Although the two qemu-x86 targets (i440fx and q35) share a lot in
common, they still have something that cannot easily handled in one
single device tree). Split to create two dedicated device tree files
and make the i440fx be the default build target.
Clean up arch/x86/cpu/coreboot.c to fix several cosmetic issues.
FSP_TEMP_RAM_ADDR should only be visible when HAVE_FSP is on.
We should ignore those regions whose size is negative. These are
typically optional and unused regions (like GbE and platform data).
Change-Id: I65ad01746144604a1dc0588b617af21f2722ebbf
As VGA option rom needs to run at C segment, although QEMU PAM emulation
seems to only guard E/F segments, for correctness, move VGA initialization
after PAM decode C/D/E/F segments.
Also since we already tested QEMU targets to differentiate I440FX and Q35
platforms, change to locate the VGA device via hardcoded b.d.f instead of
dynamic search for its vendor id & device id pair.
QEMU always decode legacy IDE I/O ports on PIIX chipset. However Linux ata_piix
driver does sanity check to see whether legacy ports decode is turned on.
To make Linux ata_piix driver happy, turn on the decode via IDE_TIMING register.
By default the legacy segments C/D/E/F do not decode to system RAM.
Turn on the decode via Programmable Attribute Map (PAM) registers
so that we can write configuration tables in the F segment.
The default weak version of pci_skip_dev() in drivers/pci/pci_common.c
skips the host bridge (b.d.f = 0.0.0) which is actually the i440fx/q35
chipset for QEMU targets. Define CONFIG_PCI_CONFIG_HOST_BRIDGE to make
it visible in the PCI configuration space.
High mem starts at 4 GiB.
Signed-off-by: Andrew Bradford <andrew.bradford@kodakalaris.com>
If pirq_routing_table points to NULL, that means U-Boot fails to
generate the table before in create_pirq_routing_table(), so we
test it against NULL before actually writing it.
Intel Quark SoC has the same interrupt routing mechanism as the
Queensbay platform, only the difference is that PCI devices'
INTA/B/C/D are harcoded and cannot be changed freely.
Describe all required properties needed by the irq router device tree.
PIRQ routing is pretty much common in Intel chipset. It has several
PIRQ links (normally 8) and corresponding registers (either in PCI
configuration space or memory-mapped IBASE) to configure the legacy
8259 IRQ vector mapping. Refactor current Queensbay PIRQ routing
support using device tree and move it to a common place, so that we
can easily add PIRQ routing support on a new platform.
Enable legacy IDE support on the pc target and AHCI support on the
q35 target. Default configuration is to support the pc target.
Enable CONFIG_LBA48 to support large disks. CONFIG_ATAPI is only needed
by cmd_ide.c which is not common for modern x86 targets, hence remove it.
Eliminate the following build warning in atapi_inquiry():
"warning: assignment from incompatible pointer type [enabled by default]"
The legacy IDE device has a BAR4 (Bus Master Interface BAR) which
needs to be configured.
Remove the '#undef DEBUG' in pci_auto.c so that we can enable debug
message output via '-DDEBUG'.
It turns out that QEMU x86 emulated graphic card has a built-in
option ROM which can be run perfectly with native mode by U-Boot.
CONFIG_FRAMEBUFFER_SET_VESA_MODE and CONFIG_FRAMEBUFFER_VESA_MODE
are not x86-specific, so move them to drivers/video/Kconfig and
make them depend on VIDEO_VESA driver. Some cosmetic fixes are
applied to the Kconfig help text as well.
There is no reason to prevent CONFIG_VIDEO_VESA driver working on
non-x86 boards, so remove such limitation.
gd is not referenced in those board files so DECLARE_GLOBAL_DATA_PTR
should be removed.
Document how to build and test U-Boot with QEMU.
QEMU is much easier for us test booting U-Boot as a coreboot payload
than having a real board like chromebook_link.
Some x86 boards set CONFIG_NR_DRAM_BANKS to 1, which causes incorrect
DRAM size printed when booting from coreboot, like this:
CPU: x86, vendor Intel, device 663h
DRAM: 636 KiB
Using default environment
Change it to 8 which should be enough for both coreboot and bare
cases, and move it to x86-common.h.
Now that we have QEMU support, make it the default vendor in the
'make menuconfig' screen.
This commit introduces the initial U-Boot support for QEMU x86 targets.
U-Boot can boot from coreboot as a payload, or directly without coreboot.
Merged in patch 'x86: qemu: Add CMD_NET to qemu-x86_defconfig
https://patchwork.ozlabs.org/patch/479745/
pci_hose_phys_to_bus() is needed by several drivers. Move it to
pci_common.c to avoid a broken build when CONFIG_DM_PCI is on.
netconsole had become defective over time and cleanups.
Because the feature is used very rarely nobody did take notice about this
defect.
With this patch the resulting syntax error on call will be fixed.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed
from the configs.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
The config for pcm051 still undef'd CONFIG_USE_IRQ. This is not
needed any more since it is not defined in the whole include path
before.
Fixup include/configs/unipher.h to not set CONFIG_LIB_RAND
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to
Kconfig to ensure that library is also compiled.
Remove the definitions from Blackfin boards' include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Commit 76ec988b062e (net: Remove all calls to net_random_ethaddr())
accidentally deleted CONFIG_TARGET_BCT_BRETTL2=y, and since then
bct-brettl2 would not build.
Since commit a26cd04920dc (arch: Make board selection choices
optional), Kconfig actually allows such a .config file in which no
board is selected, but the build never succeeds.
Commit 92ac52082140 (net: Remove all references to CONFIG_ETHADDR
and friends) accidentally dropped #endif. Since then, gr_ep2s60
could not build.
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config.h
GEN include/autoconf.mk
In file included from include/config.h:5:0,
from ./include/common.h:18:
include/configs/gr_ep2s60.h:15:0: error: unterminated #ifndef
#ifndef __CONFIG_H__
make[1]: *** [include/autoconf.mk] Error 1
this removes a config entry and uses the default value
defined in config_fallbacks.h. This implements the same
behaviour as a patch series for other i.MX6 boards from
Freescale
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
This avoids an error message on NAND-less boards.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
If the EEPROM could not be read or is corrupt we always want to hang.
Note that an error message will have been displayed by read_eeprom in this
case.
The fdt_file1 and fdt_file2 vars provide fallbacks for the fdt file loading
script. There is no need to allow the user to override these as if they
want to specify the fdt, they should do so in the first attempt which is
the fdt_file var.
We want to model env var to always reflect what was in the EEPROM. There
is no point in allowing a user to override this.
- Added iomux for CAN_STBY and RS484_TEN (GW52xx/GW53xx/GW54xx/GW551x)
- Moved iomux of USBHUB_RST# out of board_ehci_hcd_init so that it is
done regardless of USB being initialized in bootloader
- Added usb_sel iomux/hwconfig for GW552x
- Fixed mezzanine DIO for GW54xx
- Fixed PANLEDR# for GW54xx
- Fixed dio iomux/hwconfig for GW552x
- Fixed dio iomux for GW551x
- removed redundant #define
In case the DC-DC is already enabled mxs_enable_4p2_dcdc_input() returns
without reenabling brown out detection. So fix this issue by
moving the return before brown out deactivation.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
This updates r8a7794 QoS to revision 0.31 for ES1 and revision 0.321 for ES2.
Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This updates r8a7793 QoS to revision 0.311.
This updates r8a7791 QoS to revision 0.411.
This updates r8a7790 QoS to revision 0.973.
This commit can changed from KConfig to fit contents of the QoS.
