path: root/arch/arm/include/asm/arch-s5pc1xx
2012-02-12S5P: support generic watchdog timerMinkyu Kang
This patch adds support the generic watchdog timer for s5pc1xx and exynos4 Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: HeungJun, Kim <riverful.kim@samsung.com>
2011-12-11usb:gadget:s5p Enable the USB Gadget framework at GONILukasz Majewski
This commit enables support for USB Gadgets on the GONI reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-09-04i2c:gpio:s5p: I2C GPIO Software implementation (via soft_i2c)Łukasz Majewski
This patch adds support for software I2C for GONI and Universal C210 reference targets. It adds support for access to GPIOs by number, not as it is present, by bank and offset. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2011-09-03gpio:samsung s5p_ suffix add for GPIO functionsŁukasz Majewski
This change is driven by need of general gpio_* functions, which as their parameter are accepting the GPIO pin number, NOT block and pin. This makes the code alike to omap, and allows for using more generic frameworks (e.g. software I2C). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-04armv7: adapt s5pc1xx to the new cache maintenance frameworkAneesh V
adapt s5pc1xx to the new layered cache maintenance framework Signed-off-by: Aneesh V <aneesh@ti.com>
2011-05-26S5P: add set_mmc_clk for external clock controlJaehoon Chung
This patch added set_mmc_clk for external clock control. c210 didn't support host clock control. So We need external_clock_control function for c210. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-05-26S5P:SROM config code moved to s5p-common directoryChander Kashyap
SROM config code is made common for S5P series of boards. smdkc100.c now refers to s5p-common/sromc.c for SROM related subroutines. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-26S5P: GPIO Macro Values Corrected.Chander Kashyap
S5PC2XX: Macro values for Pull Up and Driver Strength were wrong. S5PC1XX: Macro values for Driver Strength were wrong. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27ARMV7: S5P: Fixed register offset in mmc.hChander Kashyap
The MMC registers are accessed through struct s5p_mmc member variables. MMC controller "control4" register offset is set to 0x8C as per data sheet. The size of struct s5p_mmc is also corrected. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27S5P: timer: Use pwm functionsMinkyu Kang
Use pwm functions for timer that is PWM timer 4. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27ARM: S5P: pwm driver supportDonghwa Lee
This is common pwm driver of S5P. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-02-02S5P: serial: Use the inline function instead of static valueMinkyu Kang
2011-02-02armv7: s5pc1xx: don't use function pointer for clock functionsMinkyu Kang
Because of the bss area is cleared after relocation, we've lost pointers. This patch fixed it. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-10-19ARMV7: S5P: serial: support the s5pc210Minkyu Kang
This patch is for s5pc210 support. Due to the resigter of baudrate is changed from slot to value, add both of them to uart structure. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-10-19s5p_mmc: support 8-bit bus widthJaehoon Chung
This Patch do support 8-bit bus width for s5p So we add parameter for bus_width (in s5p_mmc_init(), s5p_mmc_initialize()) If want to use 8-bit bus width, only change (0, 8) instead of (0, 4). Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-30ARMV7: S5P: rename the member of gpio structureMinkyu Kang
Typically we declare the name of gpio structure to "gpio", so it was duplicated around the name. (e.g: gpio->gpio_a) This patch modified the naming that is removing "gpio_". Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-30ARMV7: S5P: separate the peripheral clocksMinkyu Kang
Because of peripheral devices can select clock sources, separate the peripheral clocks. (pwm, uart and so on) It just return the pclk at s5pc1xx SoC, but s5pc210 SoC must be calculated by own clock register setting. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-26ARMV7: S5P: fix the macro at samsung_get_base functionMinkyu Kang
New line is unnecessary at last line of macro. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-23S5P: mmc: fix the mmc offsetMinkyu Kang
This patch fixed the size of mmc structure. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-23ARMV7: S5P: rename from s5pc1xx to s5pMinkyu Kang
Because of these are common files around s5p Socs, rename from s5pc1xx to s5p. And getting cpu_id is SoC specific, so move to SoC's header file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-17S5P: Use accessor functions instead of SoC specific defines to access the ↵Minkyu Kang
base address This patch is intended to prepare the other S5P SoC. (s5pc210) If use SoC specific defines then can't share with other SoC. So, make the accessor functions for access the base address by common way. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-03S5P: support mmc driverMinkyu Kang
This patch adds support mmc driver for s5p SoC Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-04-17SAMSUNG: make s5p common gpio functionsMinkyu Kang
Because of s5pc1xx gpio is same as s5p seires SoC, move gpio functions to drvier/gpio/ and modify structure's name from s5pc1xx_ to s5p_. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-04-17SAMSUNG: serial: modify name from s5pc1xx to s5pMinkyu Kang
Because of other s5p series SoC will use these serial functions, modify function's name and structure's name. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
