Fix early board initialization for Cogent CSB272 board
* Patch by Ed Okerson, 3 Mar 2004:
fix CFI flash writes for little endian systems
* Patch by Reinhard Meyer, 01 Mar 2004:
generalize USB and IDE support for MPC5200 with according
changes to IceCube.h and TOP5200.h
add Am29LV256 256 MBit FLASH support for TOP5200 boards
add info about USB and IDE to README
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA)
- Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF)
- Added support for 64bit strtoul (CFG_64BIT_STRTOUL)
* Patch by Masami Komiya, 27 Feb 2004:
Fix rarpboot: add autoload by NFS
* Patch by Dan Eisenhut, 26 Feb 2004:
fix flash_write return value in saveenv
* Patch by Stephan Linz, 11 Dec 2003
expand config.mk to avoid trigraph warnings on NIOS
* Rename "BMS2003" board into "HMI10"
- Timeouts in FPGA code should be based on CFG_HZ
- Minor cleanup in code for Altera FPGA ACEX1K
* Patch by Steven Scholz, 25 Feb 2004:
Changed "Directory Hierarchy" section in README
* Patch by Masami Komiya, 25 Feb 2004:
Reduce copy count in nfs_read_reply() of NFS code
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
Add support for NET+50 CPU and ModNET50 board
* Patch by Sam Song, 10 Feb 2004:
Fix typos in cfi_flash.c
* Patch by Leon Kukovec, 10 Feb 2004
Fixed long dir entry slot id calculation in get_vfatname
* Patch by Robin Gilks, 10 Feb 2004:
add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==,
* Cleanup compiler warnings
* Fix problem with side effects in macros in include/usb.h
* Patch by David Benson, 13 Nov 2003:
bug 841358 - fix TFTP download size limit
* Fixing bug 850768:
improper flush_cache() in load_serial()
* Fixing bug 834943:
MPC8540 - missing volatile declarations
* Patch by Stephen Williams, 09 Feb 2004:
Add support for Xilinx SystemACE chip:
- New files common/cmd_ace.c and include/systemace.h
- Hook systemace support into cmd_fat and the partition manager
* Patch by Travis Sawyer, 09 Feb 2004:
Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
Allow bzip2 compression for small memory footprint boards
* Patch by Brad Kemp, 21 Jan 2004:
Add support for CFI flash driver for both the Intel and the AMD
command sets.
* Patch by Travis Sawyer, 20 Jan 2004:
Fix pci bridge auto enumeration of sibling p2p bridges.
* Patch by Tolunay Orkun, 12 Jan 2004:
Add some delays as needed for Intel LXT971A PHY support
* Patches by Stephan Linz, 09 Jan 2004:
- avoid warning: unused variable `piop' in board/altera/common/sevenseg.c
- make DK1C20 board configuration related to ASMI conform to
documentation
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
see doc/README.MPC866 for details;
implement workaround for "SIU4" and "SIU9" silicon bugs on MPC866;
calculate CPU clock frequency from PLL register values.
* Add support for 128 MB RAM on TQM8xxL/M modules
* Patch by Scott McNutt, 02 Jan 2004:
Add support for the Nios Active Serial Memory Interface (ASMI)
on Cyclone devices
* Patch by Andrea Marson, 16 Dec 2003:
Add support for the PPChameleon ME and HI modules
* Patch by Yuli Barcohen, 22 Dec 2003:
Add support for Motorola DUET ADS board (MPC87x/88x)
Add support for the Marvell DB64360 / DB64460 development boards
* Patch by Detlev Zundel, 10 Dec 2003:
fix dependency problem in examples/Makefile
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
environment variable which can set to "100", "133", or "150". The
CPU clock will be configured accordingly upon next reboot. Other
values are ignored. In case of an invalid or undefined "cpuclk"
value, the compile-time default CPU clock speed will be used.
* Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory
window that is used to access the UART registers by the Linux driver)
* Patch by Reinhard Meyer, 20 Dec 2003:
Fix clock calculation for the MPC5200 for higher clock frequencies
(above 2**32 / 10 = 429.5 MHz).
Add support for SNMC's QS850/QS823/QS860T boards
add Realtek 8019 ethernet driver
* Patch by Yuli Barcohen, 13 Nov 2003:
MPC826xADS/PQ2FADS cleanup
* Patch by Anders Larsen, 12 Nov 2003:
Update README to mark the PORTIO commands non-standard
update for for Atmel AT91RM9200DK development kit:
- support for environment variables in DataFlash
- Atmel DataFlash AT45DB1282 support
* Patch by Jeff Carr, 11 Nov 2003:
add support for new version of 8270 processors
* Patches by George G. Davis, 05 Nov 2003:
- only pass the ARM linux initrd tag to the kernel when an initrd
is actually present
- update omap1510inn configuration file
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
(featuring a NEC NL6448BC33-54. 10.4", 640x480 TFT display).
Fix NEC display names (it's 6440 [for 640x480], not 6640).
Fix AT91RM9200 ethernet driver
* Patch by Nye Liu, 17 Oct 2003:
Fix typo in include/mpc8xx.h
* Patch by Richard Woodruff, 16 Oct 03:
Fixes for cpu/arm925/interrupt.c
- Initialize timestamp & lastdec vars.
- fix timestamp overflows.
- fix lastdec overflow.
- smarter normalization to allow udelay() below 1ms to work.
* Patch by Scott McNutt, 16 Oct
add networking support for the Altera Nios Development Kit,
Cyclone Edition (DK-1C20)
* Patch by Jon Diekema, 14 Oct 2003:
add hint about doc/README.silent to README file
header on image type as encoded in the header
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
- Add support for Altera FPGA ACEX1K
* Patches by Thomas Lange, 09 Oct 2003:
- Endian swap ATA identity for all big endian CPUs, not just PPC
- MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize
args to linux
- add support for dbau1x00 board (MIPS32)
add support for Zephyr Engineering ZPC.1900 board
* Patch by Anders Larsen, 23 Sep 2003:
add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only
implemented for the x86 architecture)
fix pll_pci_to_mem_multiplier table for MPC8245
* Patch by Anders Larsen, 22 Sep 2003:
enable timed autoboot on PXA
* Patch by David Müller, 22 Sep 2003:
- add $(CFLAGS) to "-print-libgcc-filename" so compiler driver
returns correct libgcc file path
- "latency" reduction of busy-loop waiting to improve "U-Boot" boot
time on s3c24x0 systems
* Patch by Jon Diekema, 19 Sep 2003:
- Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet
link state to the fault LED.
- In NetLoop, make the Fault LED reflect the link status. The link
status gets updated on entry, and on timeouts.
- update README (SHOW_BOOT_PROGRESS values for cmd_nand.c and
env_common.c)
- sbc8260 tweaks
- adjust "help" output
- fix spelling errors
- set GD_FLG_DEVINIT flag only after device function pointers
are valid
- Allow CFG_ALT_MEMTEST on systems where address zero isn't
writeable
- enable 3.rd UART (ST-UART) on PXA(XScale) CPUs
- trigger watchdog while waiting in serial driver
- add description for missing CFG_CMD_* entries in the README file
- sacsng tweaks:
include/configs/sacsng.h:
+ Support extra bootp options like: 2nd DNS and send hostname
+ Enabling ping and irq command
+ Adding defines for a bunch of misc configrabled options
(patches for these options will be coming)
+ Adding watchdog support, but it isn't enabled yet.
board/sacsng/sacsng.c:
+ Suppressing unneeded output when the quiet environment
is non-zero.
+ show_boot_progress() now accepts any negative number as a
failure code.
