path: root/README
2011-12-21Add CONFIG_DELAY_CONSOLE to delay console initSimon Glass
This option delays console initialization until after relocation. This can save time if this init is relatively expensive, since after relocation the CPU is often running much faster. This option should be used in conjunction with CONFIG_PRE_CONSOLE_BUFFER to ensure that all console output is buffered until the console is ready for it. This saves about 30ms boot time. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I3a774b418d45e7be9338f9942df445c2c2baa528 Reviewed-on: https://gerrit.chromium.org/gerrit/13207 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-11-17BACKPORT: net: tftpput: implement tftp logicSimon Glass
This adds logic to tftp.c to implement the tftp 'put' command, and updates the README. (cherry-picked from 1fb7cd4) Change-Id: I01fc2ca4d974416083e913597791676bbd0934ae Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/11801
2011-10-04console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped. Signed-off-by: Graeme Russ <graeme.russ@gmail.com> Change-Id: I3c4caad276b9e981ebea0a0fb79d85ee3a3bcb7d Reviewed-on: http://gerrit.chromium.org/gerrit/8686 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29Add a CBFS driver and commands to u-boot.Gabe Black
This change adds CBFS support and some commands to use it to u-boot. These commands are: cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used. cbfsinfo - Print information from the CBFS header. cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names. cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size. Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified. BUG=chrome-os-partner:3910 TEST=Built and booted on an Alex. Initialized with and without specifying the end of the ROM, and with a bad end of ROM. Ran the commands before CBFS was initialized. Ran cbfsinfo and saw reasonable output. Ran cbfsls and saw output that matched what was printed when the CBFS was put together by the coreboot ebuild. Used cbfsload to load a test text file into memory and verified that it was the correct size and had the correct contents. Ran with a max size and saw the file was truncated in memory. Change-Id: I64d06d49633cef3cffac1d571519eae38c7d267f Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: http://gerrit.chromium.org/gerrit/4167 Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-08-29CHROMIUM: ARM: Allow the FDT to specify that the env loads early.Doug Anderson
This is intended for using with the 'legacy' image to allow us to update the enviroment shipped with the image. BUG=chromium-os:17196 TEST=With ebuild changes, saw that legacy firmware loaded env and non-legacy got default. Change-Id: Iee19df02123ab2502e4803c25c94318b0e834f6d Reviewed-on: http://gerrit.chromium.org/gerrit/4056 Tested-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-29Add CONFIG_DISPLAY_BOARDINFO_LATE to display board info on LCDSimon Glass
This option displays board info after stdio is running, so that it will appear on the LCD. BUG=chromium-os:11623 TEST=build and boot with option set, see that this is the first thing displayed on the LCD Change-Id: Ideee94cadbc9670d6f2832692ba019d3e9b260ec Reviewed-on: http://gerrit.chromium.org/gerrit/3501 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29Add CONFIG_DELAY_ENVIRONMENT to delay environment loadingSimon Glass
This option delays loading of the environment until later, so that only the default environment will be available to U-Boot. BUG=chromium-os:17055 TEST=build U-Boot with option enabled, see that environment is not available Change-Id: I99a25b468fb5d14310b00eb3fd4c3e6a0c5cbe2b Reviewed-on: http://gerrit.chromium.org/gerrit/3534 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29Add some documentation for the new i386 specific configuration options.Gabe Black
BUG=chrome-os-partner:3895 TEST=None needed. Change-Id: I5d35c04f65f98aced54cea6599f3fefb6f745e6d Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: http://gerrit.chromium.org/gerrit/3330 Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-08-29fdt: Add DEV_TREE_SEPARATE to provide an fdt separate from imageSimon Glass
