- fdt_support: Add fdt_for_each_node_by_compatible() helper macro
(Marek)
- turris_omnia: Fixup SATA or PCIe nodes at runtime in DT blob (Pali)
- pci_mvebu: Add support for Kirkwood PCIe controllers (Pali)
- SPL: More verifications for kwbimage in SPL (Pali)
- mvebu: Remove comphy_update_map() (Pali)
- Minor misc stuff
Add macro fdt_for_each_node_by_compatible() to allow iterating over
fdt nodes by compatible string.
Convert various usages of
off = fdt_node_offset_by_compatible(fdt, start, compat);
while (off > 0) {
code();
off = fdt_node_offset_by_compatible(fdt, off, compat);
and similar, to
fdt_for_each_node_by_compatible(off, fdt, start, compat)
code();
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
If multiple entries are present in the memory-region property, this new
memory-region-names property can be used to specify names for each of
them so that they can be more easily distinguished.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Rather than duplicate the Ethernet MAC address and carveout updating
code for each board, move it to a common location and make it more
reusable.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Migrate CONFIG_GICV2 and CONFIG_GICV3 to Kconfig. We still have the GIC
related registers that need to be handled more cleanly but start by
moving this symbol to Kconfig.
When seaboard_defconfig is compiled with LTO, the compiler complains
about some instructions not being supported in ARM mode.
This is caused by arch/arm/mach-tegra/tegra20/warmboot_avp.c having
different CFLAGS declared in Makefile. This file needs to be compiled
without LTO.
Fix this by removing -flto for this file.
This commit does the same thing as Linux commit 33def8498fdd.
Use a more generic form for __section that requires quotes to avoid
complications with clang and gcc differences.
Remove the quote operator # from compiler_attributes.h __section macro.
Convert all unquoted __section(foo) uses to quoted __section("foo").
Also convert __attribute__((section("foo"))) uses to __section("foo")
even if the __attribute__ has multiple list entry forms.
It's an old bringup board with out upstream Linux or L4T support
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <twarren@nvidia.com>
Historically, the reset_cpu() function had an `addr` parameter which was
meant to pass in an address of the reset vector location, where the CPU
should reset to. This feature is no longer used anywhere in U-Boot as
all reset_cpu() implementations now ignore the passed value. Generic
code has been added which always calls reset_cpu() with `0` which means
this feature can no longer be used easily anyway.
Over time, many implementations seem to have "misunderstood" the
existence of this parameter as a way to customize/parameterize the reset
(e.g. COLD vs WARM resets). As this is not properly supported, the
code will almost always not do what it is intended to (because all
call-sites just call reset_cpu() with 0).
To avoid confusion and to clean up the codebase from unused left-overs
of the past, remove the `addr` parameter entirely. Code which intends
to support different kinds of resets should be rewritten as a sysreset
driver instead.
This transformation was done with the following coccinelle patch:
expression argvalue;
- reset_cpu(argvalue)
+ reset_cpu()
identifier argname;
type argtype;
- reset_cpu(argtype argname)
+ reset_cpu(void)
Signed-off-by: Harald Seiler <hws@denx.de>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Driver model: make some udevice fields private
Driver model: Rename U_BOOT_DEVICE et al.
dtoc: Tidy up and add more tests
ns16550 code clean-up
x86 and sandbox minor fixes for of-platdata
dtoc prepration for adding build-time instantiation
Prepare v2021.01-rc5
The current macro is a misnomer since it does not declare a device
directly. Instead, it declares driver_info record which U-Boot uses at
runtime to create a device.
The distinction seems somewhat minor most of the time, but is becomes
quite confusing when we actually want to declare a device, with
of-platdata. We are left trying to distinguish between a device which
isn't actually device, and a device that is (perhaps an 'instance'?)
It seems better to rename this macro to describe what it actually is. The
macros is not widely used, since boards should use devicetree to declare
devices.
Rename it to U_BOOT_DRVINFO(), which indicates clearly that this is
declaring a new driver_info record, not a device.
Try to maintain some consistency between these variables by using _plat as
a suffix for them.
Activate ARCH_SUPPORT_PSCI as other TEGRA124 target and remove
CONFIG_ARMV7_PSCI and CONFIG_ARMV7_PSCI_NR_CPUS in configs file as they
are migrated in Kconfig.
Select CONFIG_ARMV7_PSCI_0_1 (the first PSCI version),
because CONFIG_ARMV7_PSCI_0_2 and CONFIG_ARMV7_PSCI_1_0
are not activated in this product.
This patch depend on the previous serie [1].
I don't test this patch on real hardware but
after this patch the size of the binary don't change.
