.MX General Purpose Timer (GPT). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21imx: move CONFIG_SYSCOUNTER_TIMER to KconfigStefan Agner
2018-03-21colibri-imx6ull: add MTD fixup compatible for mainline kernelsStefan Agner
In upstream Linux the GPMI NAND node of i.MX 6UL/6ULL uses "fsl,imx6q-gpmi-nand" as compatible string. Add both to make sure U-Boot fixups the MTD partitions for downstream and upstream kernels. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-20colibri_imx7: do not mux SODIMM 169 as NAND chip selectStefan Agner
The pad SAI1_RX_DATA can be used as second chip select for dual-die NAND. However, with an assembly option the pad is available as GPIO on SODIMM 169. All current version of Colibri iMX7 modules have the pad available as GPIO hence do not mux the pin so that it is available as GPIO by default. This follows a similar commit in Linux ("arm: dts: imx7: mux pad of SODIMM 169 as GPIO") Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-20apalis-tk1: add pcie_aspm=off to defargsDominik Sliwa
Disabling ASPM fixes incompatibilities with some PCIe cards Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22apalis/colibri: disable undefined instruction events in user debugColibri-iMX7_LXDE-Image_2.8b1.64-20171229Colibri-iMX6_LXDE-Image_2.8b1.64-20171229Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229Colibri-VF_LXDE-Image_2.8b1.64-20171229Colibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-iMX6_LXDE-Image_2.8b1.64-20171229Apalis-TK1_LXDE-Image_2.8b1.64-20171229Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229Stefan Agner
It turns out that OpenSSL calls undefined instructions to detect ARM capabilities at runtime (via SIGILL handler). This leads to stack traces e.g. when logging in using SSH: [ 877.464442] sshd (613): undefined instruction: pc=76ee2da8 ... Disable undefined instruction events since it is used as an autodetecion mechanism. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22colibri_imx6ull: add sensible default DFU configurationStefan Agner
Add DFU configuration which allows access to all MTD partitions. Note that DFU is mostily suited for smaller image uploads e.g. to update U-Boot but does not work well for large images such as rootfs since DFU copies the whole image in a memory buffer first. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-20apalis/colibri: enable user debug by defaultStefan Agner
Let the kernel print some debug messages when a user program crashes due to an exception. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-27apalis: unify configsColibri-iMX6ULL_LXDE-Image_2.7b5-20171201Apalis-TK1_LXDE-Image_2.7b5-20171201Max Krummenacher
Follow commits 59b9b3dfb and 2533000f4 which: unified the USB PID when the config block is missing added CONFIG_OF_LIBFDT_OVERLAY Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-11-27toradex apalis/colibri: set version variable for all modulesMax Krummenacher
Set the ver environment variable consistently in all modules. Move the define form include/configs into the defconfig were applicable and create a new minimal defconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-11-27colibri_imx6ull: add dtb for wifi variantMax Krummenacher
Add handling for the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-11-27colibri_imx6ull.c: remove dead codeMax Krummenacher
2017-11-27imx: imx6ull: correct get_cpu_speed_grade_hzMax Krummenacher
backport commit 0c7c6fb7641646c45630235ea906200981f4fe80: i.MX6ULL has different speed grades than i.MX6UL. Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-11-22MLK-14839-2 imx: clean up print info for thermal and reset causeYe Li
Clean up the print info, so that the reset cause print can display in a new line. Signed-off-by: Ye Li <ye.li@nxp.com> (cherry picked from commit f84b9d512f92b66076357820b1003a1006ff619d)
2017-11-22MLK-14839-1 mx6: Fix wrong CPU frequencyYe Li
Fix incorrect value for 696MHz CPU frequency on i.MX6UL. Signed-off-by: Ye Li <ye.li@nxp.com> (cherry picked from commit 0b70df1d0e888d046cec4bd030c78eb746270ec0)
2017-11-22envtools: make sure version/timestamp header file are availableStefan Agner
With commit 84d46e7e8948 ("tools: env: allow to print U-Boot version") the fw_env utilities need the version.h header file. Building only the envtools in a pristine build directory will fail due to missing header files. Make sure the header files are a dependency of the envtools target. Fixes: 84d46e7e8948 ("tools: env: allow to print U-Boot version") Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-11-22tools: env: allow to print U-Boot versionStefan Agner
The fw_env utility family has a default environment compiled in which ties it quite strongly to the U-Boot source/config it has been built with. Allow to display the U-Boot version it has been built with using the -v/--version argument. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> (cherry picked from commit 84d46e7e8948780d7ca20c24dfc7b653b900f728)
2017-10-03apalis-tk1: support v1.2 hardware revisionColibri-iMX7_LXDE-Image_2.7b4-20171005Colibri-iMX6_LXDE-Image_2.7b4-20171005Colibri-VF_LXDE-Image_2.7b4-20171005Colibri-T30_LXDE-Image_2.7b4-20171005Colibri-T20_LXDE-Image_2.7b4-20171005Apalis-iMX6_LXDE-Image_2.7b4-20171005Apalis-TK1_LXDE-Image_2.7b4-20171007Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005Apalis-T30_LXDE-Image_2.7b4-20171005Marcel Ziswiler
Support the V1.2 hardware revision with the following pin muxing changes: Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4 are now used as DDC pins. Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are now used as USB power enable signals. Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power enable signals are now used as GPIO3 and GPIO4. Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is loaded on V1.2 and later modules and resp. USB power enable signals activated. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03apalis-tk1: rename fan enable gpio signalMarcel Ziswiler
Rename IXORA_FAN_GPIO to FAN_EN as per schematics. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03lib/bch.c: modify algorithm for all writebcb usersMax Krummenacher
