path: root/MAINTAINERS
2010-10-25ppc4xx: Add Io and IoCon 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck CATCenter Io. Board support for the Guntermann & Drunck IoCon. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-22XPedite5500 board supportJohn Schmoller
Initial support for Extreme Engineering Solutions XPedite5500 - a P2020-based PMC/XMC single board computer. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Make X-ES board names more genericPeter Tyser
Some U-Boot images for X-ES boards support multiple products in the same family. For example, the XPedite5370, XPedite5371, and XPedite5372 are similar enough that one U-Boot image can work on all 3 cards. To make it clear that a U-Boot image can work on boards of the same family, rename the boards with the least significant digit of 'x'. While we're at it, change the board config file and make targets to be lowercase. Also change the default uImage and fdt filenames to "board.uImage" and "board.dtb" to be more generic. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-19Add support for HP Jornada flashrom boardsKristoffer Ericson
This patch adds support for the HP Jornada flashboards that were made in 2008. Older flashroms should work if memory registers are adjusted. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Adpted for TEXT_BASE -> CONFIG_SYS_TEXT_BASE rename. Removed now redundant board/jornada/config.mk file. Removed unused empty jornada_init() function to silence "jornada.c:35: warning: 'jornada_init' defined but not used" Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-19PXA: Add missing MAINTAINERS entriesMarek Vasut
2010-10-19PXA: Balloon3 board supportMarek Vasut
The following hardware is currently supported: - UART - USB Host - FPGA Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: Voipac270 improvementsMarek Vasut
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: Add initial Palm LifeDrive supportMarek Vasut
2010-10-19PXA: Palm Tungsten|C SupportMarek Vasut
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19at91rm9200ek: convert to at91Andreas Bießmann
This patch removes some functionality from at91rm9200ek board but the remaining functionality does now work with newer at91 code and arm-relocation. Currently missing features are: - dataflash booting (due to missing HW for testing) - MMC/SD-Card - first stage bootloader support is completely removed (not needed for NOR) Cause this board was (some days ago) reference for all at91rm9200 based boards this should be a good starting point to convert all remaining at91rm9200 borads to at91 code. Aside from that this is a good base to get some drivers between at91sam/at91rm/avr32 merged. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-19NC650/CP850: remove code for yet another corpseWolfgang Denk
The NC650 / CP850 boards have long been unmaintained and left broken. As obviously nobody is interested in that code any more, we may as well remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-18MAINTAINERS: Fix alphabetical order in ARM subsectionEnric Balletbo i Serra
I'm noticed that IGEP maintainer isn't in the correct place within the ARM subsection: it's supposed to be in alphabetical order by maintainer. This patch fix this. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2010-10-17OMAP3: Add support for the OMAP3 IGEP module.Enric Balletbo i Serra
The IGEP module is a low-power, high performance production-ready system-on-module (SOM) based on TI's OMAP3 family.The IGEP module solution based upon TI OMAP3 provides a low-power/low-cost platform for a variety of consumer/industrial/medical devices. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17OMAP3: Add support for the IGEP v2 board.Enric Balletbo i Serra
The IGEP v2 board is a low-cost, fan-less and industrial temperature range single board computer that unleashes laptop-like performance and expandability without the bulk, expense, or noise of typical desktop machines. Its architecture shares much in common with other OMAP3 boards. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-13ARMV7: Versatile Express Coretile CortexA9x4 supportMatt Waddel
Adds support for the ARM quad-core Cortex-A9 processor This system includes a motherboard(Versatile Express), daughterboard (Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet, and flash systems work with these additions. The naming convention is: SOC -> CortexA9 quad core = ca9x4 daughterboard -> Coretile = ct motherboard -> Versatile Express = vxp This gives ca9x4_ct_vxp.c as the board support file. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2010-10-12A4M072: Added support for the board.Sergei Poselenov
This patch provides support for the A4M072 board with the following features: UART NOR flash FEC Ethernet External SRAM I2C EEPROM CompactFlash cards on IDE/ATA port USB Host PCI initialization The 7-segment LED indicator is not yet supported. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2010-10-11Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-10-07MX51: Support for TTECH vision2 boardStefano Babic
The patch adds support for TTECH vision2 board. The board has 512MB RAM, SDHC slot and 4MB SPI device from StMicron. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-06CCM: remove code for yet another corpseWolfgang Denk
The CCM board has long reached EOL, and support for it is no longer relevant in current versions of U-Boot. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-06PCU_E: remove code for yet another corpseWolfgang Denk
The PCU_E board has long reached EOL, and support for it is no longer relevant in current versions of U-Boot. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-05Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-10-04APM821xx: Add bluestone board supportTirumala Marri
