path: root/arch/arm/dts/fsl-ls1043a.dtsi
2016-10-06armv8: ls1043: Add USB node in dts for ls1043Sriram Dash
Add the USB node for LS1043 in dts. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-28armv8: dts: fsl: Remove cpu nodes from Layerscape DTSIsAbhimanyu Saini
Currently layescape SoCs are not using cpu nodes. So removing them in favour of compatibly with similar SoCs that have different cores like LS2080A and LS2088A. This has been tested on LS2080AQDS, LS1043ARDB, LS1012ARDB. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-18armv8/ls1043a: update the node for QSPI supportYuan Yao
The address value and size value set for QSPI dts node "reg" property have type of u64 on arm64. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: add QSPI support in SD bootGong Qianyu
QSPI and IFC are pin-multiplexed on LS1043A. So we use ls1043aqds_sdcard_ifc_defconfig to support IFC in SD boot and ls1043aqds_sdcard_qspi_defconfig to support QSPI in SD boot. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: Add lpuart supportWenbin Song
Add lpuart support using the driver model. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-11-30armv8/ls1043ardb: add DSPI supportGong Qianyu
Use the U-Boot Driver Model. Just enable Freescale DSPI driver and set DSPI related parameters in dts file. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8/ls1043ardb: dts: add dtb supportGong Qianyu
Reuse dts files from ls1043a linux kernel. Some parts in dts files may not be needed by U-Boot. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
