2014-11-06am335x: make get_board_rev() function weakIgor Grinberg
Current get_board_rev() function returns a hard coded value which is obviously incorrect for the majority of boards. Allow boards to provide a correct implementation by making this function weak. In addition open code the trivial and useless BOARD_REV_ID define and adjust the comment. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@ti.com>
2014-11-06arm: am335x: net: pxm2: disable rgmii internal delay modeHeiko Schocher
disable internal delay through gmii_sel register, as this is done in the ar8031 phy. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2014-11-06ks2_evm: board: remove sprintf for simple stringKhoronzhuk, Ivan
There is no reason to sprintf simple string. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-06ks2_evm: config: enable fatload commandKhoronzhuk, Ivan
The keystone2 evm can boot from USB partition with FAT32 FS, so enable generic load command and fatload command usage. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06keystone2: config: align names of images with MCSDKKhoronzhuk, Ivan
The Multicore Software Development Kit (MCSDK) provides foundational software for TI KeyStone II device platforms. It's supposed to be used with uboot, and it's convenient to have the same names for images, so correct environment image names according to the last MCSDK3. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06keystone2: config: restructure handling of default env settingsMurali Karicheri
Currently to customize env for various ks2 boards, individual variables such as NAME_FS etc are defined and included in the common config.h to define CONFIG_EXTRA_ENV_SETTINGS. This doesn't scale well if a variable is not applicable on a specific board. Using this scheme, we have to define variables with empty value and it's ugly. Instead, to allow board specific customization of default env variable, define a common CONFIG_EXTRA_ENV_KS2_SETTINGS for all common variables and define board specific variables in individual board specific config.h using CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS. Use the common and board specific variables to define CONFIG_EXTRA_ENV_SETTINGS. This way more variables can be added in future for individual boards without affecting the other config.h files. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06dma: keystone_nav: remove spurious qm_cfg verificationKhoronzhuk, Ivan
The verification qm_cfg existence is done at ksnav_init(). So, there is no need to verify it after initialization. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06keystone2: change default boot mode to ubiMurali Karicheri
To allow out of box demo, change default boot mode to ubi boot now that NAND is functional in latest EVMs. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06ks2_evm: configs: fix UBI volume nameKhoronzhuk, Ivan
The UBI volume name has to be prefixed with "ubi:". Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06ARM: TI: omap3: remove raw initrd support in omap3_igep00x0 config file ↵Guillaume GARDET
since it is now in ti_armv7_common.h Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06ARM: TI: Enable raw initrd supportGuillaume GARDET
2014-11-06net: phy: marvell: add errata w/a for 88E151* chipsHao Zhang
As per Marvell Release Notes - Alaska 88E1510/88E1518/88E1512/88E1514 Rev A0, Errata Section 3.1 Marvell PHY has an errata which requires that certain registers get written in order to restart autonegotiation. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Stefan Roese <sr@denx.de>
2014-11-05Merge branch 'rmobile' of git://www.denx.de/git/u-boot-shTom Rini
2014-11-05ks2_evm: readme: add k2l evm board informationKhoronzhuk, Ivan
Currently Keystone2 Lamar evm (K2L) board is added, so update Keystone2 readme file to have such one. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05board: k2l_evm: add network supportHao Zhang
This patch adds network support code and enables keystone_net driver usage for k2l_evm evaluation board. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05net: keystone_net: add Keystone2 K2L SoC supportKhoronzhuk, Ivan
The Keystone2 Lamar SoC uses the same keystone net driver. This patch adds opportunity to use it by K2L SoCs. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05net: keystone_serdes: add keystone K2L SoC supportKhoronzhuk, Ivan
Keystone2 Lamar SoC uses the same keystone SerDes driver. All Keystone2 EVM boards currently use SerDes driver, so move CONFIG_TI_KEYSTONE_SERDES to common configuration file. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05ARM: keystone2: keysonte_nav: add support for K2L SoCKhoronzhuk, Ivan
