Fix trailing white space, indentation by spaces instead of TABs,
excessive blank lines, trailing blank lines.
Commit bdbcdc89 "pxa: convert pxa27x_udc to use read and write
functions" added a number of C++ comments. Fix these.
do_env_import() missed the final '\0' terminator when calculating the
size of an environment data block. This led to an erroneous 'bad CRC,
import failed' message for a checksum protected environment (-c.)
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
Several bugfixes have occurred upstream since this script was imported
into U-Boot. In particular, the script currently in U-Boot does not
describe commit f8bbb4dad0e9d91b7a51d6cc54dcf66d142f50fe correctly,
resulting in a version of "2011.09" instead of "2011.09-01460-gf8bbb4d".
With that commit checked out, the command "git name-rev --tags HEAD"
gives this result:
HEAD tags/v2011.12-rc1~30^2
Then the "changes" regex does not match because of the trailing '^2':
grep -E '^HEAD[[:space:]]+(.*~[0-9]*|undefined)$'
The new version of tools/setlocalversion in the kernel correctly handles
those situations by using different plumbing commands.
The version from the kernel is not directly usable as it does not append
the full GIT version that U-Boot expects unless the right config options
are set (CONFIG_LOCALVERSION_AUTO=y). Other than a few minor changes
for Kconfig, the imported version is very similar to Linux v3.2-rc4.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Cc: Mike Frysinger <vapier@gentoo.org>
* 'master' of git://git.denx.de/u-boot-usb:
USB: Use (get|put)_unaligned for accessing wMaxPacketSize
usb:gadget:s5p Enable the USB Gadget framework at Exynos4210 (C210 Universal)
README: add documentation for CONFIG_USB_ULPI*
USB: ULPI: increase error case verbosity
USB: ULPI: clean a mixup of return types
USB: ULPI: switch argument type from u8 to unsigned
In 9792987721c7980453fe6447c3fa6593b44f8458 Stefan describes a usecase
where the previous behavior of leaving wMaxPacketSize be unaligned
caused fatal problems. The initial fix for this problem was incomplete
however as it showed another cases of non-aligned access that previously
worked implicitly. This switches to making sure that all access of
wMaxPacketSize are done via (get|put)_unaligned.
In order to maintain a level of readability to the code in some cases
we now use a variable for the value of wMaxPacketSize and in others, a
macro.
Cc: Remy Bohmer <linux@bohmer.net>
OpenRISC:
Tested-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Beagleboard xM, Pandaboard run-tested, s5p_goni build-tested.
This commit enables support for USB Gadgets on the Exynos4210 (C210 Universal)
reference target.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
CC: Remy Bohmer <linux@bohmer.net>
Add documentation for CONFIG_USB_ULPI and CONFIG_USB_ULPI_VIEWPORT
configuration options.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Add the argument value to the error message.
Clean a mixup between u32 and int as a return type
for functions returning error values.
Use int as it is native (and widely used) return type.
There is no benefit in using u8, so switch to unsigned to reduce the
binary image size (by 20 bytes).
In the current u-boot code, the value of these fields are the reserved
value (0b100), through the signal integrity measurement on freescale's
board with these reserved setting, the signal eye is out of the recommended
spec for non-transition amplitude at 500mV nominal.
According to the errata for MPC8379E, we should make a change to the
recommended setting from essentially nothing at this time to 0b001 for SATA.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
pm9g45: init serial console before relocation
pm9261: init serial console before relocation
pm9263: init serial console before relocation
The "tb0229" board has long been unmaintained, and is broken.
Remove it.
Fix:
omap2420h4.c: In function 'dram_init':
omap2420h4.c:196:25: warning: variable 'cpu' set but not used
[-Wunused-but-set-variable]
Cc: Richard Woodruff <r-woodruff2@ti.com>
Cc: Tom Rini <trini@ti.com>
Fix:
reiserfs.c: In function 'reiserfs_mount':
reiserfs.c:360:22: warning: dereferencing type-punned pointer
will break strict-aliasing rules [-Wstrict-aliasing]
Fix:
../common/isa.c: In function 'handle_isa_int':
../common/isa.c:385:21: warning: variable 'isr2' set but not used
../common/isa.c:385:16: warning: variable 'isr1' set but not used
Signed-off-by: David Mueller <d.mueller@elsoft.ch>
The early messages can be seen on the debug console.
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at>
This board breaks MAKEALL -a mips due to compile errors.
