For AM64x all devices are securable devices. Make the default defconfig
include the secure configuration. Then remove the HS specific config.
Non-HS devices will continue to boot due to runtime device type detection.
If TI_SECURE_DEV_PKG is not set the build will emit warnings, for non-HS
devices these can be ignored.
Signed-off-by: Andrew Davis <afd@ti.com>
Add j721s2 High Security EVM defconfig.
These configs are same as for the non-secure part, except for:
CONFIG_TI_SECURE_DEVICE option set to 'y'
CONFIG_FIT_IMAGE_POST_PROCESS option set to 'y'
CONFIG_SPL_FIT_IMAGE_POST_PROCESS option set to 'y'
CONFIG_BOOTCOMMAND does not have main_cpsw0_qsgmii_phyinit
variable since j721s2 does not have ethernet firmware.
Signed-off-by: Jayesh Choudhary <j-choudhary@ti.com>
Acked-by: Andrew Davis <afd@ti.com>
Add am64x High Security EVM defconfig.
These defconfigs are the same as for the non-secure part, except for:
CONFIG_BOOTCOMMAND uses FIT images for booting
Signed-off-by: Yogesh Siraswar <yogeshs@ti.com>
[praneeth@ti.com: fix am64x_hs_evm_a53_defconfig,MAINTAINERS file and commitmsg]
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
Add j7200 High Security EVM defconfig.
[praneeth@ti.com: fix j7200_hs_evm_r5_defconfig,MAINTAINERS file and commitmsg]
This is not really a new board but rather a minimal bootloader solution
for the AM437x GP EVM. In terms of interfaces, it only supports booting
from MMC0 or UART0 and only activates a minimal set of drivers that are
that are necessary to run the device such as DDR, I2C, and PMIC.
The goal is to provide a bare minimum starting point to boot Linux for
basing custom board-ports on. The limited complexity of this solution
should make it easier to achieve a successful boot to U-Boot prompt vs.
trying to pair down the full-featured multi-platform AM437x U-Boot
available through am43xx_evm_defconfig.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
[Amjad: fix compile and checkpatch warnings]
Signed-off-by: Amjad Ouled-Ameur <aouledameur@baylibre.com>
for the AM335x GP EVM. In terms of interfaces, it only supports booting
trying to pair down the full-featured multi-platform AM335x U-Boot
available through am335x_evm_defconfig.
[Amjad: fix checkpatch and compile warnings]
Add support for ipu early boot.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Add all the ipu early boot related nodes
The driver enables IPU support. Basically enables the clocks,
timers, watchdog timers and bare minimal MMU and supports
loading the firmware from mmc.
[Amjad: fix compile warnings]
Add a reset driver to bring IPs out of reset.
[Amjad: reset_ops structure member "free" has been renamed to "rfree",
use the latter instead]
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2021-01-rc4
* Provide a tool to create a file with UEFI variables to preseed UEFI
variable store.
* Make size of UEFI variable store configurable.
* Add man pages for commands 'bootefi' and 'button'.
tools/efivar.py allows to prepare a file with UEFI variables to preseed
the UEFI variable store.
Provide a description of the bootefi command.
Add SPI Flash controller driver for Cortina Access
CAxxxx SoCs
Signed-off-by: Pengpeng Chen <pengpeng.chen@cortina-access.com>
Signed-off-by: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
CC: Vignesh R <vigneshr@ti.com>
CC: Tom Rini <trini@konsulko.com>
[jagan: rebase on master]
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Update Patrick and my email address with the one dedicated to
upstream activities.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
include/log.h belongs to LOGGING.
Some commands can get very unweildy if they have too many positional
arguments. Adding options makes them easier to read, remember, and
understand.
This implementation of getopt has been taken from barebox, which has had
option support for quite a while. I have made a few modifications to their
version, such as the removal of opterr in favor of a separate getopt_silent
function. In addition, I have moved all global variables into struct
getopt_context.
The getopt from barebox also re-orders the arguments passed to it so that
non-options are placed last. This allows users to specify options anywhere.
For example, `ls -l foo/ -R` would be re-ordered to `ls -l -R foo/` as
getopt parsed the options. However, this feature conflicts with the const
argv in cmd_tbl->cmd. This was originally added in 54841ab50c ("Make sure
that argv[] argument pointers are not modified."). The reason stated in
that commit is that hush requires argv to stay unmodified. Has this
situation changed? Barebox also uses hush, and does not have this problem.
Perhaps we could use their fix?
I have assigned maintenance of getopt to Simon Glass, as it is currently
only used by the log command. I would also be fine maintaining it.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2021.01-v2
common:
- Add support for 64bit loadables from SPL
xilinx:
- Update documentation and record ownership
- Enable eeprom board detection based legacy and fru formats
- Add support for FRU format
microblaze:
- Optimize low level ASM code
- Enable SPI/I2C
- Enable distro boot
zynq:
- Add support for Zturn V5
zynqmp:
- Improve silicon detection code
- Enable several kconfig options
- Align DT with the latest state
- Enabling security commands
- Enable and support FPGA loading from SPL
- Optimize xilinx_pm_request() calling
versal:
- Some DTs/Kconfig/defconfig alignments
- Add binding header for clock and power
zynq-sdhci:
- Add support for tap delay programming
zynq-spi/zynq-qspi:
- Use clock framework for getting clocks
xilinx-spi:
- Fix some code issues (unused variables)
serial:
- Check return value from clock functions in pl01x
Maxime mentioned that he feels not having the time to be an Allwinner
maintainer anymore. Take over from him.
Maxime, many thanks for your great work in the past! I hope I can still
relay the occasional technical question to you in the future.
