Display proper reset reason after the SoC info.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit fbcb9256549453b6e81a9a01ef6475b452c9f1ed)
Disabling ASPM fixes incompatibilities with some PCIe cards
(cherry picked from commit f7c668a4e8dce3975a7c07834c448584f768a44f)
Let the kernel print some debug messages when a user program
crashes due to an exception.
(cherry picked from commit 11d96e122a29eab51242b6502dd7ff9cce533fef)
Use unified values for USB Product/Vendor numbers
when the config block is missing
(cherry picked from commit 8fd734c49cc3dd0c5bc57b4922120483688e3099)
Make sure the Apalis GPIO 8 aka FAN_EN is on when using Apalis TK1
modules.
(cherry picked from commit 538ab6c0a1a51da0caf9525607499e8cd6ef12b7)
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing
RESET_MOCI#.
Please note that module hardware versions up to V1.1A will already
release RESET_MOCI# in hardware coming out of reset.
Please further note that with this change the USB hub on the Apalis
Evaluation board is kept in reset in U-Boot and therefore none of its
ports are operational in U-Boot.
(cherry picked from commit 5b5de78b4a6ff8c2bbd71a6b51d6fdf32f420eef)
Concept: store all console-related kernel parameters
in dedicated variable.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Unfortunately, that missing M makes the current downstream NXP BSP
4.14.98_2.0.0_ga crash early during Linux kernel boot. Fix this.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Tested-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Fix issue as reported by checkpatch.pl. Leave long lines as line
continuation in text output is not recommended.
The Apalis iMX8 was missing the interactive part should a customer have
bricked his module and want to re-create the configuration block. Fix
this.
The Colibri iMX8X target got re-named late in the cycle which we forgot
to reflect here. Furthermore, it was missing the interactive part should
a customer have bricked his module and want to re-create the
configuration block. Fix this.
Make the interactive Wi-Fi/BT handling generic by pulling it out of the
Colibri iMX6ULL interactive part to be re-used for Apalis iMX8 and
Colibri iMX8X.
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
While this seems to work on the eMMC SKU, unfortunately, this no longer boots on the raw NAND one.
This reverts commit edb411e2e6aeb7214641a53d78d1dc4a943290a0.
configs/colibri_imx7_defconfig
This got dropped by a global 'make savedefconfig' resync as required patches
are still in flight.
Use CONFIG_DM_VIDEO=y by default for Colibri iMX6ULL.
Provide proper display timings for lcdif node, used by mxsfb DM_VIDEO
enabled framebuffer driver.
1. This fixes linking issues when building with DM_VIDEO enabled mxsfb
driver.
2. Provide proper defines for both VIDEO=y and DM_VIDEO=y.
Enable DM_VIDEO support for Colibri iMX7 NAND version.
Fix lcdif DT node and make it conform to the structure defined in the
Linux devicetree bindings [1]. Currently there is support only for
old style lcdif node definitions.
[1] https://www.kernel.org/doc/Documentation/devicetree/bindings/display/mxsfb.txt
Add support for display and bits-per-pixel properties.
We never really added a sensible DFU configuration for platforms
based on eMMC. Most of the things one might want to do can also be done
with UMS or fastboot, so drop the DFU configuration.
Enable DM_VIDEO for Colibri VF.
Add dumb node for NXP Display Control Unit0(DCU), which permits DM_ENABLED
converted driver to be probed. Currently no display timings are provided
in this node.
Extend the driver to build with DM_VIDEO enabled. DTS files
must additionally include 'u-boot,dm-pre-reloc' property in
soc and child nodes to enable driver binding to fsl_dcu_fb device.
Currently display timings aren't obtained from DT.
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init()
only legacy video stack (filling GraphicPanel struct etc.).
Add wrappers for all init functions, that will let to provide
struct fb_info as an additional param (needed for further moving it from
the global scope to driver private data struct in DM converted driver).
cpu_imx_get_temp() definition is wrapped with a ifdef macro, which leads
to warnings if CONFIG_IMX_SCU_THERMAL isn't defined and there are still
references to this function, as, for example, in cpu_imx_get_desc().
Drop ifdef as linker will automatically remove the function
in case CONFIG_IMX_SCU_THERMAL is not enabled.