In .config we have:
CONFIG_ARCH_SUPPORT_PSCI=y
CONFIG_ARMV7_PSCI=y
# CONFIG_ARMV7_PSCI_1_0 is not set
# CONFIG_ARMV7_PSCI_0_2 is not set
CONFIG_ARMV7_PSCI_0_1=y
CONFIG_ARMV7_PSCI_NR_CPUS=4
In u-boot.cfg, this patch only add the 2 lines
#define CONFIG_ARCH_SUPPORT_PSCI 1
#define CONFIG_ARMV7_PSCI_0_1 1
[1] "Convert CONFIG_ARMV7_PSCI_1_0 and CONFIG_ARMV7_PSCI_0_2 to Kconfig"
http://patchwork.ozlabs.org/project/uboot/list/?series=184029
Regards
Patrick
END
Reviewed-by: Peter Chubb <peter.chubb@data61.csiro.au>
At present only the ARMv7 tegra SoCs actually use binman to create an
image. Change the config to reflect this, since otherwise running binman
will produce an error.
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
In order to update our <linux/compiler.h> to a newer version that no
longer provides ACCESS_ONCE() but only READ_ONCE()/WRITE_ONCE() we need
to convert arch/arm/mach-tegra/ivc.c to the other macros.
cfb_console driver uses 'vga' console name and we still have board
environments defining this name. Re-use existing DM_VIDEO work-
around for console name to support 'vga' name in stdout environment.
Tested-by: Soeren Moch <smoch@web.de>
Move this uncommon header out of the common header.
Move this header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
Have this symbol follow the pattern of all other such symbols.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
The Jetson Nano Developer Kit is a Tegra X1-based development board. It
is similar to Jetson TX1 but it is not pin compatible. It features 4GB
of LPDDR4, a SPI NOR flash for early boot firmware and an SD card slot
used for storage.
HDMI 2.0 or DP 1.2 are available for display, four USB ports (3 USB 2.0
and 1 USB 3.0) can be used to attach a variety of peripherals and a PCI
Ethernet controller provides onboard network connectivity. NVMe support
has also been added. Env save is at the end of QSPI (4MB-8K).
A 40-pin header on the board can be used to extend the capabilities and
exposed interfaces of the Jetson Nano.
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Fix VI_I2C clock source type. Will be needed by VI_I2C driver.
Also added use of INTERNAL_ID macro in two places, needed to keep
the id returned to 8 bits.
T210 CBoot is now doing the full pinmux and GPIO init, based on the DTB
tables. Remove pinmux/GPIO init tables & code from all T210-based builds
below:
p2371-2180 aka TX1
p2371-0000
e2220-1170
p2571
This commit removes the programming sequence that enables PLLE and UPHY
PLL hardware power sequencers. Per TRM, boot software should enable PLLE
and UPHY PLLs in software controlled power-on state and should power
down PLL before jumping into kernel or the next stage boot software.
Adds call to board_cleanup_before_linux to facilitate this.
Signed-off-by: JC Kuo <jckuo@nvidia.com>
At present dm/device.h includes the linux-compatible features. This
requires including linux/compat.h which in turn includes a lot of headers.
One of these is malloc.h which we thus end up including in every file in
U-Boot. Apart from the inefficiency of this, it is problematic for sandbox
which needs to use the system malloc() in some files.
Move the compatibility features into a separate header file.
At present panic() is in the vsprintf.h header file. That does not seem
like an obvious choice for hang(), even though it relates to panic(). So
let's put hang() in its own header.
[trini: Migrate a few more files]
These functions relate to memory init so move them into the init
header.
Move this function out of common.h and into a relevant header file.
Until now, we only support aes128. This commit add the support
of aes192 and aes256.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
Part of the env cleanup moved this out of the environment code and into
the net code. However, this helper is sometimes needed even when the net
stack isn't included.
Move the helper to lib/net_utils.c like it's similarly-purposed
string_to_ip(). Also rename the moved function to similar naming.
Reported-by: Ondrej Jirman <megous@megous.com>
Move this function into init.h which seems to be designed for this sort
of thing. Also update the header to declare struct global_data so that it
can be included without global_data.h being needed.
Move these two functions into the irq_funcs.h header file. Also move
interrupt_handler_t as this is used by the irq_install_handler() function.
These functions are CPU-related and do not use driver model. Move them to
cpu_func.h
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
These functions belong in cpu_func.h. Another option would be cache.h
but that code uses driver model and we have not moved these cache
functions to use driver model. Since they are CPU-related it seems
reasonable to put them here.
Move them over.
This function belongs in time.h so move it over and add a comment.
This reverts commit 0797f7f0b7e1d7853e2842ddc235ffef139fa792.
Tegra specific solution is not required any more as efi core has been
made aware of ram_top with the following commit:
7b78d6438a efi_loader: Reserve unaccessible memory
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
This header file is now only used by files that access internal
environment features. Drop it from various places where it is not needed.
Move env_set() over to the new header file.