Acked-by: Maxime Ripard <mripard@kernel.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
On a board without hardware clock this software real time clock can be
used. The build time is used to initialize the RTC. So you will have
to adjust the time either manually using the 'date' command or use
the 'sntp' to update the RTC with the time from a network time server.
See CONFIG_CMD_SNTP and CONFIG_BOOTP_NTPSERVER. The RTC time is
advanced according to CPU ticks.
Add fragment to cover documenation for Xilinx platforms.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Half of this driver is a DM-based timer driver, and half is RISC-V-specific
IPI code. Move the timer portions in with the other timer drivers. The
KConfig is not moved, since it also enables IPIs. It could also be split
into two configs, but no boards use the timer but not the IPI atm, so I
haven't split it.
Reviewed-by: Rick Chen <rick@andestech.com>
This is a regular timer driver, and should live with the other timer
drivers.
Add support for the hardware pseudo random number generator found in Qualcomm SoC-s.
Signed-off-by: Robert Marko <robert.marko@sartura.hr>
Cc: Luka Perkov <luka.perkov@sartura.hr>
This adds the driver for the IPQ40xx built-in MDIO.
This will be needed to support future PHY driver.
This patch adds support for the Qualcomm QUP SPI controller that is commonly found in most of Qualcomm SoC-s.
Driver currently supports v1.1.1, v2.1.1 and v2.2.1 HW.
FIFO and Block modes are supported, no support for DMA mode is planned.
Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr>
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- Activate CMD_EXPORTENV/CMD_IMPORTENV/CMD_ELF for STM32MP15 defconfig
- Fix stm32prog command: parsing of FlashLayout without partition
- Update MAINTAINERS for ARM STM STM32MP
- Manage eth1addr on dh board with KS8851
- Limit size of cacheable DDR in pre-reloc stage in stm32mp1
- Use mmc_of_parse() to read host capabilities in mmc:sdmmc2 driver
Add the STM32MP1 RNG driver in the list of drivers supported by
the STMicroelectronics STM32MP15x series.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Add files and directories regex "stm32" and "stm" in "ARM STM STM32MP"
platform to avoid missing files or drivers supported by the
STMicroelectronics series STM32MP15x.
This patch adds the rules already used in Linux kernel for
ARM/STM32 ARCHITECTURE.
Add MediaTek USB3 Dual-Role controller driver to ARM MEDIATEK,
and add myself as a maintainer for it.
Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
The Fully-Programmable Input/Output Array (FPIOA) device controls pin
multiplexing on the K210. The FPIOA can remap any supported function to any
multifunctional IO pin. It can also perform basic GPIO functions, such as
reading the current value of a pin. However, GPIO functionality remains
largely unimplemented (in favor of the dedicated GPIO peripherals).
This extends the pinctrl-sandbox driver to support pin muxing, and adds a
test for that behaviour. The test is done in C and not python (like the
existing tests for the pinctrl uclass) because it needs to call
pinctrl_select_state. Another option could be to add a command that
invokes pinctrl_select_state and then test everything in
test/py/tests/test_pinmux.py.
The pinctrl-sandbox driver now mimics the way that many pinmux devices
work. There are two groups of pins which are muxed together, as well as
four pins which are muxed individually. I have tried to test all normal
paths. However, very few error cases are explicitly checked for.
Add doc/arch/sandbox.rst to the scope of SANDBOX.
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel into next
First set of u-boot-atmel features for 2021.01 cycle:
This feature set includes a new CPU driver for at91 family, new driver
for PIT64B hardware timer, support for new at91 family SoC named sama7g5
which adds: clock support, including conversion of the clock tree to
CCF; SoC support in mach-at91, pinctrl and mmc drivers update. The
feature set also includes updates for mmc driver and some other minor
fixes and features regarding building without the old Atmel PIT and the
possibility to read a secondary MAC address from a second i2c EEPROM.
Add basic CPU driver use to retrieve information about CPU itself.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Add Microchip PIT64B timer.
Merge in v2020.10-rc5
Add a driver to setup the USB PHY-s on Qualcomm IPQ40xx series SoCs.
The driver sets up HS and SS phys.
On Qualcomm IPQ40xx SoC series, GCC clock IP also handles the resets.
So since this will be needed by further drivers, lets add a driver for the reset controller.
I also followed the development of the SquashFS support in U-Boot
as part of Joao Marcos internship, so I would also appreciate receiving
new contributions and bug reports related to this topic.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
As I have followed the development of the SquashFS support in U-Boot
as part of Joao Marcos work, it makes sense to get Cc'ed on
contributions/bug reports related to the squashfs support.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Import Qualcomm IPQ4019 GCC bindings from Linux.
This will enable using bindings instead of raw clock numbers both in the driver and DTS like Linux does.
Update MAINTAINERS file for new files.
Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Since the current code base is mostly from btrfs-progs, anyone
contributing to U-Boot btrfs code could also help us to improve
btrfs-progs and btrfs kernel module.
Also add myself as designated reviewer.
Signed-off-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: Marek Behún <marek.behun@nic.cz>
I am leaving Socionext. Orphan the UniPhier platform until somebody
takes the role.
Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Update maintainers for Aspeed SoC platforms.
Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
Add Cortina Access LED controller support for CAxxxx SOCs
Signed-off-by: Jway Lin <jway.lin@cortina-access.com>
CC: Simon Glass <sjg@chromium.org>
Add head file fixed link error and remove unused flashing function
Add Python scripts to test 'ls' and 'load' commands. The scripts
generate a SquashFS image and clean the directory after the assertions,
or if an exception is raised.
Signed-off-by: Joao Marcos Costa <joaomarcos.costa@bootlin.com>
