path: root/README
2016-10-06PWM: Correct misspellings of "module" in context of PWMRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Heiko Schocher <hs@denx.de>
2016-10-06README: Drop CONFIG_SYS_USE_OSCCLKSimon Glass
This is not used in U-Boot so drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_SYS_INIT_DATA_SIZESimon Glass
This appears to be calculated automatically now. Drop the old reference. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: i2c: Drop unused i2c CONFIG optionsSimon Glass
CONFIG_SYS_NUM_I2C_ADAPTERS and CONFIG_SYS_I2C_MULTI_NOPROBES are not used in U-Boot, so drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: sh: Drop CONFIG_SYS_I2C_SH_BASE5Simon Glass
This is not used in U-Boot. Drop both the BASE and the SIZE config. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_SYS_USB_BRG_CLKSimon Glass
This is not used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_LAN91C96_BASESimon Glass
2016-10-06README: Drop CONFIG_OF_BOOT_CPUSimon Glass
2016-10-06README: Drop unused CONFIG_SYS_LS_MC_FW_... optionsSimon Glass
Drop a few that are not used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop unused JFFS2 optionsSimon Glass
There appear to be neither implemented nor used. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Correct CONFIG_ENV_OFFSET_RENDUND typoSimon Glass
Change this to CONFIG_ENV_OFFSET_REDUND. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_COGENT and related optionsSimon Glass
These are no-longer present in U-Boot. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop old Intel Monahans commentSimon Glass
This is no longer in the U-Boot source code, so drop this note from the README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-01fastboot: move FASTBOOT_FLASH options into KconfigPetr Kulhavy
Move FASTBOOT_MBR_NAME and FASTBOOT_GPT_NAME into Kconfig. Add dependency on the FASTBOOT_FLASH setting (also for FASTBOOT_MBR_NAME). Remove the now redundant GPT_ENTRY_NAME. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Add FIXME about xxx_PARTITION needing to be in Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-01fastboot: add support for writing MBRPetr Kulhavy
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
trini: Drop local memset() from examples/standalone/mem_to_mem_idma2intr.c Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Kconfig: spl: Add SPL support options to KconfigSimon Glass
There are a lot of SPL options in U-Boot to enable various features and drivers. Currently these do not use Kconfig. Add them to Kconfig along with suitable help, and drop them from the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-14armv8: ls2080a: Remove debug server supportYork Sun
Debug server feature has been dropped from roadmap. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-06README: add cmd directory descriptionXu Ziyuan
All of the command files have moved to cmd directory, add description to Directory Hierarchy. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-31Drop references to MAKEALL in the documentationSimon Glass
It is confusing to mention MAKEALL when it is not the normal way of building U-Boot anymore. Update the documentation to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-27Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2016-07-22fixing typo error in README file. CPU15 -> CP15yeongjun Kim
It looks typo error. Not CPU15, CP15(CoProcessor15) Signed-off-by: yeongjun Kim <iam.yeongjunkim@gmail.com>
2016-07-22spl: Lightweight UBI and UBI fastmap supportThomas Gleixner
Booting a payload out of NAND FLASH from the SPL is a crux today, as it requires hard partioned FLASH. Not a brilliant idea with the reliability of todays NAND FLASH chips. The upstream UBI + UBI fastmap implementation which is about to brought to u-boot is too heavy weight for SPLs as it provides way more functionality than needed for a SPL and does not even fit into the restricted SPL areas which are loaded from the SoC boot ROM. So this provides a fast and lightweight implementation of UBI scanning and UBI fastmap attach. The scan and logical to physical block mapping code is developed from scratch, while the fastmap implementation is lifted from the linux kernel source and stripped down to fit the SPL needs. The text foot print on the board which I used for development is: 6854 0 0 6854 1abd drivers/mtd/ubispl/built-in.o Attaching a NAND chip with 4096 physical eraseblocks (4 blocks are reserved for the SPL) takes: In full scan mode: 1172ms In fastmap mode: 95ms The code requires quite some storage. The largest and unknown part of it is the number of fastmap blocks to read. Therefor the data structure is not put into the BSS. The code requires a pointer to free memory handed in which is initialized by the UBI attach code itself. See doc/README.ubispl for further information on how to use it. This shares the ubi-media.h and crc32 implementation of drivers/mtd/ubi There is no way to share the fastmap code, as UBISPL only utilizes the slightly modified functions ubi_attach_fastmap() and ubi_scan_fastmap() from the original kernel ubi fastmap implementation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-19Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: arch/arm/cpu/armv8/Makefile arch/arm/lib/bootm-fdt.c
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-07-15armv8: Move secure_ram variable out of generic global dataYork Sun
Secure_ram variable was put in generic global data. But only ARMv8 uses this variable. Move it to ARM specific data structure. Signed-off-by: York Sun <york.sun@nxp.com>
2016-07-14README: Remove CONFIG_SYS_MALLOC_F_LEN commentSimon Glass
This option is now widely available, so remove the comment that it is only available on ARM and sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-11video: allow version string to be optional when using LOGOTim Harvey
The CONFIG_HIDE_LOGO_VERSION config can be used to disable putting the U-Boot version string on top of the logo. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-07-01doc: bootdelay: drop explanation about CONFIG_BOOTDELAY from READMEMasahiro Yamada
The same information now exists in common/Kconfig. Do not duplicate documentation from the point of view of maintainability. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-06-12arm: Allow skipping of low-level init with I-cache onSimon Glass