The Keystone2 Lamar SoC uses the same keystone navigator. Move queue numbers to common hardware file, as all Keystone2 SoCs have the same ones. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05Enable Android Fastboot support on am335x_evm boardDileep Katta
Signed-off-by: Dileep Katta <dileep.katta@linaro.org> [trini: Rework so that am335x_evm_usbspl still builds] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-05twl4030: More voltages on VAUX2 and VAUX3Paul Kocialkowski
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2014-11-05am335x_evm: Convert NOR_BOOT to KconfigTom Rini
2014-11-05am335x_evm: Add NOR to KconfigTom Rini
Make enabling support for NOR (and describe where it's seen) be done via Kconfig. Signed-off-by: Tom Rini <trini@ti.com>
2014-11-05arm: mx6: cm_fx6: detect 1GB DRAM correctly on soloNikita Kiryanov
The 1GB DRAM configuration on mx6 solo uses 2 chip selects, but the code tests 1GB DRAM configuration as if it is all present on one chip select, and thus cannot see the full range of available memory. Refactor the check to detect 1GB DRAM correctly. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-11-05arm: mx6: cm_fx6: change issd gpio orderNikita Kiryanov
Change the order in which GPIOs are toggled in SATA init sequence to accomodate both SanDisk and Phison SSDs. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-11-05Merge git://www.denx.de/git/u-boot-sunxiTom Rini
2014-11-05Merge git://www.denx.de/git/u-boot-ppc4xxTom Rini
2014-11-05dm: sunxi: Request USB vbus gpioHans de Goede
This is necessary for the device-model enabled builds to work properly. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-05dm: sunxi: Request card detect gpioHans de Goede
2014-11-05dm: sunxi: Add support for serial using driver modelSimon Glass
Add a driver for the designware serial UART used on sunxi. This just redirects to the normal ns16550 driver. Add a stdout-path to the device tree so that the correct UART is chosen. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05dm: sunxi: Modify the GPIO driver to support driver modelSimon Glass
This adds driver model support to the sunxi GPIO driver, using the device tree to trigger binding of the driver. The driver will still operate without driver model too. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05dm: sunxi: Make sure that GPIOs are requestedSimon Glass
The scsi_init() function uses a GPIO so should request it. There is no way to return an error here, and the request may be made multiple times, so just ignore errors for now. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05dm: sunxi: Add pinmux functions which take a bank parameterSimon Glass
With driver model we will have access to a bank pointer, so we want to use it rather than converting back to a number, and then back to a bank pointer. Add functions to provide this feature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05dm: sunxi: Add a new config for an FDT-based pcDuino3Simon Glass
For now we won't want to mess with the existing configurations. Create a new one which will enable device tree and driver model. Note that this brings the device tree binary into u-boot-sunxi-with-spl.bin. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05dm: sunxi: dts: Add sun7i device tree filesSimon Glass
These are from Linux 3.17-rc7 (commit fe82dcec). U-Boot only uses a small portion of these, but we may as well have something to look forward to. The total compiled size is about 25KB. Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.Ian Campbell
$ make BOARD_felconfig is more convenient than $ make BOARD_defconfig $ echo CONFIG_SPL_FEL=y >> .config $ echo CONFIG_SPL_FEL=y >> spl/.config Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Introduce CONFIG_TARGET_<BOARD>Ian Campbell
This was done automatically with the following bits of scripting. The Kconfig choice content was generated with this script snippet: for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i); MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i) echo "config TARGET_$TARGET" echo " bool \"$TARGET\"" echo " depends on $MACH" echo done defconfigs were updated with a sed script (t): # Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS, /^CONFIG_SYS_EXTRA_OPTIONS/ { s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/; # Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving # CONFIG_TARGET_<BOARD> in pattern space P;D; }; # Move CONFIG_TARGET_<BOARD> to hold space /^CONFIG_TARGET/{h;n} # Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or # normal mode. /^CONFIG_MACH/{p;g;p;n}; /^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n}; # Print any remaining lines normally p; Run as: sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*) and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from Colombus_defconfig board/sunxi/Makefile was updated with: sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile and manually retabbing a few lines to line up again. The board descriptions could certainly be improved. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: Drop FEL variants of defconfigs.Ian Campbell
