The current approach for setting the environment variables that
describe the memory layout runs the risk of overlapping with
reserved memory regions. Use the lmb code to derive the addresses
for these variables instead.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
The firmware on larger NVMe drives needs more than 100ms to come up.
Change the timeout to 1s.
Signed-off-by: Hector Martin <marcan@marcan.st>
Support for Apple M1 Pro and Max will allow using a single binary for
all M1 SoCs. The M1 Pro/Max have a different memory layout. The RAM
start address is 0x100_0000_0000 instead of 0x8_0000_0000.
Replace the hardcoded memory layout with dynamic initialized
environment variables in board_late_init().
Tested on Mac Mini (2020) and Macbook Pro 14-inch (2021).
Signed-off-by: Janne Grunau <j@jannau.net>
Reviewed-by: Mark Kettenis <kettenis@openbsd.org>
Choose the memory map based on the compatible property from the
device tree passed to us by m1n1. Since DRAM on the M1 Pro/Max
starts at a different address avoid hardcoding the top of usable
memory. Also make sure that the addresses entered into the memory
map are page aligned such that we don't crash in dcache_enable().
Tested on: Macbook M1 Max
Tested-by: Janne Grunau <j@jannau.net>
Most Apple IOPs run a firmware that is based on what Apple calls
RTKit. RTKit implements a common mailbox protocol. This code
provides an implementation of the AP side of this protocol,
providing a function to initialize RTKit-based firmwares as well
as a function to do a clean shutdown of this firmware.
Tested on: Macbook Air M1
U-Boot is expected to support multiple generations of Apple SoCs
in a single binary with a single defconfig. Therefore it makes
more sense to set SYS_SOC to "apple".
Rely on the new watchdog timer driver and the sysreset uclass to
reset the system. This gets rid of hard-coded addresses and
should work on systems based on the new M1 Pro and M1 Max SoCs
as well.
Tested-on: Apple M1 Macbook
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
Add support for Apple's M1 SoC that is used in "Apple Silicon"
Macs. This builds a basic U-Boot that can be used as a payload
for the m1n1 boot loader being developed by the Asahi Linux
project.
[trini: Add MAINTAINERS entry]