At present CONFIG_SKIP_LOWLEVEL_INIT prevents U-Boot from calling lowlevel_init(). This means that the instruction cache is not enabled and the board runs very slowly. What is really needed in many cases is to skip the call to lowlevel_init() but still perform CP15 init. Add an option to handle this. Reviewed-by: Heiko Schocher <hs@denx.de> Tested-on: smartweb, corvus, taurus, axm Tested-by: Heiko Schocher <hs@denx.de> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-05-27Remove/update old generic-board documentation and warningSimon Glass
Remove the warning from the Makefile, since boards that do not use generic board will no longer build. Also update documentation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-05-20cmd: eeprom: add support for layout aware commandsNikita Kiryanov
Introduce the (optional) eeprom print and eeprom update commands. These commands are eeprom layout aware: * The eeprom print command prints the contents of the eeprom in a human readable way (eeprom layout fields, and data formatted to be fit for human consumption). * The eeprom update command allows user to update eeprom fields by specifying the field name, and providing the new data in a human readable format (same format as displayed by the eeprom print command). * Both commands can either auto detect the layout, or be told which layout to use. New CONFIG options: CONFIG_CMD_EEPROM_LAYOUT - enables commands. CONFIG_EEPROM_LAYOUT_HELP_STRING - tells user what layout names are supported Feature API: __weak int parse_layout_version(char *str) - override to provide your own layout name parsing __weak void __eeprom_layout_assign(struct eeprom_layout *layout, int layout_version); - override to setup the layout metadata based on the version __weak int eeprom_layout_detect(unsigned char *data) - override to provide your own algorithm for detecting layout version eeprom_field.c - contains various printing and updating functions for common types of eeprom fields. Can be used for defining custom layouts. Cc: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2016-05-17Merge git://git.denx.de/u-boot-dmTom Rini
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17SPL: Add CONFIG_SPL_ABORT_ON_RAW_IMAGEMarek Vasut
When defined, SPL will proceed to another boot method if the image it has loaded does not have a signature. This is useful if the subsequent boot methods are much more complex. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Peng Fan <van.freenix@gmail.com> Cc: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-11README: Specify the full path for README.videoFabio Estevam
It is clearer to specify the full path to access the doc/README.video file. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-01README: Specify the full path for README.displaying-bmpsFabio Estevam
It is clearer to specify the full path to access the doc/README.displaying-bmps file. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-03-22Add an option to enable the command lineSimon Glass
Add a new Kconfig option for the command line. This is enabled by default, but when disabled it will remove the command line. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-26net: bootp: Add environment variable for timeout periodAlexandre Messier
There is currently one config option (CONFIG_NET_RETRY_COUNT) that is available to tune the retries of the network stack. Unfortunately, it is global to all protocols, and the value is interpreted differently in all of them. Add a new environment variable that directly sets the retry period for BOOTP timeouts. If this new value is not set, the period is still derived from the default number of retries, or from CONFIG_NET_RETRY_COUNT if defined. When both the new variable is set and CONFIG_NET_RETRY_COUNT is defined, the variable has precedence. Signed-off-by: Alexandre Messier <amessier@tycoint.com>
2016-02-08doc: Remove any reference to CONFIG_MODEM_SUPPORT, CONFIG_CMD_HWFLOW, ↵David Müller (ELSOFT AG)
CONFIG_HWFLOW and friends from the documentation. Signed-off-by: David Müller <d.mueller@elsoft.ch>
2016-02-08hush: Add rudimentary support for PS1 and PS2Marek Vasut
Add trivial support for changing the U-Boot command prompt string by setting PS1 and PS2 environment variables. Only static variables are supported. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-28tpm: st33zp24: Add tpm st33zp24 spi supportChristophe Ricard
Add support for TPM ST33ZP24 spi. The ST33ZP24 does have a spi interface. The transport protocol is proprietary. For spi we are relying only on DM_SPI. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
2016-01-28tpm: st33zp24: Add tpm st33zp24 support with i2cChristophe Ricard
Add support for TPM ST33ZP24 family with i2c. For i2c we are relying only on DM_I2C. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
2016-01-25common/console.c: Remove unused inline functionsTom Rini
clang-3.8 reports that these functions are unused, remove them. As this is the last part of CONFIG_MODEM_SUPPORT_DEBUG, drop that from README. Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-14README: Review the u-boot porting guide listPhil Sutter
* There is no boards.cfg anymore, so drop (1). * Creating flash.c and u-boot.lds seems not mandatory as well. * Adjusting the enumerators for the above implicitly fixed for double items numbered (3). Signed-off-by: Phil Sutter <phil@nwl.cc> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-08doc: Tidy up first part of top-level README fileRobert P. J. Day
First (small) pass at tidying up the README file, including: * remove references to obsolete CREDITS file * remove (some) references to obsolete boards.cfg file * remove at least one reference to a "scrapped" board * cut down unnecessarily detailed directory hierarchy * bunch of grammar and spelling tweaks Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2015-12-15armv8: fsl-layerscale: Rewrite reserving memory for MC and debug serverYork Sun
MC and debug server are not board-specific. Move reserving memory to SoC file, using the new board_reserve_ram_top function. Reduce debug server memory by 2MB to make room for secure memory. In the system with MC and debug server, the top of u-boot memory is not the end of memory. PRAM is not used for this reservation. Signed-off-by: York Sun <yorksun@freescale.com>