This can now be configured via Kconfig, e.g. with: $ make BOARD_defconfig $ echo CONFIG_SPL_FEL=y >> .config $ echo CONFIG_SPL_FEL=y >> spl/.config Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?IIan Campbell
Mostly automatic with: sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I) followed by removing the relevant #defines from include/configs/sun?i.h by hand. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: Kconfig: Make SPL_FEL a toplevel Kconfig optionIan Campbell
It's unfortunate that this needs to be present in both .config and spl/.config since it makes it slightly hard to enable FEL mode for a regular defconfig. It can be done with: echo CONFIG_SPL_FEL=y >> .config echo CONFIG_SPL_FEL=y >> spl/.config Ideally only one of those would be needed. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Rename TARGET_SUN[45678]I to MACH_SUN[45678]I.Ian Campbell
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the future. Done automatically with: sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I) Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Add top-level ARCH_SUNXIIan Campbell
And make TARGET_SUN[45678]I a choice variable under this. configs updated with: sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/* Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05ARM: sunxi: Fix Ippo-q8h-v5 defconfig filenameChen-Yu Tsai
The defconfig for Ippo-q8h-v5 was incorrectly committed as "Ippo_q8h". This patch renames it correctly, as well as correct a typo in my name in the maintainers listing. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05ppc: Fix ppc4xx CONFIG_SYS_GENERIC_BOARDDirk Eibach
I realized that with v2014.10 u-boot is not starting up on ppc4xx boards with CONFIG_SYS_GENERIC_BOARD set. I bisected it down to this: d54d7eb support blackfin board initialization in generic board_f With d29437a ppc: Make ppc4xx ready for CONFIG_SYS_GENERIC_BOARD I set gd to a defined value for ppc4xx in cpu_init_f(). I did not realize that the gd struct has also to be memset() to zero at this point. But at least commit d54d7eb assumes it is: @@ -516,11 +528,13 @@ static int reserve_malloc(void) /* (permanently) allocate a Board Info struct */ static int reserve_board(void) { - gd->start_addr_sp -= sizeof(bd_t); - gd->bd = (bd_t *)map_sysmem(gd->start_addr_sp, sizeof(bd_t)); - memset(gd->bd, '\0', sizeof(bd_t)); - debug("Reserving %zu Bytes for Board Info at: %08lx\n", - sizeof(bd_t), gd->start_addr_sp); + if (!gd->bd) { + gd->start_addr_sp -= sizeof(bd_t); + gd->bd = (bd_t *)map_sysmem(gd->start_addr_sp, sizeof(bd_t)); + memset(gd->bd, '\0', sizeof(bd_t)); + debug("Reserving %zu Bytes for Board Info at: %08lx\n", + sizeof(bd_t), gd->start_addr_sp); + } return 0; } #endif This might also be an issue on other architectures, so maintainers should check. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-11-04Merge git://git.denx.de/u-boot-shTom Rini
2014-11-04ARM: kwimage: fix v0 formatGerald Kerma
This patch fix the kwimage tools for version 0 fileformat used for kirkwood Tested on sheevaplug Signed-off-by: Gerald Kerma <drEagle@doukki.net> Tested-by: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2014-11-04MAINTAINERS: fix Pantelis Antoniou email addressIgor Grinberg
Trivial fix (unless Pantelis has a new email address): Pantelis Antoniou <panto.antoniou-consulting.com> ^ make it: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-11-04Fix cosmetic issues in mkimage manpageVagrant Cascadian
* Escape use of - in description of -F. * Fix line continuations in examples so that the continued lines are also bold. Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2014-11-04kbuild: do not hide clang warnings during build with W=1Masahiro Yamada
These lines originate in Linux; it looks like Linux folks chose to hide bunch of warnings reported by clang rather than fixing C code. In U-boot, warnings are being fixed thanks to Jeroen's great efforts. Let's stop suppressing clang warnings. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-11-04sparc: move CONFIG_SYS_TEXT_BASE to KconfigMasahiro Yamada
Defining CONFIG_SYS_TEXT_BASE in config.mk is very old style. Create CONFIG_SYS_TEXT_BASE option in Kconfig, but let it depend on CONFIG_SPARC because we do not want to disturb the other architectures that still define CONFIG_SYS_TEXT_BASE in their header files. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