This patch fixes only the parts causing the errors to get MAKEALL
working.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
We already flush the kernel image after we've loaded it to ensure
visiblity to the other cores. We need to do the same thing for the
ramdisk and device tree images. In AMP boot scenarios we might not be
HW cache coherent with the secondary core that we are loading and
setting the ramdisk and device tree up for. Thus we need to ensure
we've flushed the regions of memory utilized by ramdisk and device tree
so the loadding and any modifications (from decompression or fdt updates)
are made visible to the secondary cores.
Switch to extension board detection using pci_find_device()
instead of detecting by i2c access to EEPROM device on
extension board.
This is a cleaner detection method since EEPROM addresses
can be different on different board revisions. This also
avoids "i2c_read: failed to address chip" error messages
in the boot log on boards without extension board which
may confuse users.
USB: efikamx: Enable USB on EfikaMX and EfikaSB
USB: Add generic ULPI layer and a viewport
USB: EHCI: Allow EHCI post-powerup configuration in board files
USB: mx51evk: add end enable USB host support on port 1
USB: mx53loco: add end enable USB host support on port 1
USB: MX5: Add MX5 usb post-init callback
USB: MX5: Abstract out mx51 USB pixmux configuration
USB: MX5: add generic USB EHCI support for mx51 and mx53
USB: MX5: add helper functions to enable USB clocks
usb:gadget:s5p Enable the USB Gadget framework at GONI
usb:gadget:s5p USB Device Controller (UDC) implementation
ehci: speed up initialization
usb: add help for missing start subcommand
cosmetic: remove excess whitespace from usb command help
usb: align usb_endpoint_descriptor to 16-bit boundary
usbtty: init endpoints prior to startup events
pxa: convert pxa27x_udc to use read and write functions
pxa: activate the first usb host port on pxa27x by default
pxa: fix usb host register mismatch
ehci-fsl: correct size of ehci caplength
USB: Add usb_event_poll() to get keyboards working with EHCI
USB: gadaget: add Marvell controller support
USB: Fix complaints about strict aliasing in OHCI-HCD
USB: Drop dead code from usb_kbd.c
USB: Rework usb_kbd.c
USB: Add functionality to poll the USB keyboard via control EP
* 'master' of git://git.denx.de/u-boot-arm:
arm: add __aeabi_unwind_cpp_pr1() function to avoid linker complaints
post: fix compile issue for post tests on kirkwood
Cc: Wolfgang Grandegger <wg@denx.de>
Cc: Jason Liu <r64343@freescale.com>
Add partial ULPI specification implementation that should be enough to
interface the ULPI PHYs in the boot loader context.
Add a viewport implementation for Chipidea/ARC based controllers.
Signed-off-by: Jana Rapava <fermata7@gmail.com>
This patch allows USB to work on some hosts, which need additional frobing after
the host was powered up via regular USB powerup sequence.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
This is useful for USB Transceivers init etc.
It's derived from ehci-mxc and uses the header files of the
ehci-fsl interface. The callback board_ehci_hcd_init() has
been introduced to allow for board-specific setup when USB
is started.
CC: Stefano Babic <sbabic@denx.de>
V2: Fix spacing in crm_regs.h
This commit enables support for USB Gadgets on the GONI
reference target.
This commit provides UDC driver support for Samsung's SoC
family of processors.
According to EHCI specification v1.0, the controller should stabilize
the power on a port at most 20 ms after the port power bit transition.
So, we put this setting in the virtual descriptor corresponding field,
(bPwrOn2PwrGood = 10 => 10 x 2ms = 20ms), this saves about 500ms at each
controller initialization/enumeration.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
The usb_endpoint_descriptor struct is 7 bytes large and is
defined as an array (ep_desc[USB_MAXENDPOINTS])
in the usb_interface struct in include/usb.h
This fact will result in that every odd index in that
array will start at an uneven address, this in
turn makes accesses to u16 wMaxPacketSize unaligned.
Such accesses are illegal on the OpenRISC architecture
(as well as other architectures) and will render a bus error.
Setting the aligned(2) attribute on usb_endpoint_descriptor
will force wMaxPacketSize to a 16-bit boundary.
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
On some usb device controllers (pxa) the endpoint configuration must be programmed prior to enable it.
Signed-off-by: Stefan Herbrechtsmeier <sherbrec@cit-ec.uni-bielefeld.de>
CC: Marek Vasut <marek.vasut@gmail.com>
The pxa27x has 3 usb host ports. Activate all by default.
According to the EHCI specification the Capability Register Length
has a size of 8 bits.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Lei Wen <leiwen@marvell.com>
