2002-11-05 | * Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120 | wdenk | |
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board | |||
2002-11-04 | Patch by Guillaume Alexandre,, 04 Nov 2002: | wdenk | |
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code | |||
2002-11-03 | * Fix mdelay() on TRAB - this was still the debugging version with | wdenk | |
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README. | |||
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings, and README. | |||
2002-11-03 | Initial revision | wdenk | |
2002-11-02 | Initial revision | wdenk | |
2002-11-01 | Initial revision | wdenk | |
2002-10-31 | Initial revision | wdenk | |
2002-10-29 | Initial revision | wdenk | |
2002-10-28 | Initial revision | wdenk | |
2002-10-27 | Initial revision | wdenk | |
2002-10-26 | Initial revision | wdenk | |
2002-10-25 | Initial revision | wdenk | |
2002-10-24 | Initial revision | wdenk | |
2002-10-21 | Initial revision | wdenk | |
2002-10-20 | Initial revision | wdenk | |
2002-10-19 | Initial revision | wdenk | |
2002-10-17 | Initial revision | wdenk | |
2002-10-16 | Initial revision | wdenk | |
2002-10-11 | Initial revision | wdenk | |