Add support code for bluestone board wth APM821XX processor based. This patch includes early board init, misc init, configure EBC, initializes UIC, MAKEALL, board.cfg and MAINTAINERS file. Signed-off-by: Tirumala R Marri <tmarri@apm.com Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-02Blackfin: blackvme: new board portWojtek Skulski
The board includes: * ADSP-BF561 rev. 0.5 * 32-bit SDRAM (2 * MT48LC16M16A2TG or MT48LC32M16A2TG) * Gigabit Ether AX88180 (ASIX) + 88E1111 rev. B2 (Marvell) * SPI boot flash on PF2 (M25P64 8MB, or M25P128 16 MB) * FPGA boot flash on PF3 (M25P64 8MB, or M25P128 16 MB) * Spartan6-LX150 (memory-mapped; both PPIs also connected) * See http://www.skutek.com/ Signed-off-by: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bct-brettl2: new board portPeter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bf527-sdp: new board portMike Frysinger
Support for the Blackfin System Development Platform (SDP) base module. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23mpc8308_p1m: support for MPC8308 P1M boardIlya Yanok
This patch provides support for MPC8308 P1M board with the following set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported Both I2C controllers are supported Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-09MX51: Update responsible for mx51evkStefano Babic
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-07-17Drop support for GTH boardWolfgang Denk
The board maintainer states: The GTH board is obsolete and has not been manufactured for several years. To my knowledge, no recent U-Boot build has been tested on that card. So drop support for this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Acked-by: Thomas Lange<thomas@corelatus.se>
2010-07-16Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-07-16powerpc: add support for the Freescale P1022DS reference boardTimur Tabi
Specifics: 1) 36-bit only 2) Booting from NOR flash only 3) Environment stored in NOR flash only 4) No SPI support 5) No DIU support Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-15Merge branch 'master' of ../masterWolfgang Denk
2010-07-14Merge branch 'next' of git://git.denx.de/u-boot-niosWolfgang Denk
2010-07-14Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2010-07-13Blackfin: bf527-ad7160-eval: new board supportMichael Hennerich
Support the new AD7160 eval board. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-12nios2: remove EP1C20, EP1S10, EP1S40 boardsThomas Chou
The example configuration files of nios2-generic board can generated binary to run on the EP1C20, EP1S10, and EP1S40 boards. So the three boards can be removed. With nios2-generic approach, the fpga parameter header file can be generated from hardware designs using tools. Porting u-boot for nios2 boards is simplified. Vendors can supply their fpga parameter file or patches to add a new nios2-generic board instance. There is no need to include other boards support for nios2 in the u-boot mainline. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-0983xx: add support for ve8313 boardHeiko Schocher
This patch add support for the ve8313 board based on Freescale MPC8313 CPU. - serial console on UART 1 - 128 MB DDR RAM - 32 MB NOR Flash - 16 MB NAND Flash - Ethernet MII Mode over on TSEC0 - micrel ksz804 phy - Hardware WDT MAX824 changes since v1 - Environment size = sector size - use red. environment - add comments from Kim Phillips - add MAKEALL, MAINTAINERS entry - Codingstyle issues fixed - inserted original Copyrights - PCI subsys vendor ID changed from 0x1057 (Motorola) to 0x1957 (Freescale) changes since v2 - add comments from Wolfgang Denk - fix Codingstyle and some comments - reworked WDT reset (just toggling the WD_TRIG pin) - Environment size now 16KiB - fixed RAMBOOT version - fixed CONFIG_SYS_LOAD_ADDR - renamed CONFIG_TSEC1_NAME to TSEC1 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-09MPC8308RDB: minimal support for devboard from FreescaleIlya Yanok
This patch provides support for MPC8308RDB development board from Freescale with a minimal set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported The following features are enabled in configuration but not fully tested: I2C (used to get the board revision) I2C-connected RTC VSC7385 switch There is one (hopefully) minor issue: on soft reset the board sometimes resets twice. I've not managed to find the fix for this problem yet. As a workaround instruction cache can be disabled. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-05ARMV7: Add support for TI OMAP4 PandaSteve Sakoman
OMAP4 Panda is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Add support for TI OMAP4430 SDPSteve Sakoman
OMAP4430 SDP is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-01ppc4xx: Add T3COPR board support (PPC460GT based)Stefan Roese
This patch adds support for the T3CORP board, based on the AppliedMicro (APM) PPC460GT. Signed-off-by: Stefan Roese <sr@denx.de>
2010-06-22remove myself as a maintainer of several ARM boardsGuennadi Liakhovetski
Since I haven't been actively maintaining these boards for a long while, keeping myself as their maintainer makes no sense. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
Conflicts: CONFLICT (rename/add): Rename board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b. board/ti/tnetv107xevm/Makefile added in HEAD But files were identical, so no problem. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-06-17Add support for the LaCie ED Mini V2 boardAlbert Aribaud
This patch adds support for the LaCie ED Mini V2 product which is based on the Marvell Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-06-14s5pc1xx: Add support for Samsung Goni boardMinkyu Kang
This patch adds support for the Samsung Goni board (S5PC110 SoC) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
