CONFIG_CPU_FREQ_HZ
Historically, the reset_cpu() function had an `addr` parameter which was
meant to pass in an address of the reset vector location, where the CPU
should reset to. This feature is no longer used anywhere in U-Boot as
all reset_cpu() implementations now ignore the passed value. Generic
code has been added which always calls reset_cpu() with `0` which means
this feature can no longer be used easily anyway.
Over time, many implementations seem to have "misunderstood" the
existence of this parameter as a way to customize/parameterize the reset
(e.g. COLD vs WARM resets). As this is not properly supported, the
code will almost always not do what it is intended to (because all
call-sites just call reset_cpu() with 0).
To avoid confusion and to clean up the codebase from unused left-overs
of the past, remove the `addr` parameter entirely. Code which intends
to support different kinds of resets should be rewritten as a sysreset
driver instead.
This transformation was done with the following coccinelle patch:
expression argvalue;
- reset_cpu(argvalue)
+ reset_cpu()
identifier argname;
type argtype;
- reset_cpu(argtype argname)
+ reset_cpu(void)
Signed-off-by: Harald Seiler <hws@denx.de>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Map all resource for R5 to operate properly.
The patch is done based on the commit 23f7b1a77602 ("armv7R: K3: am654:
Enable MPU regions") which also map the whole 4GB at first and then change
mapping for DDR.
Move this uncommon header out of the common header.
Move this function out of common.h and into a relevant header file.
Xilinx ZynqMP also contains dual Cortex R5 which can run U-Boot.
This patch is adding minimal support to get U-Boot boot.
U-Boot on R5 runs out of DDR with default configuration that's why
DDR needs to be partitioned if there is something else running on arm64.
Console is done via Cadence uart driver and the first Cadence Triple
Timer Counter is used for time.
This configuration with uart1 was tested on zcu100-revC.
U-Boot 2018.05-rc2-00021-gd058a08d907d (Apr 18 2018 - 14:11:27 +0200)
Model: Xilinx ZynqMP R5
DRAM: 512 MiB
WARNING: Caches not enabled
MMC:
In: serial@ff010000
Out: serial@ff010000
Err: serial@ff010000
Net: Net Initialization Skipped
No ethernet found.
ZynqMP r5>
There are two ways how to run this on ZynqMP.
1. Run from ZynqMP arm64
tftpb 20000000 u-boot-r5.elf
setenv autostart no && bootelf -p 20000000
cpu 4 disable && cpu 4 release 10000000 lockstep
or
cpu 4 disable && cpu 4 release 10000000 split
2. Load via jtag when directly to R5
