path: root/MAINTAINERS
2016-08-20Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
[trini: Drop CMD_BOOTI as it's now on by default on ARM64] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-17MAINTAINERS: Add maintainer entry of RMOBILENobuhiro Iwamatsu
Add MAINTAINERS entry. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-02MAINTAINERS, git-mailrc: Update the mmc maintainerJaehoon Chung
Update the mmc maintainer from Pantelis to me. Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-28MAINTAINERS: i.MX: Add board/freescale/*mx* pathFabio Estevam
Pass the board/freescale/*mx*/ path as files maintained by Stefano Babic. While this is not ideal and does not cover all the i.MX board cases, it gives at least a better hint for the /scripts/get_maintainer.pl tool. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-04-25MAINTAINERS: Add myself as maintainer for hikeyPeter Griffin
This patch adds myself as maintainer for the hikey U-Boot port. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-11rpi: remove redundant board filesStephen Warren
Now that rpi_*defconfig and Kconfig (rather than the config header file) provide the identity of the build, we don't need to separate config headers and board directories for each RPi variant. Set CONFIG_SYS_BOARD and CONFIG_SYS_CONFIG_NAME so that we can get rid of the duplication. This requires a tiny number of extra ifdefs in the config header. The only disadvantage of this approach is that the $board/$board_name environment variables aren't as descriptive as they used to be. This isn't really an issue because those only exist to allow scripts to create DTB filenames at runtime. However, the RPi board code already sets $fdtfile to something more accurate based on FW-reported board ID anyway. While at it, unify some Kconfig select options, and add a MAINTAINERS entry for bcm283x too. Partially-suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01MAINTAINERS: Update Scott Wood's email addressScott Wood
Freescale is now NXP. I still work there, but I won't be using their mail system for U-Boot development. Signed-off-by: Scott Wood <oss@buserror.net>
2016-04-01Add myself as Snapdragon and SPMI maintainerMateusz Kulikowski
- Update MAINTAINERS - Update git-mailrc Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-15efi_loader: Add MAINTAINERS entryAlexander Graf
Now that everything's in place, let's add myself as the maintainer for the efi payload support. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-24MAINTAINERS: Update no longer valid maintainers' statusBin Meng
The following maintainers' email addresses are no longer valid. vipin.kumar@st.com martin.krause@tq-systems.de kim.phillips@freescale.com fgretief@spaceteq.co.za Update status of the components they used to maintain to be: S: Orphaned (Since 2016-02) Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-15MAINTAINERS: add entry for RockchipMasahiro Yamada
Rockchip has its own git repository maintained by Simon. Document this. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-14MAINTAINERS: Update Marvell custodianshipStefan Roese
Add myself as custodian for the Marvell git repository. Additionally, add the mach-mvebu directory to the list of files / directories. And add Armada XP & Armada 38x to the title (not only kirkwood). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Tom Rini <trini@konsulko.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Luka Perkov <luka.perkov@sartura.hr>
2016-01-08MAINTAINERS, .mailmap: Update my email addressYork Sun
Change from yorksun@freescale.com to york.sun@nxp.com. Signed-off-by: York Sun <york.sun@nxp.com>
2015-12-23ARM: uniphier: rename rest of defconfig filesMasahiro Yamada
Rename rest of defconfig files of UniPhier SoC family to have the prefix uniphier_. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: merge ph1_ld4_defconfig and ph1_sld8_defconfigMasahiro Yamada
These two are similar enough to be merged into a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-30arm: s5pc1xx: move SoC to mach-s5pc1xxMinkyu Kang
move arm/arm/cpu/armv7/s5pc1xx to arch/arm/mach-s5pc1xx Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-13sparc: Update the maintainer for SPARC architectureFrancois Retief
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-05-16MAINTAINERS, git-mailrc: Update Jagan's name and e-mailJagan Teki
Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-05-08Remove non-working address from MAINTAINERPavel Machek
I checked with Detlev, and sadly removing that maintainers entry is right thing to do. Signed-off-by: Pavel Machek <pavel@denx.de>
2015-04-20Update MAINTAINERS and git-mailrc for netJoe Hershberger
Update to my corporate email and make the supported filter and aliases more accurate. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-09MAINTAINERS: fix TI DaVinci directory path and add KeyStoneMasahiro Yamada
2015-03-15MAINTAINERS: update Masahiro's email addressMasahiro Yamada
I have transferred to Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-05MAINTAINERS: add Driver Model repository informationMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-02Merge branch 'xnext/zynqmp' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-03-02arm64: Add Xilinx ZynqMP supportMichal Simek
