path: root/README
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-04-09arm: at91: Remove CONFIG_AT91_HW_WDT_TIMEOUTStefan Roese
This patch removes the CONFIG_AT91_HW_WDT_TIMEOUT as its not needed any more. The WD timeout value can be provided via the "timeout-sec" DT property. If not provided this way, the default value of 2 seconds will be used. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-02-22preboot: Introduce CONFIG_USE_PREBOOT and migrate CONFIG_PREBOOTMasahiro Yamada
This is the same migration path as commit b6251db8c3f0 ("Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND"). I also moved the description in README to the Kconfig help. I ripped off the sentence about 'LWMON' since it is gone already. I only let my boards migrate, leaving the rest to platform maintainers. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-02-14i2c: Remove ancient zynq_i2c driverMichal Simek
This driver is replaced by drivers/i2c/i2c-cdns.c DM based driver. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Heiko Schocher <hs@denx.de>
2019-02-02Kconfig: Migrate CONFIG_BUILD_TARGETJagan Teki
Migrate CONFIG_BUILD_TARGET into Kconfig. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-01-25configs: Migrate CONFIG_DFU_MMC againTom Rini
A few platforms recently added in CONFIG_DFU_MMC under include/configs rather than via the defconfig, update them. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-24net: remove CONFIG_MCAST_TFTPChris Packham
No mainline board enables CONFIG_MCAST_TFTP and there have been compilation issues with the code for some time. Additionally, it has a potential buffer underrun issue (reported as a side note in CVE-2018-18439). Remove the multicast TFTP code but keep the driver API for the future addition of IPv6. Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-11-27spi: Zap CONFIG_HARD_SPIJagan Teki
In legacy CONFIG_HARD_SPI initalizing spi_init code, which was removed during dm conversion cleanup. So remove the dead instances of CONFIG_HARD_SPI, and related code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-10-02Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
This is the PR for SPI-NAND changes along with few spi changes. [trini: Re-sync changes for ls1012afrwy_qspi*_defconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-22MIPS: cache: remove config option CONFIG_SYS_MIPS_CACHE_MODEDaniel Schwierzeck
Caches should be configured to mode CONF_CM_CACHABLE_NONCOHERENT (or CONF_CM_CACHABLE_COW when a CM is available). There is no need to make this configurable. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-22MIPS: start.S: make boot config at offset 0x10 configurableDaniel Schwierzeck
Some MIPS systems store some board-specific boot configuration in the U-Boot binary at offset 0x10. This is used by Malta boards and by Lantiq/Intel SoC's when booting from parallel NOR flash. Convert the hard-coded values to Kconfig options to remove such board-specific stuff out of the generic start.S code. This also deprecates the config option CONFIG_SYS_XWAY_EBU_BOOTCFG. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-20mtd: move NAND files into a raw/ subdirectoryMiquel Raynal
NAND flavors, like serial and parallel, have a lot in common and would benefit to share code. Let's move raw (parallel) NAND specific code in a raw/ subdirectory, to ease the addition of a core file in nand/ and the introduction of a spi/ subdirectory specific to SPI NANDs. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2018-09-10Remove CONFIG_USE_STDINTMasahiro Yamada
You do not need to use the typedefs provided by compiler. Our compilers are either IPL32 or LP64. Hence, U-Boot can/should always use int-ll64.h typedefs like Linux kernel, whatever the typedefs the compiler internally uses. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-08-10README: U_BOOT_ENV_CALLBACK functionsHeinrich Schuchardt
Describe the interface of environment variable callback functions. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-27spl, nand: add option CONFIG_SPL_NAND_IDENT to lookup for supported NAND chipsJörg Krause
Add the config option `CONFIG_SPL_NAND_IDENT` for using the NAND chip ID list to identify the NAND flash in SPL. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks>
2018-05-29configs: remove CONFIG_SYS_MVFSChris Packham
This was being used by some Marvell boards to enable some file system related features (many of which have already been moved to Kconfig). Make the future migration of the final 2 or 3 config options easier by expanding #define CONFIG_SYS_MVFS into the options that it enables and remove CONFIG_SYS_MVFS. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-23fit: Fix CONFIG_FIT_SPL_PRINTMarek Vasut