+ show_boot_progress() flashes the error code 5 times, and
then resets the board to retry the boot from the top
* Patch by Gleb Natapov, 14 Sep 2003:
enable watchdog support for all MPC824x boards that have a watchdog
various changes to VCMA9 board specific files
* Add I2C support for MGT5100 / MPC5200
* Add PCI support for SL8245 board
* Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB)
or 1 x AM29LV652 (two LV065 in one chip = 16 MB);
Run IPB at 133 Mhz; adjust the MII clock frequency accordingly
* Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz)
to allow for more accurate baudrate settings
(error now 0.7% at 115 kbps, instead of 3.5% before)
* Patch by Andreas Mohr, 4 Sep 2003:
Fix a lot of spelling errors
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
fix TI Innovator/OMAP1510 pin configs
* Patches by Kshitij, 18 Aug 2003
- add support for arm926ejs cpu core
- add support for TI OMAP 1610 Innovator Board
add support for bzip2 uncompression
Add support for LynuxWorks Kernel Downloadable Images (KDIs).
Both LynxOS and BlueCat linux KDIs are supported.
* Patch by Richard Woodruff, 25 Jul 2003:
use more reliable reset for OMAP/925T
* Patch by Nye Liu, 25 Jul 2003:
fix typo in mpc8xx.h
* Patch by Richard Woodruff, 24 Jul 2003:
Fixes for cmd_nand.c:
- Fixed null dereferece which could result in incorrect ECC values.
- Added support for devices with no Ready/Busy signal hooked up.
- Added OMAP1510 read/write protect handling.
- Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock
for non-JFFS2.
- Switched default ECC to be JFFS2.
add delay to get I2C working with "imm" command and s3c24x0_i2c.c
* Patch by Richard Woodruff, 17 July 03:
- Fixed bug in OMAP1510 baud rate divisor settings.
* Patch by Nye Liu, 16 July 2003:
MPC860FADS fixes:
- add MPC86xADS support (uses MPC86xADS.h)
- add 866P/T core support (also MPC859T/MPC859DSL/MPC852T)
o PLPRCR changes
o BRG changes (EXTAL/XTAL restricted to 10MHz)
o don't trust gclk() software measurement by default, depend on
CONFIG_8xx_GCLK_FREQ
- add DRAM SIMM not installed detection
- use more "correct" SDRAM initialization sequence
- allow different SDRAM sizes (8xxADS has 8M)
- default DER is 0
- remove unused MAMR defines from FADS860T.h (all done in fads.c)
- rename MAMR/MBMR defines to be more consistent. Should eventually
be merged into MxMR to better reflect the PowerQUICC datasheet.
* Patch by Yuli Barcohen, 16 Jul 2003:
support new Motorola PQ2FADS-ZU evaluation board which replaced
MPC8260ADS and MPC8266ADS
- added support for arm925t cpu core
- added support for TI OMAP 1510 Innovator Board
- add I2C support for s3c2400 systems (trab board)
- (re-) add "ping" to command table
* Fix handling of "slow" POST routines
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
Improve documentation of I2C configuration in README
* Fix problems with previous log buffer "fixes"
* Fix minor help text issues
* "log append" did not append a newline
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
added CONFIG_750FX support for IBM 750FX processors
- add support for Logotronic DL datalogger board
- cleanup serial line after kermit binary download
- add debugX macro (debug level support)
- update mach-types.h to latest arm.linux.org.uk master list.
Modifications for Atmel AT91RM9200DK ARM920T based development kit
- Add Atmel DataFlash support for reading and writing.
- Add possibility to boot a Linux from DataFlash with BOOTM command.
- Add Flash detection on Atmel AT91RM9200DK
(between Atmel AT49BV1614 and AT49BV1614A flashes)
- Replace old Ethernet PHY layer functions
- Change link address
* Patch by Frank Smith, 9 Jun 2003:
use CRIT_EXCEPTION for machine check on 4xx
* Patch by Detlev Zundel, 13 Jun 2003:
added implementation of the "carinfo" command in cmd_immap.c
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