Add basic Xilinx ZynqMP arm64 support. Serial and SD is supported. It supports emulation platfrom ep108 and QEMU. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-02MAINTAINERS, git-mailrc: Update my email addressTom Rini
2015-03-01Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2015-03-01ARM: UniPhier: move SoC headers to mach-uniphier/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-uniphier/* -> arch/arm/mach-uniphier/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-03-01ARM: UniPhier: move SoC sources to mach-uniphierMasahiro Yamada
Move arch/arm/cpu/armv7/uniphier/* -> arch/arm/mach-uniphier/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-26MAINTAINERS: Add F: drivers/usb/gadget to DFU custodian responsibilityLukasz Majewski
After discussion during the last u-boot mini summit with USB maintainer - Marek Vasut - it has been decided, that gadget development should be coordinated by DFU custodian. Such patch formalizes current development status. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-21ARM: kirkwood: move SoC headers to mach-kirkwood/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-kirkwood/* -> arch/arm/mach-kirkwood/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-02-21ARM: at91: move SoC headers to mach-at91/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-at91/* -> arch/arm/mach-at91/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-21ARM: kirkwood: move SOC sources to mach-kirkwoodMasahiro Yamada
Move arch/arm/cpu/arm926ejs/kirkwood/* -> arch/arm/mach-kirkwood/* Note: Perhaps, can we merge arch/arm/mach-kirkwood and arch/arm/mvebu-common into arch/arm/mach-mvebu, like Linux? Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-02-21ARM: tegra: collect SoC sources into mach-tegraMasahiro Yamada
This commit moves files as follows: arch/arm/cpu/arm720t/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/arm720t/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/arm720t/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/arm720t/tegra124* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/arm720t/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/armv7/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/armv7/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/armv7/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/armv7/tegra124/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/armv7/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/tegra20-common/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/tegra30-common/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/tegra114-common/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/tegra124-common/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/tegra-common/* -> arch/arm/mach-tegra/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Simon Glass <sjg@chromium.org> [ on nyan-big ] Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
2015-02-07MAINTAINERS: claim maintainership of files with "uniphier" patternMasahiro Yamada
The pattern "N: uniphier" can cover - drivers/serial/serial_uniphier.c - drivers/i2c/i2c-uniphier.c - drivers/i2c/i2c-uniphier-f.c - arch/arm/dts/uniphier-* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2015-01-08MAINTAINERS: add me as a co-maintainer of KIRKWOODLuka Perkov
Signed-off-by: Luka Perkov <luka.perkov@sartura.hr> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2014-12-09stv0991: Add basic stv0991 architecture supportVikas Manocha
stv0991 architecture support added. It contains the support for following blocks - Timer - uart Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Add arch/arm/cpu/armv7/Makefile hunk] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-08Add custodians to the m68k subsystem.angelo@sysam.it
2014-12-08MAINTAINERS: add me as a maintainer of UBIHeiko Schocher
Add me for UBI custodian. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
2014-11-07MAINTAINERS: CFI flash maintainership only includes the CFI related filesStefan Roese
All the other files in drivers/mtd/* are not really CFI related. So lets only include the files that are CFI specific. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jagan Teki <jagannadh.teki@gmail.com> Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-04MAINTAINERS: fix Pantelis Antoniou email addressIgor Grinberg
Trivial fix (unless Pantelis has a new email address): Pantelis Antoniou <panto.antoniou-consulting.com> ^ make it: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-10-11arm: socfpga: add MAINTAINERS entryPavel Machek
Add MAINTAINERS entry. Signed-off-by: Pavel Machek <pavel@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-10-05MAINTAINERS: add me as a maintainer of UniPhier platformMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Michal Simek <monstr@monstr.eu>
2014-08-09MAINTAINERS: add initial versionDaniel Schwierzeck
MAINTAINERS contains all currently known custodians based on infos from wiki [1] and u-boot git forks [2]. [1] http://www.denx.de/wiki/U-Boot/Custodians [2] http://git.denx.de/?p=u-boot.git;a=forks Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
