path: root/MAINTAINERS
2009-12-02MAINTAINERS: update responsible for MPC85xx/86xxWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Becky Bruce <beckyb@kernel.crashing.org>
2009-10-24TI OMAP3 SDP3430: Initial SupportTom Rix
Start of support of Texas Instruments Software Development Platform(SDP) for OMAP3430 - SDP3430 Highlights of this platform are: Flash Memory devices: Sibley NOR, Micron 8bit NAND and OneNAND Connectivity: 3 UARTs and expanded 4 UART ports + IrDA Ethernet, USB Other peripherals: TWL5030 PMIC+Audio+Keypad VGA display Expansion ports: Memory devices plugin boards (PISMO) Connectivity board for GPS,WLAN etc. Completely configurable boot sequence and device mapping etc. Support default jumpering and: - UART1/ttyS0 console(legacy sdp3430 u-boot) - UART3/ttyS2 console (matching other boards, and SDP HW docs) - Ethernet - mmc0 - NOR boot Currently the UART1 is enabled by default. for compatibility with other OMAP3 u-boot platforms, enable the #define of CONSOLE_J9. Conflicts: Makefile Fixed the conflict with smdkc100_config by moving omap_sdp3430_config to it is alphabetically sorted location above zoom1. Signed-off-by: David Brownell <david-b@pacbell.net> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-18TI DaVinci: Maintainer for DM355 and DM365 EVMSandeep Paulraj
Adding entries to the MAINTAINERS directory for the DM355 and DM365 EVM. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-18TI: DaVinci: DM355 Leopard board supportSandeep Paulraj
This patch adds support for the leopard board which is based on the DM355 SOC. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-18TI DaVinci DM646x: Adding initial support for DM6467 EVMSandeep Paulraj
This patch adds the initial support for DM6467 EVM. Other features like NET and NAND support will be added as follow up patches. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-13s5pc1xx: add support SMDKC100 boardMinkyu Kang
Adds new board SMDKC100 that uses s5pc100 SoC Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
2009-10-13Support for the OpenRD base boardSimon Kagstrom
The implementation is borrowed from the sheevaplug board and the Marvell 1.1.4 code. Unsupported (or untested) is the SD card, PCIe and SATA. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-10-13Add support for Eukrea CPU9260/CPU9G20 SBCTom Rix
these boards are built around Atmel's AT91SAM9260/9G20 and have up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND and include a 10/100 Ethernet PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13Add support for Eukrea CPUAT91 SBCTom Rix
CPUAT91 is built around Atmel's AT91RM9200 and has up to 16MB of NOR flash, up to 128MB of SDRAM, and includes a Micrel KS8721 PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-09-15Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
2009-09-14microblaze: Remove AtmarkTechno Suzaku boardMichal Simek
Users should use microblaze-generic platform. This platform is longer not supported. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-09-11ppc4xx: Rename compactcenter to intipDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-09-05Add support for the DevKit8000 boardFrederik Kriewitz
This patch adds support for the DevKit8000 board. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
2009-09-02Blackfin: cm-bf537u: new board portHarald Krapfenbauer
The CM-BF537U is similar to the CM-BF537E module, but enough to need its own board port. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-01Support for the Calao TNY-A9260/TNY-A9G20 boardsAlbin Tonnerre
The Calao TNY-A9260 and TNY-9G20 are boards manufactured and sold by Calao Systems <http://www.calao-systems.com>. Their components are very similar to the AT91SAM9260EK board, so their configuration is based on the configuration of this board. There are however some differences: different clocks, no LCD, no ethernet. They also can use SPI EEPROM to store the environment. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-09-01Add support for the Calao SBC35-A9G20 boardAlbin Tonnerre
The Calao SBC35-A9G20 board is manufactured and sold by Calao Systems <http://www.calao-systems.com>. It is built around an AT91SAM9G20 ARM SoC running at 400MHz. It features an Ethernet port, an SPI RTC backed by an onboard battery , an SD/MMC slot, a CompactFlash slot, 64Mo of SDRAM, 256Mo of NAND flash, two USB host ports, and an USB device port. More informations can be found at <http://www.calao-systems.com/articles.php?lng=en&pg=5936> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-09-01imx27lite: add support for imx27lite board from LogicPDIlya Yanok
This patch adds support for i.MX27-LITEKIT development board from LogicPD. This board uses i.MX27 SoC and has 2MB NOR flash, 64MB NAND flash, FEC ethernet controller integrated into i.MX27. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-2885xx: Add support for P2020RDB boardPoonam Aggrwal
