path: root/Kconfig
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2016-01-20microblaze: move CONFIG_SYS_TEXT_BASE to defconfigMasahiro Yamada
This is how CONFIG options are defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-11-04dm: spl: Support device tree when BSS is in a different sectionSimon Glass
At present in SPL we place the device tree immediately after BSS. This avoids needing to copy it out of the way before BSS can be used. However on some boards BSS is not placed with the image - e.g. it can be in RAM if available. Add an option to tell U-Boot that the device tree should be placed at the end of the image binary (_image_binary_end) instead of at the end of BSS. Note: A common reason to place BSS in RAM is to support the FAT filesystem. We should update the code so that it does not use so much BSS. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-20malloc_simple: Add support for switching to DRAM heapHans de Goede
malloc_simple uses a part of the stack as heap, initially it uses SYS_MALLOC_F_LEN bytes which typically is quite small as the initial stacks sits in SRAM and we do not have that much SRAM to work with. When DRAM becomes available we may switch the stack from SRAM to DRAM to give use more room. This commit adds support for also switching to a new bigger malloc_simple heap located in the new stack. Note that this requires spl_init to be called before spl_relocate_stack_gd which in practice means that spl_init must be called from board_init_f. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-20malloc_simple: Add Kconfig option for using only malloc_simple in the SPLHans de Goede
common/dlmalloc.c is quite big, both in .text and .data usage, therefor on some boards the SPL is build to use only malloc_simple.c and not the dlmalloc.c code. This is done in various include/configs/foo.h with the following construct: #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_MALLOC_SIMPLE #endif This commit introduces a SPL_MALLOC_SIMPLE Kconfig bool which allows selecting this functionality through Kconfig instead. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-28Kconfig: fix typo in CONFIG_FIT descriptionIgor Grinberg
Fix typo in CONFIG_FIT description - remove the accidentially added redundand 'the'. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-05efi: Drop CONFIG_SYS_TEXT_BASE for EFIBen Stoltz
When U-Boot runs as an EFI application is does not have a definition of CONFIG_SYS_TEXT_BASE. U-Boot is a relocatable application and the relocation is done by EFI. U-Boot can be loaded at any address. Ensure that this CONFIG option is not set in this case. Signed-off-by: Ben Stoltz <stoltz@google.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-28Kconfig: zynqmp: Move CONFIG_SYS_TEXT_BASE to defconfigSiva Durga Prasad Paladugu
Move CONFIG_SYS_TEXT_BASE of ZynqMP_ep to its respective defconfig Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-05-31ARM: UniPhier: move CONFIG_SYS_TEXT_BASE to KconfigMasahiro Yamada
2015-04-29x86: Kconfig: Remove deprecated CONFIG_SYS_EXTRA_OPTIONSBin Meng
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define the text base address. Since it is deprecated, just remove it and use CONFIG_SYS_TEXT_BASE directly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-29sunxi: use CONFIG_SYS_CLK_FREQ to set cpu clockIain Paton
make the CPU clock selectable via Kconfig this removes the sunxi specific CONFIG_CLK_FULL_SPEED defined in each soc header and replaces it's use in board/sunxi/board.c with CONFIG_SYS_CLK_FREQ from Kconfig which allows us to configure board specific frequency on boot Signed-off-by: Iain Paton <ipaton0@gmail.com> [hdegoede@redhat.com s/CONFIG_SYS_CLK_FREQ/CONFIG_TIMER_CLK_FREQ/ for the arch-timer clk speed on sun7i to fix mis-compile on sun7i] Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-09dlmalloc: do memset in malloc init as new default configPrzemyslaw Marczak
This commit introduces new config: CONFIG_SYS_MALLOC_CLEAR_ON_INIT. This config is an expert option and is enabled by default. The all amount of memory reserved for the malloc, is by default set to zero in mem_malloc_init(). When the malloc reserved memory exceeds few MiB, then the boot process can slow down. So disabling this config, is an expert option to reduce the boot time, and can be disabled by Kconfig. Note: After disable this option, only calloc() will return the pointer to the zeroed memory area. Previously, without this option, the memory pointed to untouched malloc memory region, was filled with zeros. So it means, that code with malloc() calls should be reexamined. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-04arm: spl: Allow board_init_r() to run with a larger stackSimon Glass
At present SPL uses a single stack, either CONFIG_SPL_STACK or CONFIG_SYS_INIT_SP_ADDR. Since some SPL features (such as MMC and environment) require a lot of stack, some boards set CONFIG_SPL_STACK to point into SDRAM. They then set up SDRAM very early, before board_init_f(), so that the larger stack can be used. This is an abuse of lowlevel_init(). That function should only be used for essential start-up code which cannot be delayed. An example of a valid use is when only part of the SPL code is visible/executable, and the SoC must be set up so that board_init_f() can be reached. It should not be used for SDRAM init, console init, etc. Add a CONFIG_SPL_STACK_R option, which allows the stack to be moved to a new address before board_init_r() is called in SPL. The expected SPL flow (for CONFIG_SPL_FRAMEWORK) is documented in the README. Signed-off-by: Simon Glass <sjg@chromium.org> For version 1: Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-02-25Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-02-25crypto/fsl - Add progressive hashing support using hardware acceleration.gaurav rana
