path: root/arch/arm/dts/sun8i-r16-parrot.dts
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-07-02sunxi: Add defconfig and DTS file for Allwinner R16 EVB (Parrot)Quentin Schulz
The Parrot Board is an evaluation board with an Allwinner R16 (assumed to be close to an Allwinner A33), 4GB of eMMC, 512MB of RAM, USB host and OTG, a WiFi/Bluetooth combo chip, a micro SD Card reader, 2 controllable buttons, an LVDS port with separated backlight and capacitive touch panel ports, an audio/microphone jack, a camera CSI port, 2 sets of 22 GPIOs and an accelerometer. The DTS file is identical to the one submitted to the upstream kernel. Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