This adds support for an FDT to be concatenated to the u-boot-bin binary. This is located at run-time by U-Boot. BUG=chromium-os:11623 TEST=Either emerge with http://gerrit.chromium.org/gerrit/2961 or build manually: make ... DEV_TREE_SEPARATE=true and check that u-boot.dtb is built. Change-Id: I7c8b1315d721bc957ef3fd07f167d86345868036 Reviewed-on: http://gerrit.chromium.org/gerrit/2962 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29Add CONFIG_ALIGN_LCD_TO_SECTION to make frame buffer MMU-friendlySimon Glass
We want to make the display section-aligned on ARM so that we can easily turn off data caching for this. BUG=chromium-os:13082 TEST=build and boot U-Boot on seaboard Change-Id: Icbbc8cc473ff80b519bdd1c6520c9ed679260843 Reviewed-on: http://gerrit.chromium.org/gerrit/2240 Reviewed-by: Anton Staaf <robotboy@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-24fdt: Add support for embedded device tree (CONFIG_OF_EMBED)Simon Glass
This new option allows U-Boot to embed a binary device tree into its image to allow run-time control of peripherals. This device tree is for U-Boot's own use and is not necessarily the same one as is passed to the kernel. BUG=chromium-os:11623 TEST=build and boot U-Boot on Seaboard Change-Id: I024d01079a44395e122a8b53e3901ba9a007dc5a Reviewed-on: http://gerrit.chromium.org/gerrit/621 Reviewed-by: Doug Anderson <dianders@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-24fdt: Add device tree control of U-Boot peripherals (CONFIG_OF_CONTROL)Simon Glass
This adds a device tree pointer to the global data. It can be set by board code. A later commit will add support for embedding it in U-Boot. BUG=chromium-os:11623 TEST=Build and boot U-Boot Change-Id: I9bda9e75e088a2218e7429b550d9cd0299d728a0 Reviewed-on: http://gerrit.chromium.org/gerrit/620 Reviewed-by: Doug Anderson <dianders@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-24Add tftp speed indicationSimon Glass
This prints a tftp speed indication after the download completes. This is the 3.6 MiB/s indicator below. Tegra2 (SeaBoard) # tftp ... Using asx0 device TFTP from server 172.22.72.144; our IP address is 172.22.73.81 Filename '/tftpboot/uImage-user-seaboard-1'. Load address: 0x408000 Loading: ################################################# 3.6 MiB/s done BUG=chromium-os:13228 TEST=Boot on Seaboard, make sure message appears. Use 'time tftp ...' to make sure that speed reported is approximately right. Change-Id: I5e96e2ef6aa196a6fd8486f2dae0fe11f7464f20 Reviewed-on: http://gerrit.chromium.org/gerrit/225 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-24NS16550: buffer readsScott Wood
This improves the performance of U-Boot when accepting rapid input, such as pasting a sequence of commands. Without this patch, on P4080DS I see a maximum of around 5 mw.l lines can be pasted. With this patch, it handles around 70 lines before lossage, long enough for most things you'd paste. Change-Id: Ic17bce2fe04a3526c2605ad6d58a0d1f172e728f Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Simon Glass <sjg@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/404 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-24armv7: cache maintenance operations for armv7Aneesh V
- Add a framework for layered cache maintenance - separate out SOC specific outer cache maintenance from maintenance of caches known to CPU - Add generic ARMv7 cache maintenance operations that affect all caches known to ARMv7 CPUs. For instance in Cortex-A8 these opertions will affect both L1 and L2 caches. In Cortex-A9 these will affect only L1 cache - D-cache operations supported: - Invalidate entire D-cache - Invalidate D-cache range - Flush(clean & invalidate) entire D-cache - Flush D-cache range - I-cache operations supported: - Invalidate entire I-cache - Add maintenance functions for TLB, branch predictor array etc. - Enable -march=armv7-a so that armv7 assembly instructions can be used Signed-off-by: Aneesh V <aneesh@ti.com>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-05-20powerpc/fsl_pci: Fix device tree fixups for newer platformsKumar Gala