Currently only normal hashing is supported using hardware acceleration. Added support for progressive hashing using hardware. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> CC: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-24kconfig: Adjust ordering so that defaults work as expectedSimon Glass
At present defaults in arch-specific Kconfig files are ignored if the top-level item comes ahead of it in include order. This means that it is not possible to have a U-Boot default that architectures and boards can override. This does not seem very useful. Move the include earlier to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: test: Add a Kconfig fileSimon Glass
Add a file to control driver model test features. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12RSA depends on DMChris Kuethe
Discovered while experimenting with signature checking on vexpress which doesn't typically use DM. Acked-by: Simon Glass <sjg@chromium.org>
2015-02-09arc: move SYS_MONITOR_BASE setup in KonfigAlexey Brodkin
Following SPARK ARC now has SYS_MONITOR_BASE setup via Kconfig. This makes "include/configs/*.h" cleaner and more flexible. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-01-29FIT: Modify option FIT_SIGNATURE in KconfigRuchika Gupta
For FIT signature based approach to work, RSA library needs to be selected. The FIT_SIGNATURE option in Kconfig is modified to automatically select RSA. Selecting RSA compiles the RSA library required for image verification. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-14Kconfig: move CONFIG_SYS_CLK_FREQ to KconfigAlexey Brodkin
It makes sense to specify CONFIG_SYS_CLK_FREQ in "configs/xx_defconfig" instead of "include/configs/xxx.h" because then header will be reusable across boards with different CPU clocks. Also this nice to have an ability for end user to tune this value himself via "menuconfig". For now I'm only applying this change to all ARC configs because otherwise scope of change will be huge. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Hans de Goede <hdegoede@redhat.com> cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2015-01-07Kconfig: move EXPERT option under "General setup" menuMasahiro Yamada
Make it a sub-menu of "General setup" like Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2014-11-24Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-11-24Kconfig: Add EXPERT optionTom Rini
For similar reasons to why the Linux Kernel has an EXPERT option, we too want an option to allow for tweaking of some options that while normally should remain hidden, may need to be changed in some cases. Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-23FIT: add some FIT configurations to KconfigMasahiro Yamada
2014-11-04sparc: move CONFIG_SYS_TEXT_BASE to KconfigMasahiro Yamada
Defining CONFIG_SYS_TEXT_BASE in config.mk is very old style. Create CONFIG_SYS_TEXT_BASE option in Kconfig, but let it depend on CONFIG_SPARC because we do not want to disturb the other architectures that still define CONFIG_SYS_TEXT_BASE in their header files. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-10-27kconfig: add CONFIG_SUPPORT_TPLMasahiro Yamada
CONFIG_TPL should not be enabled for boards that do not have TPL. CONFIG_SUPPORT_TPL introduced by this commit should be "select"ed by boards with TPL support and CONFIG_TPL should depend on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27kconfig: add CONFIG_SUPPORT_SPLMasahiro Yamada
CONFIG_SPL should not be enabled for boards that do not have SPL. CONFIG_SUPPORT_SPL introduced by this commit should be "select"ed by boards with SPL support and CONFIG_SPL should depend on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-28kconfig: add CONFIG_CC_OPTIMIZE_FOR_SIZEMasahiro Yamada
Copy the Kconfig option from "init/Kconfig" of Linux v3.16 tag and adjust the help document. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-28kconfig: add CONFIG_LOCALVERSION and CONFIG_LOCALVERSION_AUTOMasahiro Yamada
Copy Kconfig options from "init/Kconfig" of Linux v3.16 tag and adjust some parts of the help document. Move CONFIG_SPL, CONFIG_TPL, ... etc. to "Boot images" menu. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21kconfig: remove DEFCONFIG_LISTMasahiro Yamada
CONFIG_DEFCONFIG_LIST specifies the default defconfig. It is used by "make savedefconfig" when .config is missing. But that's it. I could not find other useful cases. As a side effect, CONFIG_DEFCONFIG_LIST="configs/sandbox_defconfig" is contained in .config of every target board, which some people think is odd. So, let's remove it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-07-30kconfig: add basic Kconfig filesMasahiro Yamada
This commit adds more Kconfig files, which were written by hand. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