Rename CONFIG_FIT_SPL_PRINT to CONFIG_SPL_FIT_PRINT and add Kconfig entry for it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-23Convert CONFIG_SUPPORT_EMMC_RPMB to KconfigAlex Kiernan
Convert CONFIG_SUPPORT_EMMC_RPMB to Kconfig. Split the command handling from the underlying support and expose this through CMD_MMC_RPMB. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-28Migrate IMAGE_FORMAT_LEGACY to KconfigAlex Kiernan
This converts IMAGE_FORMAT_LEGACY to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-08Cleanup CONFIG_VERSION_VARIABLE migrationAlex Kiernan
CONFIG_VERSION_VARIABLE had already been mostly migrated to Kconfig, but two headers still referenced it. Also set defaults so that most of the defconfigs inherit the default rather than needing it to be set explicitly. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-06Migrate CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSCAlex Kiernan
This converts CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-03-24Convert CONFIG_UBI_SILENCE_MSG to KconfigPetr Vorel
Signed-off-by: Petr Vorel <petr.vorel@gmail.com>
2018-03-24Convert CONFIG_UBIFS_SILENCE_MSG to KconfigPetr Vorel
Introduce another difference from upstream (kernel) source in fs/ubifs/super.c: adding preprocessor condition as y variable in mount_ubifs() depends on CONFIG_UBIFS_SILENCE_MSG: fs/ubifs/super.c:1337:15: error: variable ?y? set but not used [-Werror=unused-but-set-variable] long long x, y; Not setting CONFIG_UBIFS_SILENCE_MSG in am335x_igep003x_defconfig and igep0032_defconfig. Although it was defined in their config headers, it depends on CMD_UBIFS which is not set for them. Signed-off-by: Petr Vorel <petr.vorel@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Heiko Schocher <hs@denx.de>
2018-03-13Move CONFIG_PHY_ADDR to KconfigStefan Mavrodiev
CONFIG_PHY_ADDR is used for old-style configuration. This makes impossible changing the PHY address, if multiple boards share a same config header file (for example include/configs/sunxi-common.h). Moving this to Kconfig helps overcoming this issue. It's defined as entry inside PHYLIB section. After the implemention, moveconfig was run. The issues are: - edb9315a - CONFIG_PHYLIB is not enabled. Entry is deleted. - ds414 - CONFIG_PHYLIB is in incompatible format: { 0x1, 0x0 }. This entry is also deleted. - devkit3250 - The PHY_ADDR is in hex format (0x1F). Manually CONFIG_PHY_ADDR=31 is added in the defconfig. After the changes the suspicious defconfigs passes building. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [jagan: rebased on master] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-02-24Integrate AT91 bootcount driverAlex Kiernan
Integrate Boot counter for Atmel AT91SAM9XE into Kconfig Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-24Convert CONFIG_BOOTCOUNT_EXT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_EXT Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-24Convert CONFIG_BOOTCOUNT_I2C to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_I2C Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-24Convert CONFIG_BOOTCOUNT_RAM to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_RAM Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-24Convert CONFIG_BOOTCOUNT_ENV to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_ENV Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-24Convert CONFIG_BOOTCOUNT_AM33XX to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_AM33XX Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-21dfu: Rename _FUNCTION_DFU to DFU_OVER_Marek Vasut
Do the following to make the symbol names less confusing. sed -i "s/\([TU][^_]\+\)_FUNCTION_DFU/DFU_OVER_\1/g" \ `git grep _FUNCTION_DFU | cut -d ":" -f 1 | sort -u` Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Lukasz Majewski <lukma@denx.de>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_SH_SPI to KconfigTuomas Tynkkynen
2018-02-08block: Migrate SystemACE chip to KconfigTom Rini
Migrate the base and sub-options to Kconfig. Note that we only enable this in the base sandbox config now. Cc: Alexey Brodkin <alexey.brodkin@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- Is this driver still used anywhere? It's fishy that it's only enabled in sandbox anymore.
2018-02-04README: add doc for how to supply user specific compiler flags to KbuildDaniel Schwierzeck
Probably not all users are aware of this possibility, thus add a pointer to the README. Also add a useful example. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-01-12riscv: doc: Add relative doc to describe RISC-VRick Chen
Add documents to describe NX25 and AE250. Also update other documents for RISC-V. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
2017-12-27Merge git://git.denx.de/u-boot-dmTom Rini