We assumed that only a small set of compatiable strings would be needed to find the PCIe device tree nodes to be fixed up. However on newer platforms the simple rules no longer work. We need to allow specifying the PCIe compatiable string for each individual SoC. We introduce CONFIG_SYS_FSL_PCIE_COMPAT for this purpose and set it if the default isn't sufficient. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-19TFTP: add tftpsrv commandLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-12README: Clarify difference of CONFIG_WATCHDOG and CONFIG_HW_WATCHDOGDetlev Zundel
Now that we have the documentation, the code should be changed to reflect it ;) Asd far as I can see, these are the places where HW_WATCHDOG is used instead of WATCHDOG: arch/blackfin/cpu/blackfin/watchdog.c arch/m68k/cpu/mcf547x_8x/cpu.c The relevant maintainers are on CC. Signed-off-by: Detlev Zundel <dzu@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2011-05-12README: remove spurious lineLuca Ceresoli
2011-05-12Serial: p1011: new vendor init optionsJohn Rigby
Two new options: CONFIG_PL011_SERIAL_RLCR Some vendor versions of PL011 serial ports (e.g. ST-Ericsson U8500) have separate receive and transmit line control registers. Set this variable to initialize the extra register. CONFIG_PL011_SERIAL_FLUSH_ON_INIT On some platforms (e.g. U8500) U-Boot is loaded by a second stage boot loader that has already initialized the UART. Define this variable to flush the UART at init time. empty fifo on init Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
2011-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-04-30cmd_ide: enhance new feature "CONFIG_IDE_AHB"Macpaul Lin
Although most IDE controller is designed to be connected to PCI bridge, there are still some IDE controller support AHB interface for SoC design. The driver implementation of these IDE-AHB controllers differ from other IDE-PCI controller, some additional registers and commands access is required during CMD/DATA I/O. Hence a configuration "CONFIG_IDE_AHB" in cmd_ide.c is required to be defined to support these kinds of SoC controllers. Such as Faraday's FTIDE020 series and Global Unichip's UINF-0301. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-28powerpc/85xx: Change timebase divisor to be defined per processorKumar Gala
Introduce new CONFIG_SYS_FSL_TBCLK_DIV on 85xx platforms because different SoCs have different divisor amounts. All the PQ3 parts are /8, the P4080/P4080 is /16, and P2040/P3041/P5020 are /32. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-28powerpc: use 'video-mode' environment variable to configure DIUTimur Tabi
Use the 'video-mode' environment variable (for Freescale chips that have a DIU display controller) to designate the full video configuration. Previously, the DIU driver used the 'monitor' variable, and it was used only to determine the output video port. The old definition of the "monitor" environment variable only determines which video port to use for output. This variable was set to a number (0, 1, or sometimes 2) to specify a DVI, LVDS, or Dual-LVDS port. The resolution was hard-coded into board-specific code. The Linux command-line arguments needed to be hard-coded to the proper video definition string. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-04-28common: add a grepenv commandKim Phillips
