path: root/README
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-03-18spl: Convert CONFIG_SPL_ABORT_ON_RAW_IMAGE into a positive optionAndrew F. Davis
CONFIG_SPL_ABORT_ON_RAW_IMAGE causes SPL to abort and move on when it encounters RAW images, express this same functionality as a positive option enabling support for RAW images: CONFIG_SPL_RAW_IMAGE_SUPPORT Also move uses of this to defconfigs. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Rework Kconfig logic a little, move to common/spl/Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-09ARM: Migrate errata to KconfigTom Rini
This moves all of the current ARM errata from various header files and in to Kconfig. This allows for a minor amount of cleanup as we had some instances where both a general common header file was enabling errata as well as the board config. We now just select these once at the higher level in Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-08cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to KconfigMasahiro Yamada
CONFIG_CMD_ZIP is not defined by any board. I am moving CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family. I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP" is better for this platform. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-02-03arch: powerpc: update the eLBC IP input clockPrabhakar Kushwaha
eLBC IP clock is always a constant divisor of platform clock pre-defined per SoC. Clock ratio register (LCRR) used in current implementation governs eLBC IP output cloc. Update sys_info->freq_localbus to represent eLBC input clock with value constant divisor of platform clock. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03arch: powerpc: update the IFC IP input clockPrabhakar Kushwaha
IFC IP clock is always a constant divisor of platform clock pre-defined per SoC. Clock control register (CCR) used in current implementation governs IFC IP output clock. Update sys_info->freq_localbus to represent IFC input clock with value constant divisor of platform clock. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-21status_led: Kconfig migration - introductionUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. doc/README.LED updated to reflect the Kconfig implementation. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2017-01-04powerpc: mpc85xx: Move CONFIG_SYS_PPC_E500_DEBUG_TLB to KconfigYork Sun
Use Kconfig SYS_PPC_E500_DEBUG_TLB and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate 8572] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-27README: remove description about CONFIG_USE_ARCH_MEMCPY/SETMasahiro Yamada
These options are now described in the Kconfig help. We do not want to maintain duplicated documentation. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-28README: fix typo FAT_ENV_DEV_AND_PARTNicolae Rosia
The actual define symbol is FAT_ENV_DEVICE_AND_PART Signed-off-by: Nicolae Rosia <Nicolae_Rosia@Mentor.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-31README: fix typo candiate -> candidateJelle van der Waa
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
2016-10-31cosmetic: Fix indentation in READMEAlexander von Gernler
Signed-off-by: Alexander von Gernler <grunk@pestilenz.org>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23video: Drop the sed13806 driverSimon Glass
This is not used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23video: Drop the smiLynxEM driverSimon Glass
This is not used in U-Boot anymore. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_BG_COL et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_FG_COL Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_CT69000 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_CT69000 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CFB_CONSOLE_ANSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE_ANSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONSOLE_PRE_CONSOLE_BUFFER options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-06PWM: Correct misspellings of "module" in context of PWMRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Heiko Schocher <hs@denx.de>
2016-10-06README: Drop CONFIG_SYS_USE_OSCCLKSimon Glass
This is not used in U-Boot so drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_SYS_INIT_DATA_SIZESimon Glass
This appears to be calculated automatically now. Drop the old reference. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: i2c: Drop unused i2c CONFIG optionsSimon Glass
CONFIG_SYS_NUM_I2C_ADAPTERS and CONFIG_SYS_I2C_MULTI_NOPROBES are not used in U-Boot, so drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: sh: Drop CONFIG_SYS_I2C_SH_BASE5Simon Glass
This is not used in U-Boot. Drop both the BASE and the SIZE config. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_SYS_USB_BRG_CLKSimon Glass
This is not used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_LAN91C96_BASESimon Glass
2016-10-06README: Drop CONFIG_OF_BOOT_CPUSimon Glass
2016-10-06README: Drop unused CONFIG_SYS_LS_MC_FW_... optionsSimon Glass
Drop a few that are not used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop unused JFFS2 optionsSimon Glass
There appear to be neither implemented nor used. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Correct CONFIG_ENV_OFFSET_RENDUND typoSimon Glass
Change this to CONFIG_ENV_OFFSET_REDUND. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_COGENT and related optionsSimon Glass
These are no-longer present in U-Boot. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop old Intel Monahans commentSimon Glass
This is no longer in the U-Boot source code, so drop this note from the README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-01fastboot: move FASTBOOT_FLASH options into KconfigPetr Kulhavy
Move FASTBOOT_MBR_NAME and FASTBOOT_GPT_NAME into Kconfig. Add dependency on the FASTBOOT_FLASH setting (also for FASTBOOT_MBR_NAME). Remove the now redundant GPT_ENTRY_NAME. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Add FIXME about xxx_PARTITION needing to be in Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-01fastboot: add support for writing MBRPetr Kulhavy
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
trini: Drop local memset() from examples/standalone/mem_to_mem_idma2intr.c Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Kconfig: spl: Add SPL support options to KconfigSimon Glass
There are a lot of SPL options in U-Boot to enable various features and drivers. Currently these do not use Kconfig. Add them to Kconfig along with suitable help, and drop them from the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-14armv8: ls2080a: Remove debug server supportYork Sun
Debug server feature has been dropped from roadmap. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-06README: add cmd directory descriptionXu Ziyuan
All of the command files have moved to cmd directory, add description to Directory Hierarchy. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
