path: root/arch/arm/dts/sun6i-a31-m9.dts
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-14sunxi: dts: Sync with kernelHans de Goede
Sync the sunxi dts files with the changes queued up for kernel-4.3 in mripard's sunxi/dt-for-4.3 branch. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-06-04sunxi: Sync dts files with the linux kernelHans de Goede
Copy over all the latest dts changes from mripard/sunxi/dt-for-4.2 , this gives us a proper dtsi file for the A33 rather then abusing sun8i-a23.dtsi for this. And this replaces our minimal (dummy) sun7i-a20-mk808c and sun8i-a33-astar-mid756 dts files with proper ones. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: dts: Sync all dts files with upstream kernelHans de Goede
Bring all the sunxi dts files (and update existing ones) from mripard/sunxi/dt-for-4.1 (which will be merged into upstream master any day now). This is necessary so that we can move all sunxi boards over to the driver model. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