u-boot environments, esp. when boards are shared across multiple users, can get pretty large and time consuming to visually parse. The grepenv command this patch adds can be used in lieu of printenv to facilitate searching. grepenv works like printenv but limits its output only to environment strings (variable name and value pairs) that match the user specified substring. the following examples are on a board with a 5313 byte environment that spans multiple screen pages: Example 1: summarize ethernet configuration: => grepenv eth TSEC etact=FM1@DTSEC2 eth=FM1@DTSEC4 ethact=FM1@DTSEC2 eth1addr=00:E0:0C:00:8b:01 eth2addr=00:E0:0C:00:8b:02 eth3addr=00:E0:0C:00:8b:03 eth4addr=00:E0:0C:00:8b:04 eth5addr=00:E0:0C:00:8b:05 eth6addr=00:E0:0C:00:8b:06 eth7addr=00:E0:0C:00:8b:07 eth8addr=00:E0:0C:00:8b:08 eth9addr=00:E0:0C:00:8b:09 ethaddr=00:E0:0C:00:8b:00 netdev=eth0 uprcw=setenv ethact $eth;setenv filename p4080ds/R_PPSXX_0xe/rcw_0xe_2sgmii_rev2_high.bin;setenv start 0xe8000000;protect off all;run upimage;protect on all upuboot=setenv ethact $eth;setenv filename u-boot.bin;setenv start eff80000;protect off all;run upimage;protect on all upucode=setenv ethact $eth;setenv filename fsl_fman_ucode_P4080_101_6.bin;setenv start 0xef000000;protect off all;run upimage;protect on all usdboot=setenv ethact $eth;tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/initramfs.cpio.gz.uboot;tftp c00000 $dir/p4080ds-usdpaa.dtb;setenv bootargs root=/dev/ram rw console=ttyS0,115200 $othbootargs;bootm 1000000 2000000 c00000; => Example 2: detect unused env vars: => grepenv etact etact=FM1@DTSEC2 => Example 3: reveal hardcoded variables; e.g., for fdtaddr: => grepenv fdtaddr fdtaddr=c00000 nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr => grep $fdtaddr fdtaddr=c00000 my_boot=bootm 0x40000000 0x41000000 0x00c00000 my_dtb=tftp 0x00c00000 $prefix/p4080ds.dtb nohvboot=tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/$ramdiskfile;tftp c00000 $dir/$fdtfile;setenv bootargs root=/dev/ram rw ramdisk_size=0x10000000 console=ttyS0,115200;bootm 1000000 2000000 c00000; => This patch also enables the grepenv command by default on corenet_ds based boards (and repositions the DHCP command entry to keep the list sorted). Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2011-04-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2011-04-27Don't grab memory for LCD if FB address is definedMinkyu Kang
If FB address is defined specific address then don't grab memory for LCD Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <kumar.gala@freescale.com>
2011-04-27arm: Use optimized memcpy and memset from linuxMatthias Weisser
Using optimized versions of memset and memcpy from linux brings a quite noticeable speed (x2 or better) improvement for these two functions. Here are some numbers for test done with jadecpu | HEAD(1)| HEAD(1)| HEAD(2)| HEAD(2)| | | +patch | | +patch | ---------------------------+--------+--------+--------+--------+ Reset to prompt | 438ms | 330ms | 228ms | 120ms | | | | | | TFTP a 3MB img | 4782ms | 3428ms | 3245ms | 2820ms | | | | | | FATLOAD USB a 3MB img* | 8515ms | 8510ms | ------ | ------ | | | | | | BOOTM LZO img in RAM | 3473ms | 3168ms | 592ms | 592ms | where CRC is | 615ms | 615ms | 54ms | 54ms | uncompress | 2460ms | 2462ms | 450ms | 451ms | final boot_elf | 376ms | 68ms | 65ms | 65ms | | | | | | BOOTM LZO img in FLASH | 3207ms | 2902ms | 1050ms | 1050ms | where CRC is | 600ms | 600ms | 135ms | 135ms | uncompress | 2209ms | 2211ms | 828ms | 828ms | | | | | | Copy 1.4MB from NOR to RAM | 134ms | 72ms | 120ms | 70ms | (1) No dcache (2) dcache enabled in board_init *Does not work when dcache is on Size impact: C version: text data bss dec hex filename 202862 18912 266456 488230 77326 u-boot ASM version: text data bss dec hex filename 203798 18912 266288 488998 77626 u-boot 222712 u-boot.bin Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-04-25Default to bootm_size() when CONFIG_SYS_BOOTMAPSZ is not definedGrant Likely
This patch adds a function getenv_bootm_mapsize() for obtaining the size of the early mapped region accessible by the kernel during early boot. It defaults to CONFIG_SYS_BOOTMAPSZ, or if not defined, defaults to getenv_bootm_size(), which in turn defaults to the size of RAM. getenv_bootm_mapsize() can also be overridden with a "bootm_mapsize" environmental variable. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-26rtc, rv3029: add trickle charger support.Heiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-20Merge branch 'misc' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2011-04-13crc32: make command optionalMike Frysinger
