2002-11-11 | * Patch by Andreas Oberritter, 09 Nov 2002: | wdenk | |
Change behaviour of NetLoop(): return -1 for errors, filesize otherwise; return code 0 is valid an means no file loaded - in this case the environment still gets updated! * Patches by Jon Diekema, 9 Nov 2002: - improve ADC/DAC clocking on the SACSng board to align the failing edges of LRCLK and SCLK - sbc8260 configuration tweaks - add status LED support for 82xx systems - wire sspi/sspo commands into command handler; improved error handlering - add timestamp support and alternate memory test to the SACSng configuration | |||
2002-11-10 | * Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310 | wdenk | |
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers | |||
2002-11-05 | Quick & Dirty fix for log buffer problem when environment is not set | wdenk | |
Trigger watchdog when reading the env - this might take a while. Set debugging baud rate for KUP4K board | |||
2002-11-05 | * Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735 | wdenk | |
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board | |||
2002-11-05 | * Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120 | wdenk | |
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board | |||
2002-11-04 | Patch by Guillaume Alexandre,, 04 Nov 2002: | wdenk | |
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code | |||
2002-11-03 | * Fix mdelay() on TRAB - this was still the debugging version with | wdenk | |
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README. | |||
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings, and README. | |||
2002-11-03 | Initial revision | wdenk | |
2002-11-02 | Initial revision | wdenk | |
2002-11-01 | Initial revision | wdenk | |
2002-10-31 | Initial revision | wdenk | |
2002-10-29 | Initial revision | wdenk | |
2002-10-28 | Initial revision | wdenk | |
2002-10-27 | Initial revision | wdenk | |
2002-10-26 | Initial revision | wdenk | |
2002-10-25 | Initial revision | wdenk | |
2002-10-24 | Initial revision | wdenk | |
2002-10-21 | Initial revision | wdenk | |
2002-10-20 | Initial revision | wdenk | |
2002-10-19 | Initial revision | wdenk | |
2002-10-17 | Initial revision | wdenk | |