Fix warning:
arch/arm/mach-imx/imx8/cpu.c: In function ‘cpu_imx_get_desc’:
arch/arm/mach-imx/imx8/cpu.c:612:40: warning: implicit declaration of
function ‘cpu_imx_get_temp’; did you mean ‘cpu_imx_get_desc’?
[-Wimplicit-function-declaration]
ret = snprintf(buf, size, " at %dC", cpu_imx_get_temp());
cpu_imx_get_desc
cpu_imx_get_desc
Fixes: 82467cb217 ("imx8: cpu: get temperature when print cpu desc")
Added default environment for hdp loading.
Added hdp loading as default for iMX8QM MEK board.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from downstream commit 432e5b4347841095c3b5a8a0d106f35deadd006e)
(cherry picked from downstream commit cb78a32fa8eb8c37932be003ebe4fa1f8c46c1d5)
Adding the HDP firmware loading to the build.
(cherry picked from downstream commit d4702582552aa1921fce58329ae40c24481fba3a)
This adds a command to load the HDP firmware and supporting libraries.
(cherry picked from downstream commit 94c9c7022c5b6cffb74bb2e34336cffc2790d0d8)
(cherry picked from downstream commit 21edff320e763585ebc6ab2d997c994561b69292)
Use streamids specified in dtb because they need to match anyway. This
removes the need to rebuild uboot for stream id assignments.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from downstream commit 3caa05e6dc973b8710642f27f834bf022fbb65b4)
Before starting the kernel, need to check if the enabled nodes (resources) in FDT
are owned by current partition. If it is not owned, need to disable it because A core
can't access it.
We use the node's power-domain property to get the PD node which has the SCFW resource
id in its reg property. Then we can check it with SCFW.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from downstream commit 358372674b29685788a4007b0944ab03b7fafc13)
We setup SMMU in arch_preboot_os to avoid breaking u-boot driver.
Add a kconfig entry CONFIG_IMX_SMMU to enable it.
So far, the USDHC0-USDHC1 and FEC0-FEC1 are added into sid.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from downstream commit 7da6345919ee59a26cf65b4bc29072eea2fc0909)
(cherry picked from downstream commit 45308e7da90f342c2de7fbec1f8c5b8bd3f1b8e5)
Add sc_rm_set_master_sid to support setting stream IDs.
Add thermal dts node
Enable thermal in defconfig
Add i.MX8 thermal driver to support get temperature from SCU.
Add sc_misc_get_temp to support get temperature
https://gitlab.denx.de/u-boot/custodians/u-boot-mips
- mtmips: network stability fixes for gardena-smart-gateway
The watchdog of mediatek chips is enabled by bootrom before u-boot is
running. Previously we choose to enable the wdt driver only to disable the
watchdog hardware.
Now wdt service is enabled by default. The function arch_misc_init which is
only used to disable wdt is no longer needed.
Reviewed-by: Ryder Lee <ryder.lee@mediatek.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
The initr_watchdog is currently placed before initr_serial. The
initr_watchdog calls printf and printf finally calls ops->putc of a serial
driver.
However, gd->cur_serial_dev points to a udevice allocated in board_f. The
gd->cur_serial_dev->driver->ops->putc points the the code region before
relocation.
Some serial drivers call WATCHDOG_RESET() in ops->putc. When DM is enabled
for watchdog, watchdog_reset() is called. watchdog_reset() calls get_timer
to get current timer.
On some platforms the timer driver is also a DM driver. initr_watchdog is
placed right after initr_dm, which means the timer driver hasn't been
initialized. So dm_timer_init() is called. To create a new udevice, calloc
is called.
However start from ops->putc, u-boot execution flow is redirected into the
memory region before relocation (board_f). In board_f, dlmalloc hasn't
been initialized. The call to calloc will fail, and this will cause DM to
print out an error message, and it will call printf again, causing
recursive error outputs.
This patch places initr_watchdog after initr_serial to solve this issue.
Cc: Stefan Roese <sr@denx.de>
Tested-by: Frank Wunderlich <frank-w@public-files.de>
Tested-by: Suniel Mahesh <sunil.m@techveda.org>
Fix booting for wandboard
https://gitlab.denx.de/u-boot/custodians/u-boot-video
- fix pwm backlight
One of the SD-CARD slots on the Wandboard Quad B1 is MMC 2. Enable it as a
boot device.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
- DWC and i.MX6 fixes