2011-04-13make `go` optionalMike Frysinger
2011-04-13env: make import/export optionalMike Frysinger
2011-04-13x86: Rename i386 to x86Graeme Russ
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-04-08Blackfin: ldrinfo: new commandMike Frysinger
Simple command to decode/check an LDR image before we try to boot it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-04powerpc: clean up DIU macro definitions for Freescale reference boardsTimur Tabi
Clean up the macro defintions used to enable DIU (video) support on the MPC8610HPCD and the MPC5121ADS so that they look more like the P1022DS, which is newer. Add software cursor support to all three boards. Also document the CONFIG_FSL_DIU_FB in the README. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-21mv: seperate kirkwood and armada from common settingLei Wen
Since there are lots of difference between kirkwood and armada series, it is better to seperate them but still keep the most common file shared by all marvell platform in the mv-common configure file. This patch move the kirkwood only driver definitoin in mv-common to the <soc_name>/config.h. This patch is tested with compilation for armada100 and guruplug. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-02spi: add support SuperH SPI moduleYoshihiro Shimoda
SH7757 has SPI module. This patch supports it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02net: sh_eth: add cache handlingYoshihiro Shimoda
Some CPU needs cache handling. So this patch add the config of CONFIG_SH_ETHER_CACHE_WRITEBACK, and it calls wback function. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02README: add description of sh_eth driverYoshihiro Shimoda
2011-01-19Fix defines needed to enable command sha1sumAlexander Holler
Documented is CONFIG_CMD_SHA1, through confusion in the source CONFIG_CMD_SHA1 and CONFIG_CMD_SHA1SUM has to be used to enable sha1sum. Fix both, the documentation and the source, so that only CONFIG_CMD_SHA1SUM is needed to enable the command sha1sum. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2011-01-17Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-01-17Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2011-01-14powerpc/8xxx: Refactor SRIO initialization into common codeKumar Gala
Moved the SRIO init out of corenet_ds and into common code for 8xxx/QorIQ processors that have SRIO. We mimic what we do with PCIe controllers for SRIO. We utilize the fact that SRIO is over serdes to determine if its configured or not and thus can setup the LAWs needed for it dynamically. We additionally update the device tree (to remove the SRIO nodes) if the board doesn't have SRIO enabled. Introduced the following standard defines for board config.h: CONFIG_SYS_SRIO - Chip has SRIO or not CONFIG_SRIO1 - Board has SRIO 1 port available CONFIG_SRIO2 - Board has SRIO 2 port available (where 'n' is the port #) CONFIG_SYS_SRIOn_MEM_VIRT - virtual address in u-boot CONFIG_SYS_SRIOn_MEM_PHYS - physical address (for law setup) CONFIG_SYS_SRIOn_MEM_SIZE - size of window (for law setup) [ These mimic what we have for PCI and PCIe controllers ] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-10pca953x: support 16-pin devicesChris Packham
This adds support for for the PCA9535/PCA9539 family of gpio devices which have 16 output pins. To let the driver know which devices are 16-pin it is necessary to define CONFIG_SYS_I2C_PCA953X_WIDTH in your board config file. This is used to create an array of {chip, ngpio} tuples that are used to determine the width of a particular chip. For backwards compatibility it is assumed that any chip not defined in CONFIG_SYS_I2C_PCA953X_WIDTH has 8 pins. Acked-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2011-01-09ftgmac100: support of gigabit eth ftgmac100Macpaul Lin
Add Faraday's ftgmac100 (gigabit ethernet) MAC controller's driver. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-11-27Coding Style (white space) cleanupWolfgang Denk
