path: root/CHANGELOG
2003-08-30Patch by Raghu Krishnaprasad, 7 Aug 2003:U-Boot-0_4_7wdenk
add support for Adder II MPC852T module
2003-08-29* Patch by George G. Davis, 19 Aug 2003:wdenk
fix TI Innovator/OMAP1510 pin configs * Patches by Kshitij, 18 Aug 2003 - add support for arm926ejs cpu core - add support for TI OMAP 1610 Innovator Board
2003-08-29Patch by Yuli Barcohen, 14 Aug 2003:wdenk
add support for bzip2 uncompression
2003-08-29Add I2C and RTC support for RMU board using software I2C driverwdenk
(because of better response to iprobe command); fix problem with "reset" command
2003-08-28Patch from Matthias Fuchs.stroese
2003-08-28* Fix ICU862 environment problemwdenk
* Fix RAM size detection for RMU board * Implement "reset" for MGT5100/MPC5200 systems
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-08-07Update for TQM board defaults:U-Boot-0_4_5wdenk
disable clocks_in_mhz, enable boot count limit
2003-08-07Removed tools/gdb from "make all" target. Added make target "gdbtools"dzu
in toplevel directory instead. Removed astest.c from tools/gdb because it is no longer relevant.
2003-08-05* Fix PCI support for MPC5200 / IceCube Boardwdenk
2003-08-05* Map ISP1362 USB OTG controller for NSCU boardwdenk
* Patch by Brad Parker, 02 Aug 2003: fix sc520_cdp problems * Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements) * Allow erase command to cross flash bank boundaries
2003-07-27* Patch by Scott McNutt, 21 Jul 2003:wdenk
Add support for LynuxWorks Kernel Downloadable Images (KDIs). Both LynxOS and BlueCat linux KDIs are supported. * Patch by Richard Woodruff, 25 Jul 2003: use more reliable reset for OMAP/925T * Patch by Nye Liu, 25 Jul 2003: fix typo in mpc8xx.h * Patch by Richard Woodruff, 24 Jul 2003: Fixes for cmd_nand.c: - Fixed null dereferece which could result in incorrect ECC values. - Added support for devices with no Ready/Busy signal hooked up. - Added OMAP1510 read/write protect handling. - Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock for non-JFFS2. - Switched default ECC to be JFFS2.
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
2003-07-15Patches by Kshitij, 04 Jul 2003wdenk
- added support for arm925t cpu core - added support for TI OMAP 1510 Innovator Board
2003-07-15* Patches by Martin Krause, 14 Jul 2003:wdenk
- add I2C support for s3c2400 systems (trab board) - (re-) add "ping" to command table * Fix handling of "slow" POST routines
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-07-11- Patch by Stefan Roese, 11 Jul 2003stroese
2003-07-07* Add support for NSCU boardU-Boot-0_4_2wdenk
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules * Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML mirror bit flash on TQM8xxM modules
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-30* Patch by Seb James, 30 Jun 2003:wdenk
Improve documentation of I2C configuration in README * Fix problems with previous log buffer "fixes" * Fix minor help text issues * "log append" did not append a newline
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-06-28Rewrite command lookup and help command (fix problems with bubblewdenk
sort when sorting command name list). Minor cleanup here and there.
2003-06-28Merge from "stable branch", tag LABEL_2003_06_28_1800-stable:wdenk
- Allow to call sysmon function interactively - PIC on LWMON board needs delay after power-on - Add missing RSR definitions for MPC8xx - Improve log buffer handling: guarantee clean reset after power-on - Add support for EXBITGEN board - Add support for SL8245 board
2003-06-26* Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0wdenk
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support
2003-06-24Patch from Stefan Roese.stroese
2003-06-23* Patch by Yuli Barcohen, 23 Jun 2003:wdenk
Update for MPC8260ADS board * Patch by Murray Jensen, 23 Jun 2003: - cleanup of GCC 3.x compiler warnings
2003-06-22* Patch by Rune Torgersen, 4 Jun 2003:wdenk
add large memory support for MPC8266ADS board * Patch by Richard Woodruff, 19 June 03: - Enabled standard u-boot device abstraction for ARM - Enabled console device for ARM - Initilized bi_baudrate for ARM * Patch by Bill Hargen, 23 Apr 2003: fix byte order for 824x I2C addresses (write op)
2003-06-21Patch by Murray Jensen, 20 Jun 2003:wdenk
- hymod update - cleanup (especially for gcc-3.x compilers)
2003-06-20Patch by Tom Guilliams, 20 Jun 2003:wdenk
added CONFIG_750FX support for IBM 750FX processors
2003-06-20* Patch by Devin Crumb, 02 Apr 2003:wdenk
Fix clock divider rounding problem in drivers/serial.c * Patch by Ken Chou, 19 June 2003: Added support for A3000 SBC board (Artis Microsystems Inc.)
2003-06-19* Patch by Richard Woodruff, 19 June 03:wdenk
- Fixed smc91c111 driver to sync with the u-boot environment (driver/smc91c111.c). - Added eth_init error return check in NetLoop (net/net.c).
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2003-06-19Patches by Robert Schwebel, 14 Jun 2003:wdenk
- add support for Logotronic DL datalogger board - cleanup serial line after kermit binary download - add debugX macro (debug level support) - update mach-types.h to latest arm.linux.org.uk master list.
2003-06-19* Patches by David Müller, 12 Jun 2003:wdenk
- rewrite of the S3C24X0 register definitions stuff - "driver" for the built-in S3C24X0 RTC * Patches by Yuli Barcohen, 12 Jun 2003: - Add MII support and Ethernet PHY initialization for MPC8260ADS board - Fix incorrect SIUMCR initialisation caused by wrong Hard Reset configuration word supplied by FPGA on some MPC8260ADS boards * Patch by Pantelis Antoniou, 10 Jun 2003: Unify status LED interface
2003-06-18Add support for DS12887 RTC; add RTC support for ATC boardwdenk
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-06-06Patch by Robert Schwebel, April 02, 2003:wdenk
fix for SMSC91111 driver
2003-06-05* Patch by Vladimir Gurevich, 04 Jun 2003:LABEL_2003_06_05_2140wdenk
make ppc405 ethernet driver compatible with CONFIG_NET_MULTI option
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2003-06-05Patch from Stefan Roese.stroese
2003-06-04* Patch by Denis Peter, 04 June 2003:wdenk
add support for the MIP405T board
2003-06-03* Patches by Udi Finkelstein, 2 June 2003:LABEL_2003_06_04_0200wdenk
- Added support for custom keyboards, initialized by defining a board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD . - Added support for the RBC823 board. - cpu/mpc8xx/lcd.c now automatically calculates the Horizontal Pixel Count field. * Fix alignment problem in BOOTP (dhcp_leasetime option) [pointed out by Nicolas Lacressonnière, 2 Jun 2003] * Patch by Mark Rakes, 14 May 2003: add support for Intel e1000 gig cards. * Patch by Nye Liu, 3 Jun 2003: fix critical typo in MAMR definition (include/mpc8xx.h) * Fix requirement to align U-Boot image on 16 kB boundaries on PPC. * Patch by Klaus Heydeck, 2 Jun 2003 Minor changes for KUP4K configuration
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