With the Colibri iMX6ULL there is a second user of the bch algorithms to encode the FCB. Use the more universal CONFIG_CMD_WRITEBCB_MX7 to decide if the modifications are needed. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03colibri-imx6ull.h: unify with changes in colibri_imx7.hMax Krummenacher
Remove m4boot options not available on i.MX 6ULL. Cleanup U-Boot environment settings. This undefs CONFIG_ISO_PARTITION. This removes NAND torture no longer needed after bringup. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03colibri-imx6ull.h: cleanup whitespaceMax Krummenacher
Cleanup whitespace and unify order with colibri_imx7.h. No functional change intended. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03colibri-imx6ull.h: remove unused configsMax Krummenacher
Remove/change two NAND releated configs. They are not used in the GPMI driver and likely confuse readers. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-02colibri-imx6ull: make sure MTD partitions get passedStefan Agner
Use the correct compatible string for the i.MX6ULL GPMI device tree node to make sure MTD partition passing to the Linux kernel works. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02mtd: nand: mxs_nand: support chips without ONFI/JEDEC parameter pageStefan Agner
Some NAND chips do not provide a ONFI or JEDEC parameter page. In this case the driver should fallback to a sensible default. The kernel uses legacy_set_geometry to set a default geometry in this case. U-Boot does support the legacy BCH geometry too, but errors out if no ONFI/JEDEC parameter page is available. Synchronize behavior with Linux where we automatically fall back to legacy BCH geometry if no information from ONFI/JEDEC parameter page are available. Assume default chunk/step size of 512 like the Linux kernel is doing. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri-imx6ull: use SDP if USB serial downloader has been usedStefan Agner
In case USB serial downloader has been used to load U-Boot start the serial download protocol (SDP) emulation. This allows to download complete images such as Toradex Easy Installer over USB SDP as well. This code uses the boot ROM provided boot information to reliably detect USB serial downloader. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7_emmc: legacy sdboot from external sd cardMarcel Ziswiler
Just like the following commit for distro boot also use the 2nd instance for legacy sdboot: colibri_imx7_emmc: distro boot from external SD card 93ef92091832128259ab342a314d0f3e844bb331 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02apalis/colibri_imx6: fix white spaceMarcel Ziswiler
2017-10-02apalis-tk1/colibri_t20: fix and synchronize mount options 2ndMarcel Ziswiler
Finish the work started by the following commit: apalis/colibri: fix and synchronize mount options 6ed47e0f143df1c80426edb3b705c87c443c27f7 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7_emmc: distro boot from external SD cardStefan Agner
Currently distro boot is only used for external media. Use mmc 1 which is the external SD card when booting using distro boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-02colibri_imx7_emmc: fix environment storageMarcel Ziswiler
Store U-Boot environment in eMMC, before config block at the end of 1st "boot sector". Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7_emmc: fix boot commandsMarcel Ziswiler
Use proper emmc specific device tree and boot from eMMC by default rather than from NAND aka ubi. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7_emmc: clean-up config header fileMarcel Ziswiler
Clean-up config header file. Re-order boot commands. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7: get rid of environment in mmc optionMarcel Ziswiler
2017-10-02colibri_imx7: clean-up config header fileMarcel Ziswiler
2017-10-02apalis/colibri: fix and synchronize mount optionsStefan Agner
The kernel does not know about rw,noatime. The string rw by itself is valid, and to pass additional arguments rootflags=noatime can be used. The kernel mounts ext3/ext4 file systems by default ro, hence so far the kernel mounted the rootfs read-only. The init manager systemd then remounts the rootfs after file system checking. This makes sense and does not add measureable boot time. Let the kernel explicitly mount ro on block device based rootfs. The root mount flag noatime is only relevant when re-mounting read-write, hence it needs to be present in /etc/fstab. UBIFS used on raw NAND devices has no user space file checking, hence there is no value to mount it in read-only first. Also mount time for UBIFS is larger, and mounting first read-only and then read-write has higher boot time (300ms, likely due to missing block cache). Let the kernel explicitly mount rw on raw NAND based rootfs. UBIFS has no atime support, hence no root mount flags needed. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-02colibri_imx7: improve DDR3 timingStefan Agner
This makes sure that all Colibri iMX7 modules work with the same timing. The changes are: - Disable ODT on read (JEDEC standard JESD79-3F says in chapter 5.2.3 ODT during Reads: "As the DDR3 SDRAM can not terminate and drive at the same time, RTT must be disabled at least half a clock cycle..." and also MX7D SABRESD is disabling it) This alone fixed memory issues for two Colibri iMX7 1GB modules which showed issues before - Make sure tRFC(min) is at least 260ns - Make sure tRC is >50.625ns - tRP needs to be >13.125ns, we can lower from 18.75ns to 15ns - tFAW is not relevant, leave at reset Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31colibri_imx7_emmc: add Colibri iMX7 Dual 1GB (eMMC) supportStefan Agner
This adds support for Colibri iMX7 Dual 1GB modules which come with on-board eMMC storage (whereas the other Colibri iMX7 modules use raw NAND). A subselection (variant) for the Colibri iMX7 target is used to maximize sharing. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31toradex: remove ISO partition supportStefan Agner
The ISO partition support is mainly useful for CD drives which are not really common in embedded space and in general anymore. Removing ISO partition support saves 1.5kB and gets rid of the somewhat confusing message when no partition table is present: ** First descriptor is NOT a primary desc on 0:1 ** Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
