path: root/arch/arm/dts/sun6i-reference-design-tablet.dtsi
2016-08-26sun6i: Add defconfig and dts file for tablets using the inet-q972 PCBHans de Goede
Add a defconfig and dts file for tablets using the generic inet-q972 PCB. Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host, micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot, (mini) power-barrel and an usb wifi module. This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet. The dts files are identical to the ones submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