The code base adds P1 & P2 RDB platforms support. The folder and file names can cater to future SOCs of P1/P2 family. P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series. Tested following on P2020RDB: 1. eTSECs 2. DDR, NAND, NOR, I2C. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-25Add support for the galaxy5200Eric Millbrandt
Add support for the DEKA Research and Development galaxy5200 board The galaxy5200 is an Freescale mpc5200 based embedded industrial control board. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
2009-07-29Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-07-28ppc4xx: Add GDsys CompactCenter board support.Dirk Eibach
Board support for the Guntermann & Drunck CompactCenter and DevCon-Center. Based on the AMCC Canyonlands board support by Stefan Roese. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-27mpc83xx: Add esd VME8349 board supportReinhard Arlt
This patch adds support for the esd VME8349 board equipped with the MPC8349. It's a VME PMC carrier board equipped with the Tundra TSI148 VME-bridge. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-24ppc4xx: Add 405EP based PMC405DE boardMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24xpedite1k: Move to X-ES vendor directoryPeter Tyser
The XPedite1000 is an X-ES product thus it can be put in board/xes along with other X-ES boards. Along with the move, the board was renamed to XPedite1000 from XPedite1K to fit X-ES's standard naming convention. Maintainership was also transfered to Peter Tyser. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Add DL-Vision 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck DL-Vision. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-23Marvell RD6281A Board supportPrafulla Wadaskar
This is Marvell's 88F6281_A0 based reference design board This patch is tested for- 1. Boot from DRAM/NAND flash/NFS 2. File transfer using tftp and loadb 3. NAND flash read/write/erase Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-18Marvell MV88F6281GTW_GE Board supportPrafulla Wadaskar
This is Marvell's 88F6281_A0 based custom board developed for wireless access point product This patch is tested for- 1. Boot from DRAM/SPI flash/NFS 2. File transfer using tftp and loadb 3. SPI flash read/write/erase 4. Booting Linux kernel and RFS from SPI flash 5. Boot from USB supported Reviewed-by: Ronen Shitrit <rshitrit@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-18Marvell Sheevaplug Board supportPrafulla Wadaskar
Reference: http://plugcomputer.org/ http://openplug.org/plugwiki/index.php/Das_U-boot_plug_support This patch is tested for- 1. Boot from DRAM/NAND flash 2. File transfer using tftp 3. NAND flash read/write/erase 4. Linux kernel and RFS Boot from NAND 5. Enabled USB PHY init for kernel need 6. Boot from USB supported Note: to boot Kirkwood kernel with USB support, you should add "usb start" in the boot sequence Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-14Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-10board support patch for phyCORE-MPC5200B-tinyJon Smirl
Add support for the Phytec phyCORE-MPC5200B-tiny. Code originally from Pengutronix.de. Created CONFIG_SYS_ATA_CS_ON_TIMER01 define for when IDE CS is on Timer 0/1 Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2009-07-09MAINTAINERS: fix sorting, remove duplicates.Wolfgang Denk
2009-07-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
Conflicts: drivers/spi/Makefile Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-06xscale: add support for the polaris boardStefano Babic
The Polaris board is based on the TrizepsIV module of Keith & Koep (http://www.keith-koep.com). Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-07-06at91: Add esd gmbh MEESC board supportDaniel Gorsulowski
This patch adds support for esd gmbh MEESC board. The MEESC is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-07-06MX31: Add basic support for Freescale i.MX31 PDK board.Magnus Lilja
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board). This patch assumes that some other program performs the actual NAND boot. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Acked-by: Fabio Estevam <fabioestevam@yahoo.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-0186xx: XPedite5170 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5170 - a MPC8640-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-21at91: add support for the PM9261 board of Ronetix GmbHIlko Iliev
The PM9261 board is based on the AT91SAM9261-EK board. Here is the page on Ronetix website: http://www.ronetix.at/starter_kit_9261.html Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-14Blackfin: ibf-dsp561: new board portHoan Hoang
Signed-off-by: Hoan Hoang <hnhoan@i-syst.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: blackstamp: new board portMike Frysinger
2009-06-14Blackfin: bf537-srv1: new board portMike Frysinger
2009-06-14Blackfin: bf537-minotaur: new board portMike Frysinger
2009-06-14Blackfin: bf537-pnav: new board portMike Frysinger
2009-06-14Blackfin: cm-bf527: new board portMike Frysinger
2009-06-14Blackfin: cm-bf548: new board portMike Frysinger
2009-06-14Blackfin: tcm-bf537: new board portMike Frysinger
